Elsmar Cove Quality DiscussionsProcess Capability for Non-Normal Data - Philosophical QuestionsThe Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Some Related Topic Tags
non-normal data distribution, process capability
  Post Number #1
Old 10th August 2017, 07:22 PM
yerasij
Please Help! Process Capability for Non-Normal Data - Philosophical Questions
I am trying to answer some philosophical questions that came up in my discussions with my management. I am trying to find some answers to these questions on the Internet and my reference books. But, I have not been able to find one. Hoping that some one here might be able to help:
Background: We work with contract manufacturers (CM's) who make Injection molding parts for us. Historically, we used to collect 32Pcs. (not sure where that came from) data and calculate CpK (without understanding if the process is stable or if the distribution meets normality assumption). In the last year or two, we have been working with all our CM's to establish proper control charts and understand the stability and reduce "special causes". We overcame many challenges (trying to understand the root cause and eliminating them or adding the "causes" if it helps reduce variation etc.,) and now we are at a step where we want to improve how we understand and report out capability.
There are many CTQ's identified on the drawing (some are safety critical and some are critical to cosmetics). Now were are trying to understand the "real" capability of the process and understand # of defects shipped out.
The questions I have are:
Question 1: Lets assume an injection molded part (PC) has 5 characteristics (SPC A,B,C,D and E), and 4 of them (SPC A,B,C and D) are "non-normal". When I try to do best fit method (JMP or Minitab)- all the 4 curves have different distributions. Is it okay to pick different distributions for every characteristic ? (same parts coming from same cavities) or do I need to pick one distribution that has an "Okay" fit for all the characteristics.
Please note that I am only trying to understand the process capability (DPPM) and not trying to compare the characteristics.
The same SPC's follow a different distribution on the next set of tools (which has the same tool structured and similar process parameters). I did not see any statistical difference between the tools or cavities in means or variation.
Question 2: Why aren't the dimensions of a simple injection molded part always follow normal distribution ? I looked at the tool structure and wasn't able to find a "physical limit". Why are they not following normal distribution as expected ? Is that bad ?
Please let me know if you need any more information to help answer these questions.
  Post Number #2
Old 14th August 2017, 08:47 AM
Miner's Avatar
Miner
Look! Re: Process Capability for Non-Normal Data - Philosophical Questions
It is certainly possible that different dimensions have different distributions. For example, a fixed dimension might have a different distribution than a closure dimension. Or a feature size versus a distance between features.
However, I would not expect the same dimension to vary its distribution from tool to tool unless you are including cavity to cavity variation. If this is the case, you are mixing process streams and fitting a distribution is a waste of time.
There are a number of things that cause a feature to follow a distribution other than normal. For example, take a fixed dimension such as outer diameter. The part cannot be larger than the diameter of the mold cavity, but may be smaller due to shrinkage. This would result in a skewed distribution. GD&T can artificially cause skewness by taking absolute values or using polar versus Cartesian coordinates.
Thank You to Miner for your informative Post and/or Attachment!
  Post Number #3
Old 14th August 2017, 12:01 PM
Miner's Avatar
Miner
If you attach data, we can better assess what you are seeing. I have Minitab, but Excel would ensure others could also assist.
  Post Number #4
Old 14th August 2017, 12:35 PM
Proud Liberal's Avatar
Proud Liberal
I would be careful about fitting data to a distribution based on a correlation calculation (ie R square). The correct distribution should be determined by the physics of the process not the mathematics of the dataset. If the correlation to that distribution defined by the process isn't acceptable there are other factors at work that need to be identified and addressed.
(and to Miner's point, mixing process streams can only lead to false conclusions)
Thanks to Proud Liberal for your informative Post and/or Attachment!
  Post Number #5
Old 14th August 2017, 02:42 PM
howste's Avatar
howste
In Reply to Parent Post by Proud Liberal View Post
Process Capability for Non-Normal Data - Philosophical Questions-cropped-header2013-jpg
Thank You to howste for your informative Post and/or Attachment!
  Post Number #6
Old 14th August 2017, 04:16 PM
Statistical Steven's Avatar
Statistical Steven
I assume the 32 pieces come from the number of cavities in the mold (4,8,16 or 32).
If you combine data across cavities for any feature, your data is not normal, it is multinomial. You have to look at Cpk by cavity, then combine the Cpks in order to understand that data. I will assume (might be wrong) that each cavity on its own is normally distributed.
Let me know if this helps.
In Reply to Parent Post by yerasij View Post
Thank You to Statistical Steven for your informative Post and/or Attachment!
  Post Number #7
Old 16th August 2017, 08:42 AM
Mike S.
How much data do you have? Thousands of parts or hundreds of thousands? Should you really be calculating PPM?
Maybe look up Dr. Wheeler's column "The Parts Per Million Problem".
Thanks to Mike S. for your informative Post and/or Attachment!
Capability Analysis - Dealing with non-normal data in Minitab alokb Using Minitab Software 8 4th May 2014 10:51 AM
Capability with Non-Normal Data - Component Strength Tim S Statistical Analysis Tools, Techniques and SPC 11 1st December 2009 10:37 AM
Capability Analysis of Non-Normal Data Seyed Statistical Analysis Tools, Techniques and SPC 23 14th October 2009 12:50 AM
Capability of Inherently Non-Normal Process - Plating Process Thickness Distribution jefnik3201028 Statistical Analysis Tools, Techniques and SPC 9 1st February 2007 10:07 AM
Bootstraping and Resampling Statistics - Capability for non-normal variable data Ravi Khare Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6 10th March 2002 05:13 AM
The time now is 05:57 AM. All times are GMT -4.
Misc. Internal Links
