Elsmar Cove Quality Discussions510(k) Raw Data from Studies - 21 CFR Part 11 ComplianceThe Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Some Related Topic Tags
21 cfr part 11 - electronic records and signatures, 510(k)
  Post Number #1
Old 6th October 2017, 03:55 AM
invitro_spain's Avatar
invitro_spain
Question 510(k) Raw Data from Studies - 21 CFR Part 11 Compliance
Hi Folks,
I need help for this easy or not so easy question. During the premarket submission for a device Class II-Moderate risk, you have to include a summary of your bench studies and raw data (for example, spreadsheets with the data from your studies).
In this case, Should these spreadsheets comply with the 21 CFR Part 11?
Could you advise me about the most suitable way to comply with this regulation?
Thank you in advance
  Post Number #2
Old 7th October 2017, 12:31 PM
yodon
re: 510(k) Raw Data from Studies - 21 CFR Part 11 Compliance
If the spreadsheet is maintained as an electronic record or if you applied a signature electronically as required by predicate rule then yes!
Further, a spreadsheet application should also be validated for its intended use. If the spreadsheet is not validated then the data collected COULD be called into question.
A lot will depend on your inspector. The "enforcement discretion" can be anywhere in the spectrum. One option is to make a snapshot of the spreadsheet (PDF) and control that as the record. (There's still potentially a Part 11 concern but it's greatly reduced since alteration would be much more difficult. And the validation concern still exists, too.)
Thank You to yodon for your informative Post and/or Attachment!
  Post Number #3
Old 10th October 2017, 11:33 AM
invitro_spain
Re: 510(k) Raw Data from Studies - 21 CFR Part 11 Compliance
In Reply to Parent Post by yodon View Post
Thank you yodon. Sorry for the delay in replying. During the submission, you have to submit a hard copy and a electronic copy of your 510(k) using "esubmitter". I suppose if you upload a spreadsheet to this application you may obtain a pdf controlled version of your initial spreadsheet. Anyway, you can include a hard copy version signed in paper with your 510(k). Would be this methodology correct?
  Post Number #4
Old 11th October 2017, 09:45 AM
yodon
I've definitely seen the PDF approach used.
Thanks to yodon for your informative Post and/or Attachment!
  Post Number #5
Old 11th October 2017, 07:51 PM
Mark Meer
In Reply to Parent Post by invitro_spain View Post
...I suppose if you upload a spreadsheet to this application you may obtain a pdf controlled version of your initial spreadsheet. Anyway, you can include a hard copy version signed in paper with your 510(k). Would be this methodology correct?
We use this method - spreadsheets, once finalized, are exported to PDF, and then signed. Alternatively, the exported data is attached to a test-report as an appendix, and it is the report that is ultimately signed and controlled.
This should be done at the time the data is done (record closed). The original spreadsheet can be maintained/archived, but as far as your records go, the signed PDF of the data is the "official" record.
Signatures are intended to attest to some activity (e.g. review, approval..) at the time of the activity. So, exporting a PDF and signing it long after the spreadsheet was originally finalized, just for the purposes of Part 11, and a 510(k), may be called into question.
Alternatively what you can do is to collect required signatures elsewhere (e.g. via a separate approvals form). In such case, all you have to do is:
1. Make sure that the dates on the signatures form are after the last modification date of the spreadsheet.
2. The spreadsheet is protected somehow from modification (or, at least, a way to identify modification - e.g. via timestamps, version control), after the necessary signatures have been collected.
Thanks to Mark Meer for your informative Post and/or Attachment!
Data Quality and Data Integrity - Audit Trail - Part 11 - WHO - FDA - MHRA - PDA v9991 US Food and Drug Administration (FDA) 6 7th August 2017 07:46 AM
Original Data Copying to Maintain Compliance with 21 CFR Part 820.180 greenfish US Food and Drug Administration (FDA) 2 9th February 2013 01:51 AM
Capability Studies: Can I combine Attribute Data and Variables Data Oloriko Capability, Accuracy and Stability - Processes, Machines, etc. 2 17th September 2010 04:10 AM
Does every PMA part have to have an 8130 form? Or compliance with part 21.303? Corsair Federal Aviation Administration (FAA) Standards and Requirements 4 3rd January 2009 10:15 PM
Gage R&R Studies for Attribute Data? Antonio Vieira Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7 12th October 2006 12:49 PM
The time now is 07:50 PM. All times are GMT -4.
Misc. Internal Links
