100% Inspection - 80% Accurate - Quote from Juran (?)
Status
Not open for further replies.
Rick Goodson
#91
SteelMaiden,
I am not sure which is the best way. Maybe we could perform a DOE to determine which process (half-blind versus half a##ed) produces the best results.
As an aside, what part of NC? I use to work in Albemarle for a couple of years.
JMitchell
#93
100% inspection calculation
Originally posted by Kevin Mader
RCW,
Dr. Juran noted that inspection was at best, 80% accurate. Others have guessed less, but that doesn't really matter. Think of it this was. One inspector is .8 in 1 chance likely to find a problem. The second inspector has the same chance. However, if you take .8 and multiply it by .8 (the second inspector), your outcome is .64. With the second inspector, your odds are reduced thus making 200% inspection 64% likely to find a defect.
Dr. Deming offered this in regards 200% inspection: Inspector 1 thinks inspector 2 will catch the defect while inspector 2 thinks inspector 1 will catch it. Net result: nobody inspecting.
I hope this helps.
Kevin
I think that a better way to do this calculation is to say that there is a 20% chance a defect will not be caught. Thus, if you add a second inspection, the chance that a defect will not be caught is 0.20 * 0.20, or 4%. Thus, double inspection is 96% effective, and triple inspection is 99.2% effective, statitically speaking. It doesn't make sense that inspecting more decreases your chance of catching a defect using normal statistical analysis.
However, the situation where an inspector knows that someone else is also inspecting the product may be another beast all together. It may be that when this situation occurs, 100% inspection is only 50% effective - no way to know unless you conduct your own experiment!
E
energy
#94
Re: 100% inspection calculation
Why don't we ask the Inspectors. I, for one, would never not inspect because someone else has already inspected. It's absurd. Make the same mistake? Possible. Particularly, if the drawing is unclear or subject to interpretation. That's happened. Supplier, Code Inspector, Source Inspector, Assemblers all missed a very important attribute in my previous life. They changed their drawing practices, not blame Inspectors. I've posted on this before and feel very strongly that no self respecting Inspector would do such a despicable thing such as not do his/her job. It does make a good subject for those professionals who have never sat at an Inspector's bench and performed such an important high pressure task. Inspectors Rule!:ko: :smokin:
Status
S 100% Final Inspection Requirements of Active Medical Devices (MDD or IEC Standards?) EU Medical Device Regulations 4
E Is there a specific regulatory requirement for 100% inspection of IFUs? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
N Switch to 100% inspection when lot fails sampling? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
G Is Controlled Shipping requirement Sampling Based or 100% Inspection? Misc. Quality Assurance and Business Systems Related Topics 3
N 100% Inspection in Retail Warehouse which Ships Products to Customers Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K 100% Inspection or do the usual IQ, OQ, PQ Validation - Medical Molding Design and Development of Products and Processes 3
G Am I silly to do a 100% inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
M 100% Inspection - 85% Effective Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
M Vision System - Camera vs. Sensor to perform 100% EOL Inspection Quality Tools, Improvement and Analysis 2
S AQL .65 Level III - Take a particular component off 100% Inspection AQL - Acceptable Quality Level 4
A Injection Mold 100% Visual Inspection - Short Shots and Debris not being found Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
M SPC vs. 100% Inspection - Is SPC still value-added when 100% inspection is in place? FMEA and Control Plans 40
S Applying ANSI/ASQ Z1.4 given known lot size and 100% visual inspection AQL - Acceptable Quality Level 2
S Is there an Accept/Reject Criteria for 100% Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
E 100% continuous inspection question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
R Transfering Cpk specification to 100% inspection specifications Capability, Accuracy and Stability - Processes, Machines, etc. 24
S Condition of 100% inspection in organization. Capability, Accuracy and Stability - Processes, Machines, etc. 7
G Is 100% Inspection a Control or does a Process need another type of control? FMEA and Control Plans 9
Q Who is responsible for 100% Inspection (QC) activities? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
1 U Charts, Defects and 100% Inspection Statistical Analysis Tools, Techniques and SPC 8
C Acceptance Sampling is Better Than 100% Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
J Visual Inspection Not 100% Effective - How to Improve Visual Inspection Quality Tools, Improvement and Analysis 51
J Customer Complaint Corrective Action Response - 100% Vision Inspection Customer Complaints 9
M 100% Measurement Shift to Sample Inspection? PCB Substrates Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
L Customer Requires Cpk 1.33 with 100% Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
R 100% Visual Inspection - Would you Remove or Reduce the Visual Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
G Inspection 100% - Process continuos (Continuous Process) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S 100% Inspection Control Chart By Dr. Feigenbaum - SMT (Surface Mounting Technology) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Tips for convincing general labour that 100% inspection not required Various Other Specifications, Standards, and related Requirements 18
S P-Chart Question - Need Guidance - 100% inspection of all product parts required? Statistical Analysis Tools, Techniques and SPC 11
T Prototype Inspection - 100% Inspection on All Parts or just a Sample? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A How effective is 100% inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 25
R 8.2.3.1 Monitoring and measurement - Containment of product and 100% inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Final Inspections - Does 100% inspection really work Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
CarolX Accuracy of 100% Visual Inspection - Proofs Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Ninja Windows 10 100 % disk use after update Coffee Break and Water Cooler Discussions 33
A 21 CFR part 11 - section 11.100 - Electronic Signature Certification Other US Medical Device Regulations 6
Stoic Manual soldering processes - 100% verifiable, or always requiring validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
E Correct way to certify hydrostatic testing when it is not 100% (and Sample Size) Various Other Specifications, Standards, and related Requirements 6
A What to do when 100 % verification is not 100 % Manufacturing and Related Processes 5
Nicole Desouza ISO / AS Certification - Small business with less than 100 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M EU – Chemical Safety Report – CSR – REACH Authorisation decisions – Triton X-100 – Ortho-clinical-Use1 REACH and RoHS Conversations 0
D Measuring fine tubing (< 0.100") "Wall by weight" General Measurement Device and Calibration Topics 11
Marc Anniversary of the First Trans-Atlantic Flight 100 years ago - June 2019 Coffee Break and Water Cooler Discussions 2
Y IEC 62304 Section 4.3(a) - 100% probability of failure IEC 62304 - Medical Device Software Life Cycle Processes 3
BHobbs_Busche All Measurements taken with a Variable Gage have to be Recorded 100% IATF 16949 - Automotive Quality Systems Standard 14
Pmarszal Clarification for 21 CFR Part 11.100 - General Requirements Other US Medical Device Regulations 14
B Is Gage R&R required on a 100% Dimensional Layout? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
K IEC 61010-2-100 Labeling question - IVD equipment Other ISO and International Standards and European Regulations 1
D Long length measurement of 18" up to 100" with an accuracy of .005 min General Measurement Device and Calibration Topics 8
