Can Internal Auditors Audit the Internal Audit Process / System? How?
darkafar
Could internal auditors audit internal audit process? If so, how to avoid contradicting “Auditors shall not audit their own work.”?
AndyN
Moved On
Re: Can Internal Auditors Audit the Internal Audit Process / System?
It seems to me that as long as the internal auditor doesn't audit the records of any work they actually performed, (and if they're not responsible for the audit program) then it would be O.K.
You would want to ensure that they were 'objective and impartial', so being careful which candidate was chosen is important.
Andy
Duke Okes
I agree with Andy. If this were not possible there would have to be a lot more external auditors contracting with companies. I've helped may companies achieve registration, and no problems with auditor independence.
Sambasi
Involved - Posts
It is possible this way.
After you complete an internal audit, choose an auditor who was not in the team of auditors for the earlier completed internal audit.He can audit the entire internal audit process.
Dear Darkafar,
You have posed an interesting question. In my opinion, the Management Representative is the one who commissions the internal audit (client) and he is responsible for the intenral audit process. Hence I would not expect him to carry out an audit on "internal audit". Any internal auditor who has not been involved in establishing/maintaining the procedure for internal audit should be able to audit the internal auditing procedure. Another approach may be to invite an "external" auditor to carry out an audit of the intenral auditing process. This audit being a conformance audit, should ideally confine itself to the assessment of conformance to the established procedure (e.g. audit programme, auditor qualification, audit elements etc.) rather than to assess the quality/content of the internal audit report(s). The latter should be left to be discussed between the Management Representative (client) and the team of internal auditors or the Lead internal auditor.
with best regards,
Ramakrishnan
Hershal
Metrologist-Auditor
I would suggest that they MUST audit the internal audit process for two reasons:
1. It is part of the QMS, regardless of the standard, and they must audit the entire QMS.....
2. How else will you determine improvements or issues within the process?
Just my thoughts.....
Hershal
SteelMaiden
I'm with Andy. I just make sure that I ask two auditors to audit the audit program. That way if one audited an area, the second can look at that audit and vice versa. It has always worked for me with no negative input from the registrar. Another thing we have done is MR from Environmental is included in quality audit audit and I have been on audit team for environmental audits. This is a little more questionable, as I end up responsible for a lot of environmental things, but I attempt to maintain impartiality.:D
GStough
We just had our internal audit process audited by the lead auditor at one of our other manufacturing facilities. He drove over (it's about a 4-hr. drive) last Thursday and did the audit on Friday. This is how we do it to ensure that internal auditors don't audit their own work. This removes any doubt and ensures a completely impartial audit. :D
Randy
Dear Darkafar,
with best regards,
Ramakrishnan
One of the few times I'll disagree with you Dr R. The internal audit, the requesting of and the results of are the property of Top Management (who is actually the client for an internal program).
The responsibility of the internal audit program is in whoever Top Management has given it to.
Read Section 5 of ISO 19011:2002.
