The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Using Minitab Software
Forum Username
Wooden Line
Sample format for Equivalency Protocol /Report
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
Quality Digest
Some Related Topic Tags (Not all threads are Tagged)
equivalency protocol
Reply
  Post Number #1
Old 20th May 2014, 03:31 AM
kuyakut
Thank You! Sample format for Equivalency Protocol /Report
Does any one here have some sample for an Equivalency Test Protocol or Report.
My main problem is what would be my acceptance criteria to for the equivalency and 2Sample T test .
Thank you in advance.\
Sponsored Links
  Post Number #2
Old 2nd June 2014, 06:47 AM
Stijloor's Avatar
Stijloor
Re: Sample format for Equivalency Protocol /Report
A Quick Bump!
Can someone help?
Thank you very much!!
Sponsored Links
  Post Number #3
Old 2nd June 2014, 12:47 PM
Bev D's Avatar
you must provide the criteria for equivalency. what level of difference is small enough for you to consider 'equivalent'? What risk are you will to take (alhpa and beta risks).
Then if the p value for the 2 sample test is greater than the critical value your two methods are 'statistically not diiferent'
if you provide us a bit more information on what you are trying to do, we can provide more specific advice.
if this is just a 'how do I do this in Minitab' question, I will defer to the many minitab experts on this site.
Thanks to Bev D for your informative Post and/or Attachment!
  Post Number #4
Old 4th June 2014, 08:46 AM
kuyakut
Hi Bev,
I've done a 2 Sample T test and equal Variance.
And the result are attached below
Two-Sample T-Test and CI: TitanPro 6331, Basell PP 592
Two-sample T for TitanPro 6331 vs Basell PP 592
N Mean StDev SE Mean
TitanPro 6331 720 0.411736 0.000190 0.0000071
Basell PP 592 720 0.411273 0.000474 0.000018
Difference = mu (TitanPro 6331) - mu (Basell PP 592)
Estimate for difference: 0.000463
95% upper bound for difference: 0.000494
T-Test of difference = 0.0004 (vs <): T-Value = 3.30 P-Value = 0.999 DF = 943
Test for Equal Variances: Dim ID 0.412 versus Material
95% Bonferroni confidence intervals for standard deviations
Material N Lower StDev Upper
Basell PP 592 720 0.0004476 0.0004742 0.0005039
TitanPro 6331 720 0.0001792 0.0001898 0.0002016
F-Test (Normal Distribution)
Test statistic = 6.24, p-value = 0.000
Levene's Test (Any Continuous Distribution)
Test statistic = 7.73, p-value = 0.006
The 2 Sample T test and equal variance fails but if i compare the Cpk , the new material has a higher cpk value. So my question is , to be able to pass the 2 Sample T test , it must be always equal to or lesser than T test difference. For equal variance to pass P value must be always above 0.05.
  Post Number #5
Old 4th June 2014, 01:23 PM
Bev D's Avatar
as always, the statistical output table is meaningless unless we understand the nature of the test itself.
Cpk is a test of the location and dispersion of the individuals values vs the tolerances.
a two sample t-test will only tell you if the means are statistically significantly different or not. It won't tell you if the difference is practically large or small.
a homogeneity of variance will only tell if the differnce in variance is statistically significantly different
In order to answer your real questions, can you post:
  • your raw data for the two samples
  • tell what you are measuring - what characteristic?
  • what is a Bassel and a TitanPro? are they different materials?, processes?, equipment? measurement devices?
  Post Number #6
Old 4th June 2014, 08:39 PM
kuyakut
In Reply to Parent Post by Bev D View Post
Hi Bev ,
Here it is,
  • your raw data for the two samples - see attached fle
  • tell what you are measuring - what characteristic? I'm measuring the CTQ
  • what is a Bassel and a TitanPro? are they different materials?, processes?, equipment? measurement devices?They are 2 different material that was process at the same day with the same parameters at the same machine.
  • I am comparing the 2 materials to make sure which ever I used have the same or almost same product dimensional result. It was measured with the same measurement equipment , MSA already done.
Specs is 0.412 = 0.002 /-0.002, T test difference = 10 % of the tolerance band or lesser (0.0004)
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
Can anyone provide an example of Design Validation Protocol and Report? SGquality 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2 9th January 2015 09:23 AM
Format for Discrepant Material Report (DMR) - Nonconformance Report (NCR) biju-joseph Document Control Systems, Procedures, Forms and Templates 1 6th March 2012 12:42 AM
8D Report format and the best and most effective method of report preparation Chandradhar Shukla - 2009 Nonconformance and Corrective Action 1 25th November 2009 04:56 AM
Should the Protocol and Report be signed by the same person(s)? Ajit Basrur Qualification and Validation (including 21 CFR Part 11) 7 19th July 2009 12:18 AM
Quality Audit Report - Report Format and some Formal Sentences abnoyan General Auditing Discussions 22 29th May 2002 09:48 AM
The time now is 02:12 AM. All times are GMT -4.
NOTE: This forum uses "Cookies" - A Peachfarm Internet Property
