The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Elsmar Cove Forum Community Forums > Community Discussion Topics > Funny Stuff - Jokes and Humour
Forum Username
Wooden Line
Who says you can't calibrate a steel rule!
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
Quality Digest
Some Related Topic Tags (Not all threads are Tagged)
steel rulers & tape measures
Reply
  Post Number #1
Old 8th June 2014, 02:03 AM
bobdoering's Avatar
bobdoering
I Say... Who says you can't calibrate a steel rule!
Ponder this quality meme!
Thank You to bobdoering for your informative Post and/or Attachment!
Sponsored Links
  Post Number #2
Old 8th June 2014, 09:05 PM
Wes Bucey's Avatar
Wes Bucey
Re: Who says you can't calibrate a steel rule!
Channeling Clinton:
It depends on what your definition of "calibrate" is.
mark (a gauge or instrument) with a standard scale of readings.
  • correlate the readings of (an instrument) with those of a standard in order to check the instrument's accuracy.
  • adjust (experimental results) to take external factors into account or to allow comparison with other data.
Does ALL calibration require adjustment? Or can "some" calibration merely be a process of affirming or denying whether the instrument is within its stated tolerances? Perhaps something as simple as saying this is no longer meeting one tolerance class, but may meet a lesser class of tolerances. Here's an example of thread tolerances to get an idea that a gage, for instance, "could" gradually move down in class as it wears.
Tolerance classes
A classification system exists for ease of manufacture and interchangeability of fabricated threaded items. Most (but certainly not all) threaded items are made to a classification standard called the Unified Screw Thread Standard Series. This system is analogous to the fits used with assembled parts.
Classes 1A, 2A, 3A apply to external threads; Classes 1B, 2B, 3B apply to internal threads.
Class 1 threads are loosely fitting threads intended for ease of assembly or use in a dirty environment.
Class 2 threads are the most common. They are designed to maximize strength considering typical machine shop capability and machine practice.
Class 3 threads are used for closer tolerances.
Thread class refers to the acceptable range of pitch diameter for any given thread. The pitch diameter is indicated as Dp in the figure shown above. There are several methods that are used to measure the pitch diameter. The most common method used in production is by way of a Go/no go gauge.
Thanks to Wes Bucey for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 8th June 2014, 09:13 PM
bobdoering's Avatar
bobdoering
My definition of calibrate is very simple: Verify a measurement system against a standard to assure its accuracy.
Adjustment is not calibration, only an option to react to an out of calibration condition. If you can adjust, fine - do so. If not, pitch it or "reclassify" it.
Gotta love definitions. When its all said and done, they are not very definitive.
  Post Number #4
Old 9th June 2014, 07:56 AM
David-D
I think advocating for not calibrating really misses the critical point on what that calibration is buying you. It is providing book-ends in the measurements made between those calibration points, and thus the acceptance and rejection decisions, were accurate. I'm always scheptical of when organizations buy a new, calibrated gage and then rather than get it calibrated, they dispose of it and buy a new one. I understand that is often cheaper (ex. Set of pin gages) but there isn't any closure on the gages.
David
  Post Number #5
Old 9th June 2014, 08:46 AM
AndyN's Avatar
AndyN
Read This! Re: Who says you can't calibrate a steel rule!
I don't think the thread is about advocating for/against calibration. It's more a case of whether a steel rule SHOULD be calibrated compared to simply being verified. Knowing how far "off" a steel rule is, for most uses isn't really necessary and it's likely not the right tool, if you do need to know.
  Post Number #6
Old 9th June 2014, 09:36 AM
BradM's Avatar
BradM
You can calibrate gauge blocks. You just have to have the right tools.
Thank You to BradM for your informative Post and/or Attachment!
  Post Number #7
Old 9th June 2014, 11:13 AM
Steve Prevette's Avatar
Steve Prevette
In my past life with a calibration program, we would have referred to the test on the steel rule as a "calibration check".
Generally, if a steel rule were to fail its cal check, the only remedy is to dispose of it and buy a new one, I would suppose, unless there were a special case like I could sand some off the end . . .
  Post Number #8
Old 9th June 2014, 12:31 PM
Marc's Avatar
Marc
I Say... Re: Who says you can't calibrate a steel rule!
In Reply to Parent Post by BradM View Post
Yeah, but only if the block has "grown" which will not help because wear is usually the problem to begin with. Of course one could make a "new" smaller gage block.
With regard to the thread topic this is along the lines of "calibration" of a glass bulb thermometer. There is nothing to "adjust".
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
To Calibrate or Not to Calibrate various Weight Scales michaelkhart ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24 18th October 2010 05:54 PM
Tape Measure Verification - Starrett 72" certified steel rule Jessic2952 General Measurement Device and Calibration Topics 16 18th April 2008 08:56 AM
Calibration of steel rulers - Why do I need to calibrate it again? amanbhai General Measurement Device and Calibration Topics 12 6th April 2006 04:36 AM
Calibration Cycle: Calibrate When Issued OR Calibrate by Due Date? Russ General Measurement Device and Calibration Topics 7 29th January 2002 02:55 PM
Calibration - What do we need to calibrate and what don't we need to calibrate? Dan De Yarman QS-9000 - American Automotive Manufacturers Standard 4 7th October 1999 09:08 PM
The time now is 08:17 PM. All times are GMT -4.
NOTE: This forum uses "Cookies" - A Peachfarm Internet Property
