The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > National and International Business System Standards > Other ISO and International Standards and European Regulations
Forum Username
Wooden Line
ISO Class 7 Clean Rooms - built as Class 8 but complies with requirements of Class 7
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
Quality Digest
Some Related Topic Tags (Not all threads are Tagged)
cleanroom classification, cleanrooms, iso 14644 - cleanrooms and controlled environments, particle counts
Reply
  Post Number #1
Old 1st November 2011, 08:03 AM
SGquality
Thank You! ISO Class 7 Clean Rooms - built as Class 8 but complies with requirements of Class 7
I have a question on the ISO Class 7 clean rooms.
When do perform particle counts of the clean rooms, it complies as per the requirements of ISO Class 7 (10,000) consistently as defined per ISO 14644 standard.
Is this requirement okay to label the clean room as per ISO Class 7 ? My question is specifically because when we built the clean room, it was to comply per ISO Class 8 clean rooms (100,000) but since the particle counts are met per Class 7 areas, our Management label it as ISO Class 7 area.
Is this acceptable ? Or is there anything that needs to be carried out seperately per ISO Class 7 ?
Thanks in advance
Sponsored Links
  Post Number #2
Old 2nd November 2011, 01:39 AM
Stijloor's Avatar
Stijloor
Re: ISO Class 7 Clean Rooms - built as Class 8 but complies with requirements of Clas
In Reply to Parent Post by SGquality View Post
Is this acceptable ? Or is there anything that needs to be carried out separately per ISO Class 7 ?
Thanks in advance
Can someone help?
Thank you very much!!
Stijloor.
Sponsored Links
  Post Number #3
Old 2nd November 2011, 03:53 AM
harry
...................when we built the clean room, it was to comply per ISO Class 8 clean rooms (100,000) but since the particle counts are met per Class 7 areas, our Management label it as ISO Class 7 area. .........................
Amazing! Unless somebody replaced the filters. Otherwise, my first suspicion will be on how the particles counts were measured. Did you get an independent lab to verify it?
  Post Number #4
Old 2nd November 2011, 04:12 AM
somashekar's Avatar
somashekar
Thanks in advance
The other way could happen, but from what you say, I would take an other validation run with workload situation to reassess if indeed it meets the class 7 consistently.
To maintain class 7 the man and material control could be a lot different, and you must consider this.
If I were you, I would apply caution and wait for repeated validation over time.
  Post Number #5
Old 2nd November 2011, 04:55 AM
Kwesifaiola
Hello
Thanks for provide me information about ISO standards class because this will help me.
Regards
Kwesifaiola
  Post Number #6
Old 3rd November 2011, 12:52 AM
SGquality
In Reply to Parent Post by harry View Post
Yes harry - all the particulates are measured by an external laboratory and there is no doubt on measurements. In fact the limits for particulate counts are so huge that most ISO Class 8 clean rooms areas would be acceptable at the higher classification too as the particle counts are low.
In Reply to Parent Post by somashekar View Post
Thanks somashekhar. That was my precise question. What would be different in these 2 areas ?
  Post Number #7
Old 5th November 2011, 01:19 AM
SGquality
Question Re: ISO Class 7 Clean Rooms - built as Class 8 but complies with requirements of Clas
Pls help
  Post Number #8
Old 5th November 2011, 02:41 AM
somashekar's Avatar
somashekar
Pls help
Not knowing your product that you handle in the clean room, it is not too easy to suggest. However the selction of the clean room class and the processes performed thereafter as against requirement is a matter of risk assessment and supported by valid product testing.
Calling out your clean room as Class 7 and yourself is far less important than claiming meeting or exceeding class 8 and supporting the same with periodic validation and product test reports meeting to requirements.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
Clean Room Cost per sq foot is to have a class 100,000 clean room built erniel Manufacturing and Related Processes 3 24th March 2015 06:26 PM
Electrical Class (Class I, II & III) vs. Medical Device CE marking Class I, II & III LuckyK ISO 13485:2016 - Medical Device Quality Management Systems 3 6th January 2015 12:43 PM
Do I need to test "as built" for an expanded ISO Class 8 Clean Room ? dcvanderbush Other Medical Device Related Standards 2 2nd April 2014 03:01 PM
The requirements of an ISO 14644 Class 8 Clean Room SK Vision Manufacturing and Related Processes 1 17th July 2009 09:17 AM
Percentage of Class I Medical Devices in market - viz Class I, Class II and Class III Ajit Basrur ISO 13485:2016 - Medical Device Quality Management Systems 8 25th February 2008 04:44 AM
The time now is 05:16 PM. All times are GMT -4.
NOTE: This forum uses "Cookies"
