§ 820.120 Device labeling - "shall be documented in the DHR"
ThatSinc
Hi All,
Hoping I can get some clarity from the wider audience regarding the requirements under 820.120 on device labelling about things that must be "documented in the DHR";
(b) Labeling inspection.
The release, including the date and signature of the individual(s) performing the examination, shall be documented in the DHR.
(d) Labeling operations.
The label and labeling used for each production unit, lot, or batch shall be documented in the DHR.
The guidance provided by the FDA here, seems to give conflicting advice on what checks and balances are needed on receipt and then again on use, particularly when it comes to pre-printed labels that do not include control numbers.
The devices manufactured at the company I'm working with now include a significant number of pre-printed labels and a single in-house printed label that includes the control number, UDI, DOM, etc. All labels have technical drawings.
Each of the pre-printed labels are inspected and released at the time of goods inwards inspection, which includes reference to the label part number, revision, and order number, though a physical copy of the label is not currently attached to the inspection record.
Each label is stored in separate boxes labelled with the part number and description, Each sheet of labels includes the part number and revision of the label, each label sheet where there are multiple labels on a single sheet cannot be mixed up based on the size/shape of the label and where it is intended to be applied.
Currently the labels would be withdrawn from stock and used, no further check and sign-off on being issued from stock for use.
Is this acceptable?
The devices are built in accordance with technical drawings that reference the part number of the label to be used.
The DHR would show that a particular assembly or finished device was manufactured in accordance with the technical drawings but there would be no documented record of what batch of labels was used on a particular batch of sub-assembly or finished device (paper based system, no electronic stock management).
I'm concerned that this is not sufficient to comply with the requirement to document the release of any label within the DHR (as you couldn't say explicitly from which order the label used came with to reference back to the inspection and release document) or the requirement to document which label was used, as again - you couldn't explicitly state which order of labels was used, particularly times when stock is running low and another order was delivered and released for use.
i.e. if you wanted to look at the DHR for a particular device, you may have a situation where the label used could have been from either of two orders, though the review and approval of the label would be available from both. would this be acceptable?
The raw material stock for the in-house printed label is inspected at goods-receipt and released to stock, and the printed label is verified as correct by the production supervisor following printing.
A copy of this label is attached to the DHR by the supervisor and signed when they are issued. I'm confident that this meets the requirements - but would be grateful for any confirmation or challenges on that.
Thanks in advance,
TS.
Swimming In The Soup
I have two comments on your situation.
1. Medical Device Labels are required to be protected as to not be misbranded or adulterated. If someone takes (steals) controlled labels and places them on non-conforming product then you as a company may be liable. A reconciliation log can help there to account for the label inventory and at least give you due diligence support in court.
2. We have a pharma batch style process. Our filling record form is issued with an image of the appropriate label and the operators will attach a sample of the actual label used next to it to evidence the proper label used. As far as I can tell, there is no verification in your process that the supervisors attached label is actually the label placed on the product. That is a gap.
ThatSinc
True, though I've worked for a few device companies where the majority of fixed-text labels are free-issue once they've been verified as good at goods inwards, and the labels with device specific control information on are issued per run and verified as correct prior to issue.
The device release then captures a review of the labelling being correct.
In your example, having a reconciliation doesn't stop anyone from saying they destroyed a label because it was damaged or mis-applied, and using it on a non-conforming device - it's either fraud with a false record, or fraud with no record.
This is why I have this concern because, as with most people posting around on Quality forms, the "we've always done it like that" defence is like red rag to a bull, and my only defence for thinking it's acceptable to free-issue the labels is that I've been in companies that worked like that before.
I don't think securing all labelling and having a designated person issuing labels for each job is necessary, and would just result in significant amounts of labelling on work benches rather in the appropriate storage location.
The device authorisation for release includes review of the applied labels against the batch record.
