18 different charts? 18 sample points over 28 days
I've got myself very confused.
If I have 18 different sample points throughout a process and sample each of them once a day for 28 days how to I chart stability of the process. Do I need to do 18 charts each with a sample size of 1?
Thank you so much for any help.
Jen Kirley
Quality and Auditing Expert
Welcome to The Cove ricen!
What process is this that has 18 different sample points? What are these sample points? Which ones are critical and which are not?
I am also wondering about your sample size of 1 per day. How big are your lots or batches? I am wondering how a single sample would allow you evaluate stability in your process. That said, I can understand it if you make chemicals in large batches, one per day.
Thank you so much for taking the time to reply.
This is a purified water distribution loop.
18 sample points along the loop. All equally critical. I have 28 days of data with tests results everyday at each point for conductivity, total organic compounds, total microbial count and residue on evaporation.
How best to present all this data and show the system is in control? Previously my company has taken the daily mean of all sample points and plotted an x-bar & s charts using the Stdev of the daily mean of all points. One graph for 28days of conductivity,bone for toc etc. We superimpose our acceptance criteria onto the x-bar graphs, which I'm pretty sure is a no no.
I'm just not sure where to start with this one.
Thank you for the warm welcome.
I should add that this is an academic exercise. I am the system owner and the system is fully validated. I just want to learn how to apply lean six sigma principles to the data before I suggest their use to my employer. I'm open to any suggestions. I am a green belt but am new to the company and there are no Black belts here to ask for guidance. We are in the pharmaceutical space.
Thinking again to the criticality of all 18 sample points.: I'm open to suggestion regarding risk analysis to reduce the test points. We do 18 points because "that's what we've always done".
Extra info: The water is constantly circulating around the loop. The samples are taken manually by one person walking from point to point over approx 2 hr period.
First I strongly suggest that you read the articles of Donald Wheeler. These are free and can be found at quality digest. The most ritual ones are also available for free at his website spcpress.com. You must understand the concept of homogeneity and rational sampling to properly select a control chart design. I seriously doubt that you were taught this as a green belt - even black belts are rarely taught this.
Without looking at the data we cannot really advise on the best way to chart it. It all depends on the homogeneity of the 18 points. A third research article would be the 3 Way Control Chart as explained by Donald Wheeler. If you can post the data and the charts we can provide more help…
Thank you Bev, I will check those out. (by the way I LOVE your signature!)
How can I post the data? I don't see how to attach a file.
Here are direct links to the best articles that might help you:
Prevette, Steven, “Liars Figure and Figures Lie”, ASQ Newsletter October 1999. Copy provided via Elsmar Cove Quality Forum by Steve Prevette.
@Steve Prevette perhaps you could provide a link to your article? or repost it?
Wheeler, Donald, “Why We Keep Having Hundred Year Floods”, Quality Digest, June 2013, Why We Keep Having 100-Year Floods
Wheeler, Donald, “The Secret Foundation of Statistical Analysis”, Quality Digest, December 2015 The Secret Foundation of Statistical Inference
Wheeler, Donald, “Statistics 101 and Data Analysis”, Quality Digest, March 2016 Statistics 101 and Data Analysis: an Example
Wheeler, Donald, J., “Foundations of Shewhart’s Charts”, SPC Tool Kit column, Quality Digest, October, 1996 http://www.qualitydigest.com/oct96/spctool.html
Wheeler, Donald J., “The Empirical Rule”, Quality Digest, March 2018 The Empirical Rule
Wheeler, Donald, “The Right and Wrong Ways of Computing Limits”, Quality Digest, January 2010 The Right and Wrong Ways of Computing Limits
Wheeler, Donald, “Good Limits from Bad Data I”, Quality Digest, March 1997 SPCTool
Wheeler, Donald, “Good Limits from Bad Data II”, Quality Digest, April 1997 SPCTool
Wheeler, Donald, “Good Limits from Bad Data Part III”, Quality Digest, May 1997 SPCTool
Wheeler, Donald J., “Myths About Shewhart’s Control Charts”, SPC Tool Kit column, Quality Digest, September, 1996 http://www.qualitydigest.com/sep96/spctool.html
Wheeler, Donald J., “Myths about Process Behavior Charts”, Quality Digest September, 2011 Myths About Process Behavior Charts
Wheeler, Donald, “What is a Rational Subgroup?”, Quality Digest, October 1997 SPCTool
Wheeler, Donald, “Rational Subgrouping”, Quality Digest, June 2015 http://www.qualitydigest.com/inside/quality-insidercolumn/060115-rational-subgrouping.html
Wheeler, Donald, “Rational Sampling”, Quality Digest, July 2015 Rational Sampling
Wheeler, Donald, “The Chart for Individual Values”, https://www.iienet2.org/uploadedfil...ransition/The Chart For Individual Values.pdf
Wheeler, Donald J., “A History of the Chart for Individual Values, The ultimate in homogenous subgroup”, Quality Digest July 2017 https://www.spcpress.com/pdf/DJW317.Jul.17.History of XmR Chart.pdf
Wheeler, Donald, “The Three-Way Chart”, Quality Digest, March 2017
http://www.qualitydigest.com/inside/statistics-column/three-way-chart-030617.html
Fantastic thank you. That's my Christmas reading sorted.
