Re: Do you set up your QC visual standard for medical product like this?
do you set up your QC visual standard (for medical product) like this?
Scratch length < 3 mm
Bubbles/dots/dents size < 0.20 x 0.20 mm;
The whole PC tube not more than 2 scratches/bubbles/dots/dents within 1 foot apart from the unaided eye;
The problem, as I see it, is that you don't specify how to measure it. When you use the phrase "unaided eye" I get the feeling that it is merely a visual inspection. I, for one, am not able to see whether a given "dent" is 0.20 x 0.20 mm, especially at 1 feet (how do I measure that distance, too?). I would say that you need some sort of reference to provide a guide to what is acceptable or not.
I also wonder, do you intend to test each and every length of tubing? It is practically impossible to test all tubing that you extrude manually, and the effect of the performed testing is not going to bring you any value (at least very little). If I were you, I would go for some sort of vision control if it were economically possible. Gives better test results in the long run.
