0.00005" tolerance on micrometer with 0.0005" resolution?
greif
I see that Mitutoyo 293 series (std. 0-1" digital micrometer with 0.00005" resolution) have a factory spec of 0.00005".
This seems rather extreme to have the tolerance be the same as the resolution. What are everyone's thoughts?
NickV....
From my experience I don't think the 5th digit even indicates a value between 0.00000-0.00009", it only shows a value of 0.00000 or 0.00005". So accurate to the 5th digit.....I don't believe so.
dwperron
I need the full model number to get a complete answer to this.
Some have a 0.00005" tolerance, others have 0.0001"
There are parallelism and flatness specs that need to be accounted for.
Note that "Quantizing error: ±1 is not included " in the tolerance.
dwperron
I am looking at the specs on this Mitutoyo web page:
Coolant Proof Micrometer Series 293-with Dust/Water Protection Conforming to IP65 Level
And the first 0-1" micrometer listed: 293-330-30
For that micrometer here are the full specifications:
Technical Data
• Resolution: .00005"/0.001mm
• Quantizing error: ±1 is not included.
• Flatness: .000012"
• Parallelism: .00004"
How you combine the specifications is up to you. Conservatively, you can just add the terms together. More aggressively, you can combine them via RSS.
R Inspecting straightness tolerance of .00005" on a shaft Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
J Measuring Hole @ .00005" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
D Tolerance symbol Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Proud Liberal Small radius with tight tolerance on a torus General Measurement Device and Calibration Topics 4
L GRR for a tolerance that has changed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T How to justify this High %Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
S Tolerance limits for micro balance General Measurement Device and Calibration Topics 1
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
WEAVER Electronic Weighing Scale Calibration Tolerance Manufacturing and Related Processes 1
Ronen E Tolerance intervals (?) question - Flow Rate Probability Range Statistical Analysis Tools, Techniques and SPC 6
D Tolerance when verifying an analytical balance General Measurement Device and Calibration Topics 3
E Discussion between co-worker on tolerance and uncertainty and how to apply it. Thoughts? 17025 ISO 17025 related Discussions 1
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
T GRR based on part tolerance or process variation. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Excel OOT (Out of Tolerance) Formula Excel .xls Spreadsheet Templates and Tools 3
S Question about a basic additive variance/tolerance example Quality Tools, Improvement and Analysis 2
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
F Position tolerance check gage manufacturing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M GD&T tolerance or band? Using a symbol like parallelism // Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Gage R&R without tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
V Using K-Factor(Tolerance Interval) Analysis for Design Verification Statistical Analysis Tools, Techniques and SPC 3
C Acceptable NDC for %GR&R part inspection to Tolerance (%Tolerance) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Cpk for Unilateral Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 9
S Doubts about SPC taken in Machining - Part has +-0.01 Tolerance Statistical Analysis Tools, Techniques and SPC 5
A Calibration tolerance for data logger General Measurement Device and Calibration Topics 3
N Straightness Gage Tolerance General Measurement Device and Calibration Topics 0
G Calculating Tolerance of a Panel Meter with a 2 degrees of an Arc General Measurement Device and Calibration Topics 0
kedarg6500 Excel spreadsheet for Unilateral Tolerance Study wanted Excel .xls Spreadsheet Templates and Tools 2
U Control Charting a Feature with Bonus Tolerance Quality Tools, Improvement and Analysis 10
J Process Capability - How much percentage of tolerance? VDA Standards - Germany's Automotive Standards 3
B Gage R&R MSA - Variation, Tolerance, Variance by different methods IATF 16949 - Automotive Quality Systems Standard 23
R Fixing of tolerance limit - Electronic weighing balance with the capacity of 150 Kgs General Measurement Device and Calibration Topics 5
