17025 and NIST handbook relationship (need advice)
I'm not even sure how to phrase my question, but...
I'm a relatively new and inexperienced quality manager, and I'm going through our Internal Audit checklists for 17025 for our test lab. I was noticing that some checklists reference the 17025:2017 standard
For example:
4. General Requirements
>4.1 Impartiality
>>4.1.1 Impartiality
>>>Are Lab activities undertaken impartiality and structured and managed to safeguard impartiality?
And some reference NIST 150 2006 Ed. Handbook (National Voluntary Laboratory Accreditation Program Procedures [NVLAP] and Gen Requirements)
For example:
4.13 Control of Records
>4.13.1 General
>>4.13.1.1a
>>>Does the laboratory establish and maintain procedures for identification, collection, indexing, access, filing, storage, maintenance, and disposal of quality and technical records?
I couldn't find anything in our procedures or work instructions that mentions NIST or NVLAP, nor any actual reference on the checklists saying that this was they were pulled from. The only thing I found was the actual NIST 2006 handbook in the personal file of the QM the company had about 2-3 years ago. I only figured this out because I'm very good at googling (I'm the kind of person that needs to know how things work before doing something about it) and the people working here looked as confused as I felt when I mentioned this.
I'm trying to figure out his thought process for doing this; I'm not sure what to do with this information. I can see how they're related, but to use things almost word for word from this second document and not mentioning that anywhere puzzles me.
My Questions:
Should I change things?
Is it necessary to base things off the NIST handbook or is it overboard/ outdated?
Is there a better reference I can use for formatting our internal audit checklists?
Should I even worry about this?
Thanks Cove!
Jen Kirley
Quality and Auditing Expert
Hello Whiskey,
It seems counter productive to wonder if we should change how we do things out of concern that the NIST 150 2006 Ed. Handbook seems out of date. The clause you listed does not seem out of date at all. Let's keep in mind that 17025:2017 is generally for organizations that provide calibration services. Who could argue with establishing and maintaining procedures for identification, collection, indexing, access, filing, storage, maintenance, and disposal of quality and technical records? Notice there is not mention of documented procedure(s).
Similarly, impartiality is a common sense attribute in auditors. What good-sense QMS would not want its auditors to be free to call things as they see them?
I hope this helps!
dwperron
For example:
>4.1 Impartiality
>>4.1.1 Impartiality
For example:
>4.13.1 General
>>4.13.1.1a
My Questions:
Thanks Cove!
ISO 17025 is an international standard, and does not fall under NIST.
NVLAP is an accreditation body. They do assessments for accreditation of organizations to ISO 17025. They do not write the standard, they audit compliance to the standard.
Interpretation of ISO 17025 is done by ILAC, the International Laboratory Accreditation Cooperation. You can find then at www.ilac.org.
They have a number of publications available concerning interpretation of ISO 17025.
It appears that your organization is accredited to ISO 17025 by NVLAP. You should reach out to them with your questions, as they will give you guidance based on their interpretation of the standard.
You can also download the most recent copy of NIST Handbook 150:
NVLAP Handbooks and Lab Bulletins
Oh, I see, so that's what NIST and NVLAP do.
We're actually not accredited by NVLAP, which is why I was confused to see it referenced in our document (section numbers only, there's no place in our system that actually straight-out mentions NIST/NVLAP. I had to figure out where the section numbers came from because they didn't line up with the 17025 manual).
as quality manager you decide what goes into your checklist to try to meet the requirements of the governing standards and the quality goals. if the previous qm though nist gave a good checklist that satisfies the requirements then that would be their prerogative. there are code councils tat publish internal audit checklists for any lab to use for various test methods also. having said that, it would be helpful if people reference the documents they are plagiarizing....
dwperron
Out of curiosity, who are you accredited through for 17025, and is it for calibration or testing?
dwperron
Our cert says ANAB, and it's for testing
That got me to do a little more digging, and I learned something, so today's a good day!
The NIST Handbook 150:2006 is based on ISO 17025:2005. Actually, it is a word for word copy of 17025:2005.
If you are looking to update your 17025 checklist you need to do it for 17025:2017, and since you are not accredited through NVLAP I would avoid using references to their handbook, keep everything referenced tp 17025:2017.
Thanks for digging into that!
I don't like changing things without having something to back up my reasoning, so I'll definitely use this information when I present my updates to the big boss.
