The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > Document Control Systems, Procedures, Forms and Templates
Frozen/Fixed Process Procedures - Requirements from our Customers
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
International Standards Organization - ISO Standards and Information
Some Related Topic Tags (Not all threads are Tagged)
customer requirements, document control, procedures (general), process requirements
  Post Number #1
Old 24th June 2009, 09:54 AM
Rick Hart
Please Help! Frozen/Fixed Process Procedures - Requirements from our Customers
Hello All,
I need to implement a procedure that will detail the Frozen Process requirements from our Customers. I am really struggling on how I want to word this document.
Does anyone out there have a sample procedure they care to share?
I really appreciate the help!!
Thanks to Rick Hart for your informative Post and/or Attachment!
  Post Number #2
Old 24th June 2009, 10:07 AM
Jim Wynne's Avatar
Jim Wynne
Re: Frozen/Fixed Process Procedures
Are you referring to a frozen design, wherein a customer assures you that a new product design is stable and you can proceed with production?
Thanks to Jim Wynne for your informative Post and/or Attachment!
  Post Number #3
Old 24th June 2009, 12:02 PM
alspread's Avatar
alspread
Re: Frozen/Fixed Process Procedures - Requirements from our Customers
I wove the following into my 7.5 procedure. I also made work instruction for each of our own special processes.
This covers more than just frozen processes. This whole section (along with other stuff) will be part of section 7.5.2 in the new AS9100C
Good luck
3.6. Special processes WI 07-05-24 Welding, WI 07-05-25 EDM, WI 07-05-23 Etching, WI 07-05-22 Hole making process GE-P11TF12, WI 07-05-26 Induction Heat Treat
3.6.1. Significant process definition: A significant process is a sequence of operations (special or ordinary) that if changed could affect design intent; might affect material structure, mechanical, chemical or electrical properties; and cannot normally be evaluated without destructive testing.
3.6.1.1. Significant processes are designated by customer requirements. Significant process is sometime referred to as: VSE Process, Fixed Process, Frozen Process, EDI 1306 Process, etc.
3.6.1.2. Validation (or qualification) and changes or variations to such a process are handled in accordance with each customer requirements.
3.6.1.3. A Significant process may or may not include Special operations/processes.
3.6.1.4. Quality Control is responsible for submittal of initial and final qualifying documentation (FAI) for significant processes to the customer, for approval.
3.6.1.5. After initial approval of the special process by the customer, the significant process section(s) is/are "frozen" as defined by the customer requirement.
3.6.1.6. The routing sheet shall state: "This Manufacturing plan contains significant process/operations that may require customer approval for changes. Refer to customer specification for change approval requirement."
3.6.1.7. Significant process approval documentation will be maintained in the First Article package for the individual part number.
3.6.2. Significant Operation definition: A single operation which modifies or changes the inherent physical, chemical, electrical or metallurgical properties of an item, or non-conventional methods which remove or deposit material on a item during or after fabrication which can not be fully evaluated by non-destructive means, or those used to maintain process control such as non-destructive testing. This type of process may require a demonstration of operator or equipment capability or proficiency and require special controls for monitoring per specification. Means for compliance are contained in individual specifications. Typical processes/ operations are listed in customer's approved lists.
3.6.2.1. Special operations typically require a detailed technical plan. The special operation results are typically analyzed by an independent 3rd party (laboratory) and evaluated or approved by the customer.
3.6.2.2. This special operation evaluation and approval can usually employ a representative coupon or sample of the special operation performed if sample analysis would destroy the part.
3.6.2.3. Validation (or qualification), changes or variations to a significant operation are handled in accordance with each customer requirements.
3.6.2.4. Special operation approval documentation will be maintained in the First Article package for the individual part number.
3.6.2.5. Quality engineering is responsible for submittal of initial and final qualifying documentation for special operations to the customer, for approval.
3.6.2.6. Manufacturing engineering and Quality engineering will assure that the manufacturing operation sheets for the special operations are stamped with "This Manufacturing plan contains significant process/operations that may require customer approval for changes. Refer to customer specification for change approval requirement."
3.6.2.7. Manufacturing & Quality engineering are responsible for designating the initial source for each special operation on the routing sheet and identifying the operation as special by placing an "S" in the appropriate block on the routing sheet next to the operation.
3.6.2.8. Manufacturing & Quality engineering, Production control and Quality control are responsible for assuring that only customer-approved sources are utilized for material and all significant operations.
3.6.2.9. The following list is a guide as to what may be considered special operations/process. Final establishment for each individual part or operation shall be done by taking into account function, geometry, location of the operation in the manufacturing process, material, etc
· Forging
· Casting
· Isostatic pressing
· Chemical cleaning
· Mechanical cleaning (blasting, barreling, etc.)
· Welding
· Brazing
· Soldering
· Thermal spray
· Heat treatment and Surface hardening
· Shot Peening
· ECM
· EDM
· Laser machining
· Electroplating
· Painting
· Adhesive bonding
· Corrosion protection
· Grinding to final form and dimension
· Forming (tool inspection, lubrication, stress relieve, etc.)
· Cold forming (bending, straightening, etc. after final heat treatment, shot peening, welding, brazing, plaiting)
· Etching, Etch inspection
· Magnetic particle inspection
· Penetrant inspection
· Radiographic inspection
· Ultrasonic inspection
· Eddy current inspection
· Operation sequence (heat treatment, plating, shot peening, NDT, marking transfer, final inspection, etc.)
3.6.3. Changes to significant operations/processes, unless otherwise specified by the customer, dual sourcing of significant operations will be done whenever practical. After initial approval is granted, should it be desirable to change the significant process, source, sequence, or other requirements, customer approval will be obtained prior to initiating the change.
3.6.3.1. “THE COMPANY” is responsible for the performance and or verification of the qualification, validation and control of special processes, regardless if they are performed within the company or subcontracted.
3.6.3.2. The following special processes are performed at “TH COMPANY”.:
· Welding WI 07-05-24
· Electrical Discharge Machining (EDM) WI 07-05-25
· Etching, Etch inspection WI 07-05-23
· Induction heat treat WI 07-05-26
Thank You to alspread for your informative Post and/or Attachment!
  Post Number #4
Old 11th July 2017, 02:17 PM
Sandy Simpson's Avatar
Sandy Simpson
Very impressive!
MSA on Process Instruments (Voltmeters, Ammeters Fixed on Machine) bkarthikeyan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13 6th March 2014 06:35 AM
No Process Defined to Capture the Special Requirements of Customers Saifuddinkhan Problem Solving, Root Cause Fault and Failure Analysis 5 22nd March 2011 06:10 AM
What if the Customers Insist on Service that Breaks the Established Procedures? StMichael Service Industry Specific Topics 19 7th January 2011 09:51 PM
Training Matrix Requirements - ESA & Internal Frozen Process Control Joeem Various Other Specifications, Standards, and related Requirements 3 3rd September 2010 01:46 PM
New Requirements for Fixed Machine Guarding - Fasteners JerryV CE Marking (Conformité Européene) / CB Scheme 1 7th September 2009 10:49 PM
The time now is 10:29 AM. All times are GMT -4.
