Brexit 100% inspection during in process inspection
sharonblon88
Our medical device needs 100% inspection during in process inspection. What's the sample plan we can apply for?
Another question is that for process validation or verification, when it can be proved that it's fully verification without validation? If it needs validation, what parameters related to? (for N95 respirator)
Cthames
It sounds like if you need 100% inspection, you won't be able to use a sampling plans. Sampling plans take a look at a percentage of the total units (lets say 15 out of 100) to make a determination of the acceptability of the lot.
chris1price
Remember if you are doing 100% inspection, you must validate the inspection process to prove that it is suitable, (ie perform Measurement Systems Analysis / Test Method Validation).
Unfortunately, only you can identify the parameters that require validation. Do you have risk assessments or control plans for the process? What are the critical quality attributes for the product, how do you know they are being met in production? If you think about these points, it might lead you to the answer.
Cthames
Doesn't 100% inspection alleviate you from validation? I believe the regulation states you must validate all processes which cannot be 100% verified.
Ed Panek
QA RA Small Med Dev Company
We perform 100% inspection of the device in production. We power it on and verify it transmits data and record the event in a human readable log. We have to validate other areas though like tools and equipment.
Some characteristics can be inspected or tested 100%. (this is verification)
Some cannot and will require process VALIDATION. Process validation is required for those characteristics that can only be tested via a destruct test and therefore 100% inspection is not viable.
sharonblon88
Thanks. For the defected in-process products, do we need to maintain a record for different defects? We usually just destroy it and throw into trash can.
sharonblon88
For 100% inspection, do we need to document inspection finding by characteristics or simply just classify by acceptance or scrapes? We don't reword the device
I don't know. this is usually either a regulatory requirement and/or a requirement of your QMS.
I would think as a medical device you would want - and most probably need - records so that if an audit, investigation or if a recall were necessary you would be able to show when defects 'began' and 'ended'.
Ed Panek
For an audit, it would be expected that the results of the 100% inspection can be reviewed. For us, each device has a serial number that is broadcast with the data that is collected. All of this is exported into an XLS we can add to the DHR. We also record failures of this stage.
S For Parts Manufacturer Approval (PMA) Is 100% Inspection Required? Federal Aviation Administration (FAA) Standards and Requirements 2
M Detection rank for sampling vs 100% inspection & 15x vs 400x magnification FMEA and Control Plans 4
S 100% Final Inspection Requirements of Active Medical Devices (MDD or IEC Standards?) EU Medical Device Regulations 4
E Is there a specific regulatory requirement for 100% inspection of IFUs? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
N Switch to 100% inspection when lot fails sampling? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
G Is Controlled Shipping requirement Sampling Based or 100% Inspection? Misc. Quality Assurance and Business Systems Related Topics 3
N 100% Inspection in Retail Warehouse which Ships Products to Customers Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K 100% Inspection or do the usual IQ, OQ, PQ Validation - Medical Molding Design and Development of Products and Processes 3
G Am I silly to do a 100% inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
M 100% Inspection - 85% Effective Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
M Vision System - Camera vs. Sensor to perform 100% EOL Inspection Quality Tools, Improvement and Analysis 2
S AQL .65 Level III - Take a particular component off 100% Inspection AQL - Acceptable Quality Level 4
A Injection Mold 100% Visual Inspection - Short Shots and Debris not being found Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
M SPC vs. 100% Inspection - Is SPC still value-added when 100% inspection is in place? FMEA and Control Plans 40
S Applying ANSI/ASQ Z1.4 given known lot size and 100% visual inspection AQL - Acceptable Quality Level 2
S Is there an Accept/Reject Criteria for 100% Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
E 100% continuous inspection question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
R Transfering Cpk specification to 100% inspection specifications Capability, Accuracy and Stability - Processes, Machines, etc. 24
S Condition of 100% inspection in organization. Capability, Accuracy and Stability - Processes, Machines, etc. 7
G Is 100% Inspection a Control or does a Process need another type of control? FMEA and Control Plans 9
Q Who is responsible for 100% Inspection (QC) activities? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
1 U Charts, Defects and 100% Inspection Statistical Analysis Tools, Techniques and SPC 8
C Acceptance Sampling is Better Than 100% Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
J Visual Inspection Not 100% Effective - How to Improve Visual Inspection Quality Tools, Improvement and Analysis 51
J Customer Complaint Corrective Action Response - 100% Vision Inspection Customer Complaints 9
M 100% Measurement Shift to Sample Inspection? PCB Substrates Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
L Customer Requires Cpk 1.33 with 100% Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
R 100% Visual Inspection - Would you Remove or Reduce the Visual Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
G Inspection 100% - Process continuos (Continuous Process) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S 100% Inspection Control Chart By Dr. Feigenbaum - SMT (Surface Mounting Technology) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Tips for convincing general labour that 100% inspection not required Various Other Specifications, Standards, and related Requirements 18
S P-Chart Question - Need Guidance - 100% inspection of all product parts required? Statistical Analysis Tools, Techniques and SPC 11
T Prototype Inspection - 100% Inspection on All Parts or just a Sample? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A How effective is 100% inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 25
R 8.2.3.1 Monitoring and measurement - Containment of product and 100% inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Final Inspections - Does 100% inspection really work Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R 100% Inspection - 80% Accurate - Quote from Juran (?) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 94
CarolX Accuracy of 100% Visual Inspection - Proofs Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G When does containment event not require 100% sort? Nonconformance and Corrective Action 5
M Do i need to have equipment validation if 100% testing is completed? Qualification and Validation (including 21 CFR Part 11) 6
Ninja Windows 10 100 % disk use after update Coffee Break and Water Cooler Discussions 33
A 21 CFR part 11 - section 11.100 - Electronic Signature Certification Other US Medical Device Regulations 6
Stoic Manual soldering processes - 100% verifiable, or always requiring validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
E Correct way to certify hydrostatic testing when it is not 100% (and Sample Size) Various Other Specifications, Standards, and related Requirements 6
A What to do when 100 % verification is not 100 % Manufacturing and Related Processes 5
Nicole Desouza ISO / AS Certification - Small business with less than 100 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M EU – Chemical Safety Report – CSR – REACH Authorisation decisions – Triton X-100 – Ortho-clinical-Use1 REACH and RoHS Conversations 0
D Measuring fine tubing (< 0.100") "Wall by weight" General Measurement Device and Calibration Topics 11
Marc Anniversary of the First Trans-Atlantic Flight 100 years ago - June 2019 Coffee Break and Water Cooler Discussions 2
Y IEC 62304 Section 4.3(a) - 100% probability of failure IEC 62304 - Medical Device Software Life Cycle Processes 3