D 820.120 UDI (Unique Device Identification) Labeling Verification Requirements Other US Medical Device Regulations 11
R Sec. 820.120 Device Labeling & DHR - Count and Document All Labels 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
S Suggested process to show compliance for this 820.120(a) for Label Integrity 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A Implementation of 820.72 and 820.120 - Problem with Calibration Procedure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C QSR 820.120 labeling and packaging control 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
R Device History Record Title 21 CFR Part 820.184 (d) QSR 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
D Licensed Practitioners Exemptions 807.65 and 820.1.a.2 US Medical Device Regulations 0
D Audit Report details when ISO 13485:2016 and cGMP 21 CFR 820 are applicable ISO 13485:2016 - Medical Device Quality Management Systems 6
C 21 CFR 820.90 - Documenting rework and reevaluation in DHR 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
Sam Lazzara Record signature requirements in proposed FDA 21 CFR 820 QMS Regulation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
JesseE Electronic signatures FDA CFR 820 ISO 13485:2016 - Medical Device Quality Management Systems 3
M Validation of Data verification tool per 21 CFR 820 Quality Assurance and Compliance Software Tools and Solutions 1
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
A TUV Audits - 21 CFR 820 General Auditing Discussions 6
S Records - Do's and don't' of record entries (FDA - 21 CFR 820) Records and Data - Quality, Legal and Other Evidence 13
T 21 CFR 820.20 - Quality Planning Requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M 21 CFR 820 vs 21CFR820 vs 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
A 21 CFR 820 - Risk Management - Looking for some guidance US Food and Drug Administration (FDA) 3
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
D ISO 13485, FDA 21 CFR 820 and Auditing the Accounting Department ISO 13485:2016 - Medical Device Quality Management Systems 5
Ed Panek 21 CFR Part 820 - FDA Label Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
B Per 21CFR 820.198 (b) - Justification for no investigation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 22
Watchcat Does 820.30 include the manufacturing process? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
K 820.200 Servicing Procedure - Our system (because there is an API involved) is classified as Class 3 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
V Determining FDA 820 (registration) vs ISO 13485 - Supplier gives us the kit ISO 13485:2016 - Medical Device Quality Management Systems 1
R Addressing training requirements - 21 CFR Part 820.25 (1) & (2) Other US Medical Device Regulations 4
R How to improve a Validation program and procedures to FDA (21 CFR part 820) & ISO13485 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Marc Problem with 21 CFR Part 820 - US FDA Quality System Regulations (QSR) sub-forum link - 2 May 2019 Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
R 21 CFR Part 820 Contract Manufacturer of Medical Device Component 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Q Any good Checklists for ensuring SOPs cover ISO 13485:2016 and 21CFR 820? ISO 13485:2016 - Medical Device Quality Management Systems 3
B Classes/ Online Training on ISO 13485:2016 and FDA QSR Part 820 ISO 13485:2016 - Medical Device Quality Management Systems 5
C ISO 13485 certified as precursor to regulatory compliance to 21 CRF Part 820? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
N Change Control - Compliance with FDA 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
D 21 CFR Part 820 (Subpart A) - Question about "Authority" 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R RUO audits - CFR 820.22 and ISO 13485 8.2.4 Internal Auditing 3
A Training as well as certifications for ISO 13485:2016, 21 CFR 820... Training - Internal, External, Online and Distance Learning 5
K Production Unit Labeling - 21 CFR 820.184.e 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
R 21 CFR Part 820.186 - Types of Quality System Records Document Control Systems, Procedures, Forms and Templates 1
M Does the Scope of 21 CFR Part 820.72 (Equipment) apply to Design? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
V 21 CFR 820 Compliant way to use Kaizen to address Nonconformances Nonconformance and Corrective Action 9
C 21 CFR Part 820.184 - Label Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
shimonv 21 CFR 820.20(d) says: Each manufacturer shall establish a Quality Plan 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
V Upgrading Systems from CFR 211 to CFR 820 (drug+device combination) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
S Looking for a checklist comparing ISO 13485:2016 and 21 CFR Part 820 ISO 13485:2016 - Medical Device Quality Management Systems 14
Q Internal Audit of Product Quality Complaint System (21 CFR Part 820) Customer Complaints 9
R Managing Employee Training Files - 21 CFR Part 820.25 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M Release authorization before or after packaging per 21 CFR 820.80(d)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D Need advice in streamlining antiquated 21 CFR 820 compliant QMS Quality Manager and Management Related Issues 2
J Minimum staff per 21 CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Does a process map satisfy 21 CFR 820.20(d) (Quality Plan)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
