The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > General Metrology, Measurement Device, Calibration and Test Laboratories > Gage R&R (GR&R) and MSA (Measurement Systems Analysis)
Forum Username
Wooden Line
How to interpret Grindometer Gage R&R Results
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
Quality Digest
Some Related Topic Tags (Not all threads are Tagged)
gage r&r (repeatability and reproducibility), measurement systems, msa (measurement system analysis), painted surfaces
Reply
  Post Number #1
Old 13th February 2017, 09:45 PM
BKunrath
Question How to interpret Grindometer Gage R&R Results
Hello all,
I'd like to know if anyone could tell me if my interpretation is correct.
Usually I work with calibration processes, but Iím pursuing new fields of knowledge, so I just did my first MSA study.
But Iím still trying to undestand what the results means.
The study is about our paint fineness of grind evaluation method (itís measured with a grindometer).
I got these numbers based on the tolerance (the idea of the study is to measure if my QC lab is capable of identifying out of spec batches)
%VE 36,9%
%VA 19,8%
%R&R 41,9%
%VP 60,5%
Ndc = 5
Both R and X charts are under control.
Does the %R&R = 42% mean that 42% of 1/6 of the specification is due to the variance of the measument system alone?
So if my production were somehow able to make equal batches everytime, Iíd still find results spread over 42/6 = 7% of my specification? Is that it?
A higher %VE could mean that there is a equipment problem. The usual grindometer could be replaced by another model with better resolution. That might lower the amplitude of the readings performed by the same operator of the same sample.
Any help would be appreciated and sorry if I wasn't clear enough.
I attached the (very crude and poorly translated) original data if needed.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
Sponsored Links
  Post Number #2
Old 14th February 2017, 08:55 AM
Miner's Avatar
Look! Re: How to interpret Grindometer Gage R&R Results
The first thing I would recommend is that you validate this R&R template. I checked these results against a validated template and obtain somewhat different values. Given that, the first issue that you should address is the measurement resolution. A resolution of 0,5 is inadequate. You can assess this by evaluating the range chart. There needs to be a minimum of 5 distinct possible measurement between zero and the UCL_R of the range chart. This gage has only 3. A resolution of 0,1 should be adequate.
Sponsored Links
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
Gage Bias and Linearity - How to interpret the Minitab results TheCableGuy1 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6 5th March 2013 07:06 PM
Please help me interpret my GR&R results tommyd327 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2 18th August 2011 02:43 AM
Gage R&R - How to interpret results? Fugazy5 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5 22nd October 2010 01:23 PM
Could someone tell me what are the results of a Gage R&R & how to interpret it? snowman6705 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7 31st May 2009 12:31 PM
Gage R&R - How do I interpret the %PV & %TV results? KMAAA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9 21st April 2004 06:44 PM
The time now is 03:55 PM. All times are GMT -4.
NOTE: This forum uses "Cookies" - A Peachfarm Internet Property
