Interesting Discussion Using a Wiki to implement a Quality Management System (QMS)
Pancho
wikineer
I had an epiphany recently.
My company documented and implemented an ISO 9001:2008 compliant Quality Management System on a wiki.
The epiphany part is the realization of how incredibly, amazingly, unbelievably useful the wiki is to complete this process. In fact, it is so useful that I now feel this urge to evangelize. Hence my contribution here.
If one of you finds this half as useful as we did at Geometrica, my work is done. :)
Cheers!
Pancho
Le Chiffre
Re: Using a wiki to implement a QMS
I'm glad to see someone else using a wiki for this task. We started using one for our QMS 3 years ago and it's been through ISO 9001 and ISO 13485 audits. We've reached almost 3,000 pages but the wiki is now used for every aspect of the business.
You have to be careful to identify "controlled" records and to show the approval state of some articles, alerting the reader if the article has changed since being reviewed - it may be in a state of flux during an edit when someone else takes instruction from it.
Stijloor
Where can a "rookie wiki" user find additional information?
Thanks.
Stijloor.
Pancho
wikineer
Thanks.
Stijloor.
The term "wiki" has several related meanings. One is the website where information can be read and edited. A second is the body of information and cross-links. A third is the software that runs it. To differentiate, I sometimes call the first a "wiki space", the second the "wiki content" and the last the "wiki engine".
A wiki engine or space are not, by themselves, compliant or not with ISO 9001 or any other standard. The wiki content, as the body of documentation, of your implementation may be. And your organization gets to write it.
Wiki engines are many. The most popular is MediaWiki. At Geometrica we used ProjectForum and found it very straightforward to install and use, which was a great advantage when we got started. (Neither I nor anyone at Geometrica is affiliated to ProjectForum in any way).
One of the first realizations that we came to was that hot-links are incredibly useful. Our wiki home page, very early on, became a list of links to pages of indices of documents organized by processes and functions (i.e. Sales, Engineering, Procurement, Manufacturing, Construction, etc.).
As we built the wiki content, we started to "include" on every document the index of docs of their corresponding or closest area (process or function). By "included" I mean that the page of indices is displayed on the document itself, but as a side bar. This way, anyone browsing, say, an engineering document has immediate access to all other engineering documents. We also "included" links to every area in a top navigation bar, so that anyone can jump from area to area very quickly.
To get started, I'd recommend that you download one of the many free wiki engines and play with it. Once you get it installed, you may, for example upload to the wiki the documents for one of your company's processes as initial content. Hotlink the heck out of this new content and let their users loose on them. If you have the authority, compell them initially to use the wiki for changes to the documents. With a little luck, one by one they will come around (this is probably the hardest part). After some 3 or 4 do, you will start to see some "wiki magic". And you are off.
Good luck!
Le Chiffre
That's good advice, there really is no better way to learn than to try it for yourself. Familiarity with other Wikis is helpful, even Wikipedia. I found the concept of articles and categories to be the most misunderstood. Some Wikis have few categories and hundreds of articles (like the *cough* Elsmar Cove Wiki *cough*), whereas others create content in categories that are otherwise empty of articles.
The meat of the Wiki should be made up of articles. Generally, information should be written in articles and not categories. These are organized by being included in categories. Create a category if you intend it to contain multiple instances of similar articles (e.g. "Test cases"). Each article should be included in at least one category, but don't get carried away. Include your new article in the most appropriate (or immediate) category and allow that category to make it a member of other broader categories.
Pancho
wikineer
Generally, information should be written in articles and not categories. Each article should be included in at least one category, but don't get carried away. Include your new article in the most appropriate (or immediate) category and allow that category to make it a member of other broader categories.
Agree, Le Chiffre. We gave up on Categories and substituted them with "wiki gnoming" to write up navigation indices. Its a bit more work, but in our experience categories were always so jumbled that they were useless.
BTW, in your opinion, why is the Cove's wiki not used much?
Le Chiffre
Primarily because these forums are so comprehensive and convenient. Assuming people come here in search of a solution to a problem, the forums offer a search utility to check for an existing similar question or they post a new one and generally get a fairly good response within 24hrs.
I think the wiki vs. forum debate has happened here before but I believe people are more inclined to post individual opinions, however incomplete rather than collaborate on a complete and definitive answer.
Scott Catron
True Artisan
The wiki started as an alternative to the Definitions, Acronyms, Abbreviations and Interpretations forum. The initial content was from Bill Pflanz's General Quality Assurance Glossary and grew from there. There are only a handful of Covers that learned wiki mark-up, so after the initial coding of the the glossary (done my Marc and myself on a previous version of the wiki), not much more has been done.
It's probably easier to find a quick definition of a term on the wiki, but if one wants to read interpretations and discussion, that is better served by the forums.
