How to document "Exclusions" in the Quality Manual
SpaceCase
We have excluded Section 7.3 ? Design and Development, what do I do with that section of our quality manual (we have downloaded the quickstart total package from the AS9100store.com)?
We have excluded it with this statement in the Application section (1.2):
? Justification of exclusion: products are built to Customer specifications and drawings.
As we only build-to-print and do not have any Design or Engineering Depts.
Do I just delete the section and just write in that we have excluded it and only build-to-print?
Thanks!
the47guy
Re: Exclusions question.
In our Quality Manual, we just put:
7.3 Design and Development
EXCLUDED – (See section 1.2)
SpaceCase
That's what I figured, but didn't want to File 13 the whole section if that wasn't the correct way to go.
Thank you!
AndyN
Moved On
You are missing the justifications - which is a requirement! You can't simply say "excluded" because - in particular with design - some folks try to exclude it because Engineering "didn't want to be part of ISO" (as they say). Or to save money on certification!
You should have a justification: "We are a make to print shop and our customers own the designs" for example.
SpaceCase
Yes, this is what I have there:
▪ Section 7.3 – Design and Development
• Justification of exclusion: products are built to Customer specifications and drawings.
the47guy
The justification is in 1.2 (Justifications) of the Quality Manual. That's why we put see 1.2.
SpaceCase
Here is section 1.2:
1.2 Application
The Company has determined that the following requirements are not applicable to the operations at this site and are documented as exclusions:
And 7.3:
EXCLUDED – See section 1.2.
SpaceCase
Re: How to document "Exclusions" in the Quality Manual ?
I kinda figured, thanks for making sure I'm on the straight and narrow!
dsanabria
1.2 Application
▪ Section 7.3 ? Design and Development
And 7.3:
EXCLUDED ? See section 1.2.
Nice!:applause:
