The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Manufacturing, Service, and Business Systems Processes > Service Industry Specific Topics
Forum Username
Wooden Line
Outsourced Plating Supplier Responsibilities
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
Quality Digest
Some Related Topic Tags (Not all threads are Tagged)
outsourced products and processes, plating & coatings
Reply
  Post Number #1
Old 7th April 2017, 07:32 AM
Russ's Avatar
Russ
Please Help! Outsourced Plating Supplier Responsibilities
We recently had some parts E-Nickel plated by a somewhat new supplier. Part of these parts had to be masked prior to plating. It seems that the supplier did not see the need to oil these parts after processing and removing the masking so the unplated section of the parts rusted before we got them back and unboxed them. I cost us over 6 hours rework time to fix these parts. The supplier tells me we should have "told them" to oil them if we wanted that done. I said it only makes common sense to oil a part after doing this to prevent it from rusting. Could I please have everyone's input on this?
Sponsored Links
  Post Number #2
Old 7th April 2017, 08:01 AM
Ron Rompen's Avatar
Ron Rompen
Re: Outsourced Plating Supplier Responsibilities
Although it is only 'common sense' to oil or otherwise coat an exposed surface, I have to agree with your supplier on this. If you didn't specify that you wanted it done, then they are not under any obligation to do it. Any added processes add costs, and if they didn't quote it, then they are (understandably) reluctant to do it for free.
Thank You to Ron Rompen for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Mike S.
We have had this happen. In reality, IMO you’re both responsible.
So for the future I would clearly state – at a minimum for every product you buy – that the product needs to be adequately protected from rust, corrosion, oxidation, deterioration, damage, whatever, before shipment.
If you want them to use a specific method, especially if some of this stuff may sit in inventory for a while, clearly state the method you want used. This is the safest bet.
Thank You to Mike S. for your informative Post and/or Attachment!
  Post Number #4
Old 7th April 2017, 10:05 AM
Russ's Avatar
Russ
I see where I may have been amiss. So if I were to add a note to the PO about oiling to prevent rust I would like to do it using a general note that would appear on every PO so that we are covered on all PO's sent out.
Something like: "Prior to parts being returned to [our company], they should be treated to prevent rust or corrosion when failure to do so could result in either of these situations developing."
Any ideas on this approach?
  Post Number #5
Old 7th April 2017, 02:09 PM
Mike S.
Whatever works for your system...we have a series of PO codes we apply when needed. A text note on the PO would work.
  Post Number #6
Old 20th April 2017, 06:10 PM
Wes Bucey's Avatar
Wes Bucey
My weigh-in echos the others - SPECIFY EXACTLY WHAT YOU WANT/NEED!
I can think of a number of scenarios where I would NOT want any rustproofing chemicals added to parts after unmasking. I would be damn specific about how and with what the masking was applied and how and with what it was removed.
Just curious: by "E-Nickel" did you mean "electroplated" or "electroless"? My preference was always for electroless - no dogboning, with uniform deposition on EVERY exposed surface.
Thanks to Wes Bucey for your informative Post and/or Attachment!
  Post Number #7
Old 21st April 2017, 11:36 AM
normzone
In Reply to Parent Post by Russ View Post
Methods vary - here's the risks I've experienced.
The P.O. will likely not be in the hands of the guy doing the work. He'll either have a copy of your drawing, or a customized work document created by his planning department. YMMV - depending on how sophisticated the outfit is. So whether or not the note on the P.O. is followed depends on your supplier's setup.
Putting the callout on a master document that only contains callouts and explanations of them works fine - when your customer has that document and follows it, when the guy in the shop gets that information reliably and understands it, and there's not a guy substituting for him while he's on vacation. And when your engineer uses it and keeps it up to date forever - when engineering department practices evolve (or devolve, I've seen both) then that doc may get obsoleted and nobody knows what the hell that code means or where the old document is.
Your best choice depends on your situation - size of your company and supplier, stability of the staff. My preference is every drawing contains the full requirement. All the buyer has to do is drop the note from his template, or pull a different template and your communication is over.
Also, correspond with your supplier and ask them what works best for them. They may need it the way you want to do it, or they may be in a completely different world when it comes to how they perceive what is best practice.
Been there, done that - word to the wise and all that.
Thank You to normzone for your informative Post and/or Attachment!
  Post Number #8
Old 21st April 2017, 03:04 PM
Wes Bucey's Avatar
Wes Bucey
Norm has nailed it! COMMUNICATE! I never met a psychic supplier who could read my mind, so I had to tell him, confirmed in writing, and sometimes had to add photos, cartoons, and physical samples to get my point across. There's an old adage:
Never "assume." Broken down into its basic components, you get an
A S S U M E
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
Plating Shop - Forums specifically related to the plating / metal finishing industry Brite ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3 2nd May 2014 12:39 PM
We put Old plating spec on supplier prints and need to PPAP to Customer. vardar3 APQP and PPAP 1 5th April 2012 10:17 AM
Supplier's First Run had Plating Problems - Can they Strip, Re-Plate and PPAP them? vardar3 APQP and PPAP 14 3rd April 2012 02:54 PM
Plating Supplier PPAP Revalidation Requirements - A-Coat GM 9984132 Plating Process vardar3 APQP and PPAP 1 22nd March 2012 08:22 AM
Plating Supplier Audit Checklist fcardillo Supplier Quality Assurance and other Supplier Issues 15 11th December 2009 02:01 PM
The time now is 09:49 PM. All times are GMT -4.
NOTE: This forum uses "Cookies" - A Peachfarm Internet Property