I have the raw data in an excel sheet. I can't see how to attach it.
Steve Prevette
Deming Disciple
I believe there is a limit on the number of posts you need to make before you can post an attachment. You could "private msgs" to Bev (and myself if you want) in the meanwhile. The newsletter archive for my ASQ section is Columbia Basin ASQ (asq614.org) but it only goes back to 2006, so I don't think the article is online. I'll need to search my files, I may still have a copy of the newsletter since I was also the editor of the newsletter at the time the articla was likely posted.
J Control Charts with different Sample Sizes Reliability Analysis - Predictions, Testing and Standards 2
S Are P-charts for a Particular Defect or can Different Defects be counted in one? Statistical Analysis Tools, Techniques and SPC 2
M Data Types and Charts - Process has different work types and sub-work types Statistical Analysis Tools, Techniques and SPC 19
Z How many charts we need? Different sizes of part produced in the same line Statistical Analysis Tools, Techniques and SPC 2
S Audit Duration Calculation - ISO9001 + EN9100 with different scope General Auditing Discussions 2
P Manufacturing facility moved to different location ISO 13485:2016 - Medical Device Quality Management Systems 10
S Confection validation on different batch sizes Qualification and Validation (including 21 CFR Part 11) 0
S Registation different version of Medical Devices & Germany competend authority EU Medical Device Regulations 3
A 510(k) and DeNovo on same medical device for different indications? US Medical Device Regulations 4
B Labeling question about different manufacturers on a single label Manufacturing and Related Processes 4
S Additional registration requirements for different EU-states on top of standard CE-registration? EU Medical Device Regulations 3
S Functionality of software in countries with different legal requirements IEC 62304 - Medical Device Software Life Cycle Processes 2
B EUDAMED 2 Different Registration EU Medical Device Regulations 1
qualprod Why Averages values are different? Capability, Accuracy and Stability - Processes, Machines, etc. 9
C Can I apply First Time Yield (FTY) for several products or processes of different nature? Manufacturing and Related Processes 5
V Product naming: Same name - different perfume & status CE Marking (Conformité Européene) / CB Scheme 0
Watchcat Mobile app - Different UDI for different smartphones? Other US Medical Device Regulations 7
H CAPA effectiveness verification methods for different types of CA Nonconformance and Corrective Action 10
D QMS Realignment after business splits into 2 different companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Is there a way to obtain redacted copies of IFU from a different manufacturer? EU Medical Device Regulations 2
S Device with different options for a sub-component - CE marking implications EU Medical Device Regulations 2
K UDI for two units with different S/N on the same package/case Other US Medical Device Regulations 10
A What is different between Field Safety Notice and Advisory Notice in U.S and EU? Document Control Systems, Procedures, Forms and Templates 7
R Whats different between these position CE Marking (Conformité Européene) / CB Scheme 10
T Different Formats for SOPs/Work Instructions? Document Control Systems, Procedures, Forms and Templates 5
N Medical device name in different countries EU Medical Device Regulations 4
K Different Indications for Use in Different Countries -- how to handle IFU? Other Medical Device Regulations World-Wide 4
John C. Abnet Terms- Different Items in a system ISO 26262 - Road vehicles – Functional safety 0
K How to handle GTINs for different configurations of one device with one part number? Other Medical Device Related Standards 0
D Different limits for new and worn gauges General Measurement Device and Calibration Topics 2
V Sister companies selling same medical device under different names ISO 13485:2016 - Medical Device Quality Management Systems 3
Y What are different Special Inspection Level 1-4 and General spesification 1-3 ? AQL - Acceptable Quality Level 0
K Why 'FD&C act section number' and 'section number' in the title of the act are different? US Food and Drug Administration (FDA) 7
K Biocompatibility Testing - Multile products of different sizes and shapes US Food and Drug Administration (FDA) 2
T Different Authorized Representative and distributors in Saudi Arabia Other Medical Device Regulations World-Wide 0
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R Yield Plot for different groupings Using Minitab Software 3
F How do you add accuracies for tools with different measurement devices? General Measurement Device and Calibration Topics 1
R Does any here use an internal auditing tool that works on different platforms? Internal Auditing 3
H What is different between PED certificate and CPR certificate? Manufacturing and Related Processes 2
R QMS Standard appilications on different Defense Sector Quality Management System (QMS) Manuals 1
A Statistical Analysis - Check if these organisms at different concentrations affect the growth of wheat seedlings Using Minitab Software 4
M Different procedure templates for different standards - We have two different management systems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Identical Sales Package in Different Countries Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
E Different requirements for Class II and Class III Medical Devices Other ISO and International Standards and European Regulations 5
C Subsidiaries; same/different Quality Policies? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
qualprod Controlling documents in two different Applications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A Touch current in single fault conditions test and earth leakage current in normal conditions test, are they really different tests? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
