The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > General Metrology, Measurement Device, Calibration and Test Laboratories > General Measurement Device and Calibration Topics
Forum Username
Wooden Line
Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
Quality Digest
Some Related Topic Tags (Not all threads are Tagged)
calibration (general topics), calibration procedures and methods, gages (measurement and monitoring devices)
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
  Post Number #1
Old 20th April 2017, 06:03 AM
drobbins329
Question Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition
I have many width gages on my production floor. Simply checking against a max width condition.
My question is this:
How would I go about measuring the effective size of the slot? I have an ok set of gage blocks to compare against, but I can't get down to .0001" on some arrangements. I have a CMM I can use, but I don't trust it to hit all the possible high/low spots. I don't feel a comparator would even come close.
I attached an image of one of them as an example.
What is best practice on something like this, with the highest accuracy?
Click image for larger version
Sponsored Links
  Post Number #2
Old 20th April 2017, 08:09 AM
ncwalker's Avatar
ncwalker
Re: Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition
Off the top of my head:
1) I would definitely pass gage blocks through the slot - they have surface. And that will tell you the situation with the whole slot.
2) But you're right about the high and low spots. Lay it on its side and use a height stand and lever indicator to reach into the slot and find the high and low points that way (should be pretty quick). Put a paint dot for marking the location. Flip it over and do the other cheek.
3) With the offending areas marked, you can then switch to pin gages (most people have these in finer graduation than gage blocks) or try the CMM ensuring you probe in the marked locations. If you were really good with the CMM you could load up a matrix of positions from the edge where you could type in locations of the high/low spots and probe there specifically.
Hopefully, that gives you a few things to think about.
Thank You to ncwalker for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 20th April 2017, 08:22 AM
drobbins329
Absolutely some things to consider. I am pretty handy with the CMM. I use the gage blocks currently. I do not have gage pins in the appropriate sizes to get the resolution I am looking for (.0001).
Now that I am discussing it, I am considering getting gage pins for each width gage, in a go/nogo setup. Custom sizes to match the acceptable wear tolerances of the width gage in question.
Thanks!
  Post Number #4
Old 20th April 2017, 12:44 PM
Eredhel
Is your CMM head a scanning head?
  Post Number #5
Old 20th April 2017, 12:45 PM
drobbins329
In Reply to Parent Post by Eredhel View Post
??? Terminology?
  Post Number #6
Old 20th April 2017, 01:34 PM
Eredhel
Some CMMs can scan the part without lifting off the surface making them able to take as many points as you want. Some can only take one point at a time, they back off the surface for each point taken. Ours is a scanning head that can ride along the surface and take thousands of points along the way. With scanning heads you can do form, contour, and other more complex things.
I was checking to see which type you all used.
Thanks to Eredhel for your informative Post and/or Attachment!
  Post Number #7
Old 20th April 2017, 01:38 PM
drobbins329
Mine doesnt sound anywhere near as high-tech as that. I have to move it by hand. Single point only.
Thanks to drobbins329 for your informative Post and/or Attachment!
  Post Number #8
Old 20th April 2017, 01:57 PM
ncwalker's Avatar
ncwalker
Also thought about this a lunch - a profilometer may be able to help, if you have one. They can be very squirrely with their pickups, though, and you may not be able to get one that can access such a narrow slot.
Pin gages are cheap. (Relatively). I'd get them. But lock them up. They have a tendency to wander.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
Attribute Gage MSA - What is the width of the gray area of ​​doubt? mnavarro Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5 13th October 2011 11:23 AM
Width comes before height measurements Phatkid Various Other Specifications, Standards, and related Requirements 2 29th May 2009 07:45 AM
GD&T Rule 1: Gage size for form check at MMC (maximum material condition)? Salman Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9 22nd January 2008 01:48 AM
Where to purchase Go/NO GO Block gage needed to measure width ozziegood General Measurement Device and Calibration Topics 5 23rd May 2007 03:45 AM
CMM Band Width - How does band width relate to accuracy? Marc General Measurement Device and Calibration Topics 3 20th April 1999 09:06 AM
The time now is 09:35 PM. All times are GMT -4.
NOTE: This forum uses "Cookies" - A Peachfarm Internet Property
