mkjohnson
I am new to measurement systems analysis and I am doing a 10 part, 3 operator, 3 measurement GR&R study for a client. I have read through numerous posts on this forum about tolerance and GR&R, but haven't found a discussion that matches the scenario I am looking at.
Here is a simplified version of the problem:
- the client has a process that produces parts with a key parameter that varies between 0 and 2 (arbitrary units).
- parts measuring less than 1 will be considered 'A' grade and parts greater than 1 will be considered 'B' grade
- the client wants to keep the 'A' grade parts and discard the 'B' grade parts
Let's suppose the GR&R study shows Gage R&R at 5% of total variation. Do I think of the tolerance parameter as being related to actual process width and set it to 2, or do I set it to 1 because of the clients preference of considering parts from 0 - 1 to be within spec?
The situations I have read about with respect to tolerance are when the sample set in the GR&R study doesn't span the process range. In these situations, it makes sense to me to divide by a tolerance known through other means. But the situation I'm wondering is when the client's desired range for accepting a part is just a fraction of the process range.
Any help is appreciated.
- mkj
- mkj