S ISO 17025 requirements not enough to prove NIST Traceability? ISO 17025 related Discussions 10
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
X ISO 17025 certification for Laboratory for online gambling products ISO 17025 related Discussions 3
R ISO 17025 - ISO Guides 33 & 80 ISO 17025 related Discussions 1
T ISO 17025: Lockout/Tagout Requirement ISO 17025 related Discussions 1
R ISO 17025 vertical audit checklist wanted Document Control Systems, Procedures, Forms and Templates 2
A ISO 17025 - Methods validation and clients ISO 17025 related Discussions 3
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
R Who is the customer in the ISO/IEC 17025:2017? ISO 17025 related Discussions 1
C Compliance with ISO 17025 requirement 8.4.2 - Controls - Records recovery ISO 17025 related Discussions 4
G ISO 17025-2017 Management Review reporting items - Inputs ISO 17025 related Discussions 1
S High voltage testing - ISO 17025 - 7.2.2 Validation of methods and 7.3 Sampling ISO 17025 related Discussions 3
S Internal calibrations - Part of an ISO 17025 accredited testing laboratory (Automotive) ISO 17025 related Discussions 16
I Approved Suppliers ISO/IEC 17025:2017 and used test equipment ISO 17025 related Discussions 6
W Issuing reports under ISO 17025:2017 ISO 17025 related Discussions 2
S The (E) in ISO/IEC 17025:2017(E) ISO 17025 related Discussions 3
G ISO 17025:2017 Uninterrupted chain of traceability for test laboratories ISO 17025 related Discussions 6
DuncanGibbons Who are ISO/IEC 17065 and 17025 applicable to? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
V IS/ISO/IEC 17025:2017 Clause 4.1 Impartiality ISO 17025 related Discussions 3
F ISO 17025:2017 Clause 7.7 Ensuring the validity of results - Threshold ISO 17025 related Discussions 9
A ISO 17025 Requirement 6.2 - Department Manager Testing Qualifications ISO 17025 related Discussions 1
F ISO 17025 8.6.2 Customer Feedback Analysis ISO 17025 related Discussions 5
F ISO 17025 8.8 Internal Audits in a segmented company ISO 17025 related Discussions 5
F Faulty Equipment and ISO 17025 General Measurement Device and Calibration Topics 1
F Online courses - Metrology, standardization, calibration and ISO 17025 Training - Internal, External, Online and Distance Learning 3
F Proficiency Testing for ISO 17025: AC Current Ranges ISO 17025 related Discussions 1
F ISO 17025:2017 Format for Procedure and Records Document Control Systems, Procedures, Forms and Templates 3
F ISO 17025:2017 Clause 7.4.1 - Requirements for Procedures ISO 17025 related Discussions 4
F Complying with ISO 17025 by UNIDO ISO 17025 related Discussions 0
F Measurement Audit and ILC for ISO 17025 Clause 7.7.2 - Comparison with results of other laboratories ISO 17025 related Discussions 0
F ISO 17025:2017 mandatory documentation requirements ISO 17025 related Discussions 1
F Linking an ISO 31000 Risk management SOP to ISO 17025 ISO 17025 related Discussions 2
C ISO 17025 2017, Requirement 6.6.3 - Communicate requirements to external providers ISO 17025 related Discussions 4
D Risk Assessment Procedure in accordance with ISO 17025:2017 ISO 17025 related Discussions 5
A Validation of Calibration Methods and Traceability - ISO 17025 ISO 17025 related Discussions 3
J ISO 17025 - Please share a sample procedure for monitoring the validity of results ISO 17025 related Discussions 1
G ISO 17025:2017 7.1.2 - Should I produce a document for the customer? ISO 17025 related Discussions 8
G ISO 9001 and ISO 17025 - Measuring tools not in calibration system General Measurement Device and Calibration Topics 3
D USFDA vs NRTL/IEC 17025 Differences - Compliance testing lab ISO 17025 related Discussions 0
D USFDA vs NRTL/IEC 17025 Differences - Compliance testing lab US Food and Drug Administration (FDA) 6
E Discussion between co-worker on tolerance and uncertainty and how to apply it. Thoughts? 17025 ISO 17025 related Discussions 1
S Can anybody share a sample risk assessment prepared based on ISO 17025:2017? ISO 17025 related Discussions 15
U ISO 17025:2017 Clause 7.7 Ensuring the Validity of Calibration Results ISO 17025 related Discussions 6
G From an ISO 17025 auditor perspective must micrometer calibration check anvil flatness? General Measurement Device and Calibration Topics 4
