EN60601-1-2 4th edition requirements - Tests for devices produced in two options
Please read this thread...
Software update
Some Related Topic Tags
iec 60601 - medical electrical equipment, medical devices
  Post Number #1
Old 10th August 2018, 07:02 AM
medical_electronic
Please Help! EN60601-1-2 4th edition requirements - Tests for devices produced in two options
Hello, I am new here but I am little confused how should I testing devices in my company to get agree with new standard. For Example I need to prepare tests for device which is produced in two options:
with internal power supply 120V/60Hz
with internal power supply 230V/50Hz.
The power suplies are mounted differently, depending on the order. The rating voltage (sticker on the device) is also different for both types of power supply.
How should I perform EMC test to be agree with EN60601-1-2 4th edition?
In the standard there is a record that during testing it is enough to use "any voltage" and "any frequency". Can I, however, treat my bed as one device or as a completely different two devices?
If as two, could I do some tests together?
Maybe could I choose a worse case on the basis of pre-complenice test and test one device on this basis?
Thanks for comments.
  Post Number #2
Old 10th August 2018, 09:30 AM
Pads38
Re: EN60601-1-2 4th edition requirements - Tests for devices produced in two options
As you have suggested Table 1 in the 4th edition clarifies supply requirements. As bullet point a) says, when it says 'Any one voltage' it is not necessary to re-test at additional voltages.
But if your 230V and 115V psu are totally different your test house may look to repeat some tests - perhaps at an exploratory level to check that they do not perform differently.
Welcome to the forums!
Thanks to Pads38 for your informative Post and/or Attachment!
  Post Number #3
Old 14th August 2018, 03:54 AM
medical_electronic
As you said, but as I understand it is in my interest to determine the methodology of measurement. The laboratory performs only tests according to my guidelines, which I determined based on the standard.
  Post Number #4
Old 15th August 2018, 04:04 AM
3dBUnderThe Limit
My two cents
As emission test shall be performed in the modes that maximizes emission, pre-compliance testing can guide you to the modes and configurations that you will test at the test lab. (ed4 7.2.1)
For the power supply, voltage should be any voltage within the rated range (Table 1 note a)).
So the method I would propose would be pre-compliance testing with both mains voltages. Based on that and design differences between the two configuration I would decide if final tests should be performed on both configurations or only one.
  Post Number #5
Old 15th August 2018, 05:05 AM
MedMartin
Hello,
In one project we evaluated a second source display and performed just preliminary EMC tests on the second display to evaluate possible differences for radiation and susceptility. This was fine for the test house and for the notified body.
The standard is not clear on this in your case and you should talk with your notified body. I would say that at least you have to document that there are no differences based on extensive preliminary testing in all modes (radiated and conducted emissions, immunitiy).
But maybe just perform the tests with all 2 configurations.
Best regards
Martin
List of Tests - IEC 61010-1, 3rd edition and IEC 60601-1, 3.1 edition Thukira IEC 60601 - Medical Electrical Equipment Safety Standards Series 0 20th March 2018 02:00 AM
IEC 61010 3rd Edition - When devices are listed to the 2nd edition Pick 5 CE Marking (Conformité Européene) / CB Scheme 5 20th June 2012 03:41 PM
Rework Devices placed on the market - IEC 60601-1 Requirements 3rd edition Mawos78 IEC 60601 - Medical Electrical Equipment Safety Standards Series 7 19th April 2012 02:55 PM
EN60601-1 2. or 3. edition - Question KESADV IEC 60601 - Medical Electrical Equipment Safety Standards Series 5 28th September 2011 08:16 AM
Medical Devices produced during OQ runs. Are they saleable product? arios Other US Medical Device Regulations 5 11th September 2010 11:53 PM
The time now is 12:39 AM. All times are GMT -4.
Misc. Internal Links
