Elsmar Cove Quality DiscussionsColorant leaching out of Nylon in AutoclaveThe Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Some Related Topic Tags
autoclaves, medical device parts and components, nylon, plastic injection molding
  Post Number #1
Old 5th December 2017, 05:10 PM
PatrickSebast
Please Help! Colorant leaching out of Nylon in Autoclave
We have recently had a customer seeing color leaching out of our Nylon parts into surrounding plastics during autoclaving.
The nylon parts they have noted seem to have a colorant with some oil based components, our colorant supplier says that the colorant SHOULD be inert once mixed during injection molding but obviously they don't have much experience with autoclaving. Also the colors with oil mixed in tend to be a bit darker so it may simply be that the leaching is more noticeable and it is not directly related to the oil.
We don't have an autoclave on site, but I have boiled the parts and found that there is no color leach.
I also boiled the (nylon based) colorant pellets and found that the colors leached very prominently in the colorants that contained oil and very slightly in the colorants that did not.
Wondering if anyone else has ever encountered this as I can't find anything about it online and none of our colorant contacts seem to have any idea what is going on.
  Post Number #2
Old 5th December 2017, 06:19 PM
Ronen E
Re: Colorant leaching out of Nylon in Autoclave
In Reply to Parent Post by PatrickSebast View Post
Hello Patrick and welcome to the Cove
Please note that autoclave may go up to 134C (minimum 121C) so open boiling in water is not a very good simulation.
Are these parts / clients / uses / processes well established, or is something new? Was any change implemented?
First step in finding a root cause is being able to reproduce the failure. If you don’t have access to an autoclave and wish to avoid buying one (a small / simple one might suffice and maybe isn’t too costly in comparison with the cost impact of the issue, but pay attention to the complaining customer autoclave’s spec), you might be able to “outsource” the autoclaveing from a nearby healthcare provider or a lab.
Please also consider the potential effects of vacuum inside the autoclave.
Cheers,
Ronen.
  Post Number #3
Old 5th December 2017, 10:52 PM
PatrickSebast
It is a brand new product that they are sampling for the first time. This is a universal failure and they are doing testing on all the products so they will let us know if other colorants start to leak with more time.
The autoclave will be set to 121C, multiple cycles may occur, and it will be 13psia.
Investigations should get us to a reasonable root cause eventually, but it would be much faster to have someone confirm a similar experience if one is available.
  Post Number #4
Old 6th December 2017, 12:41 AM
Ronen E
Is your product intended for autoclaving (ie was it part of the design input)? If yes, wasn’t it verified and validated before being offered to customers?
If it wasn’t intended, I guess a design change will be required for accommodating it.
  Post Number #5
Old 6th December 2017, 12:42 PM
NikkiQSM
In Reply to Parent Post by Ronen E View Post
I agree. Why not look into other colorants which are certified to hold up against autoclaving in nylon? Suggest these new colorants to the customer - they may be willing to make the change and save the hassle.
  Post Number #6
Old 8th December 2017, 04:30 AM
rob73's Avatar
rob73
Patrick
Is there a reason nylon was chosen as a material? Nylon is hygroscopic i.e. it will absorb water, if as you suggest some of the colourant is suspended in oil then migration is quite possible. Nylon would not be my first choice of material for autoclave use, polypropylene or polysulfone's are better known for their thermal stability during autoclaving.
http://www.industrialspec.com/images...s-from-ISM.pdf
  Post Number #7
Old 13th February 2018, 12:01 PM
PatrickSebast
Just wanted to update this thread for anyone who might run into this problem in the future:
After extensive testing in conjunction with the customer and our colorant supplier we did isolate the color leaching specifically to the oil component in the colorant. Only colorants with an oil component leaked out, and removing the oil component from the colorant removed the problem.
We did discuss the idea that Nylon was a not ideal for autoclaves, but the customer only had a limited set of 'approved' material via their own regulations for the product and said it would take too long to add in a new material so they preferred to stay with Nylon.
Nylon 66 Molding Process - It is normal to have voids when molding nylon? quality1 Manufacturing and Related Processes 9 17th October 2010 04:37 PM
Grilamid L25 vs. L20 for Nylon 12 Balloon Tubing NB-Eng Manufacturing and Related Processes 1 9th September 2010 05:06 PM
510(K) submission - Is it necessary if we changed from nylon to polyester suture? Cinti US Food and Drug Administration (FDA) 4 16th December 2009 10:04 PM
Customer Approval to Substitute Nylon 6/10 with 6/12? turnit Manufacturing and Related Processes 6 18th May 2008 05:49 PM
A mix of plastic and solid colorant - 'Gage' R&R on a process Benoit Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1 7th October 2003 05:40 PM
The time now is 03:40 AM. All times are GMT -4.
Misc. Internal Links
