The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > Inspection, Prints (Drawings), Testing, Sampling and Related Topics
Forum Username
Wooden Line
Hot Plate Welded Plastic Strength Validation
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
Quality Digest
Some Related Topic Tags (Not all threads are Tagged)
oem (original equipment manufacturer), plastic parts, plastics, validation testing, welding
Reply
  Post Number #1
Old 19th May 2017, 09:42 AM
Danny Hoover
Please Help! Hot Plate Welded Plastic Strength Validation
Does anyone have any experience with hot plate welding?
I have a new part that is made by hot plate welding 2 pieces of plastic on the edges and interior ribs.
I am attempting to validate the strength of the weld and am having a hard time finding any baseline specifications for a DT.
I am going to have a pull test done to create a baseline measurement of the strength but am having a hard time finding any documentation except assembled part specs.. The assembled part will be tested as part of a door assembly and I have those specs, but they are mainly looking at the force it takes to pull the part from the door(screw boss strength)
We are a Tier 2 supplier, just got these parts and test request.
TIA
DH
Sponsored Links
  Post Number #2
Old 19th May 2017, 10:39 AM
Miner's Avatar
Look! Re: Hot Plate Welded Plastic Strength Validation
What does DT mean?
I do not have experience with hot plate welding, but do with ultrasonic welding, so the testing issues should be similar. In general, the complexities of part geometry make fixturing the part for testing problematic, which in turn has a big impact on results.
We took the approach of sectioning the part in multiple locations and checking for correct fusion of the material. If you have straight sections within the part, you might cut a standard size section of the weld and pull test the section.
Sponsored Links
  Post Number #3
Old 19th May 2017, 11:07 AM
JeantheBigone
Is DT Dynamic Tear?
It's hard to comment without seeing exactly what it is you need to test, but is there any possibility of testing an unwelded part, using that as a baseline and expressing the result of the welded part as a percentage of the unwelded part?
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
Validation Guidance - Plastic Injection Molding Process QE Qualification and Validation (including 21 CFR Part 11) 53 13th February 2017 05:13 PM
Validation of Processes - Plastic Injection Moulding - ISO 9001 Clause 7.5.2 lrsiyer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13 17th May 2011 04:02 AM
Surface Plate Calibration - How to verify the flatness of a granite surface plate Calibrator24 General Measurement Device and Calibration Topics 1 22nd July 2010 11:29 PM
Plastic Injection Molding Specification (Purchasing, Qualifying, validation) examples triathlonx13 Document Control Systems, Procedures, Forms and Templates 2 19th December 2009 08:11 AM
Advice on maintaining surface plate condition - Starrett crystal pink surface plate apestate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14 4th July 2006 10:37 AM
The time now is 12:22 AM. All times are GMT -4.
NOTE: This forum uses "Cookies" - A Peachfarm Internet Property
