1st Gage R&R Results help
SteelMaiden
#31
The last division I worked at had a laser mic that measured up to 4" I do believe that the name of the supplier was Lasermike Inc. (it was a while ago, so my memory is a little rusty) I don't have any sort of affiliation with them, just used the one piece of equipment, I was in charge of in-house calibrations at the time.
justncredible
#32
I am looking into laser mics, and I can only find a few that only go up to 2.56" ( http://www.keyence.com/products/vision/micrometer/micrometer.php ) , Do you have to have custom laser mics made up if you want to measure larger parts. We have a lot of parts from 1-3", and some from 3-4", which really struggles with Gage RR because a 3-4" mic is hard to handle.
Call them, they will demo a unit. Also I am sure they go up to 8 inches or more. They have dual head units. Is a free demo, and they will loan it out for a few weeks.
Also have you looked into the marposs stuff?
http://www.marposs.com/site/theproduct.asp
We had some marposs units on our machines, center grinders. You will have to call them to.
I am not affilated with either company.
http://www.marposs.com/site/family....0-->GAUGING AND CONTROL FOR GRINDING MACHINES
found what we used, it is the unit in the picture.
CMfgT
#34
Well I just got off the phone with a laser mic rep and the laser mics have the same resolution our hand mics do (0.000010" or 0.000015") I know the laser mic will be more repeatable than a hand mic, but the resolution will still hurt use in a gage RR right? I know my operators vary 4 tenths on the same part with the hand mic. I just don't know if the cost of 10K or more would be worth the expense.:bonk:
SteelMaiden
#35
it all depends on what your "real" tolerance requirements are. If you only need to measure to the nearest Thou, 0.000010" is more than enough accuracy. Your gage R&R should be based on the tolerance required by the specs you are working to, not the measuring tolerance.
bobdoering
Stop X-bar/R Madness!!
#36
I thought you said the digital mics had .0005 resolution, so .000010" should be much better resolution. The other issue is the influence of the operator on the repeatability. Laser mics remove all issues with gage pressure error and bias, so that helps quite a bit. I would recommend looking at Western air gages, though. They are not as universal, but they are less expensive. :cool:
CMfgT
#37
Our mic resolution is
0.00000 or .00005
so we have the tenths 0-9 but the next decimal place is 0 or a 5, basically we need to measure to the tenths, but can not follow the 10 to 1 rule because the next decimal place is either a 0 or a 5
sorry for the typo/confusion
justncredible
#38
Indicator mics do read to 50 millionths, but that is all. The laser mics are accurate to within 40 millionths and read to the 1 millionth.
So indicator mic read .00005
laser reads .000001 and is accurate to .00004
It gives you 1-9 numbers in the 10 millionths place. The indicator mic gives you a 50 only.
Get a demo unit and do a R&R on it. You should be able to pass ±.0001.
bobdoering
#39
Better yet, they should be evaluated to your control limits. Ideally, you chould have an ndc (calculated using control limits rather than tolerance) > 10 for statistical process control. :cool:
CMfgT
#40
I talked to a rep at Keyence and their laser mics to go .00005", and said you cannot go any further without being in a lab setting. Am I getting a sales pitch or the truth. Does anyone have a laser mic that goes to "laser reads .000001 and is accurate to .00004"
S Successful 1st Gage R&R Study...but Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
K China UDI Implementation for October 1st 2019 China Medical Device Regulations 4
J AS9100D Sections related to 1st Piece and In-Process Inspection Manufacturing and Related Processes 15
V Handling decomissioned line/equipment during 1st time product-based inspection US Food and Drug Administration (FDA) 1
A 1st Time Purchase of Aluminum Extrusion - First Article? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Effective 1st Piece Inspection Sign Off Procedure Quality Manager and Management Related Issues 8
S 1st AHWP-RAPS Joint Conference @ KL, Malaysia 2-3 Dec 2013 Other Medical Device Regulations World-Wide 2
A Publication Dates of MSA Manuals (1st & 2nd Ed.) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D QMS 1st Cycle - Indicators and Data ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
N 1st Shift vs. 2nd Shift Production Crews - How to end this war? Career and Occupation Discussions 15
W Is there an IEC 60601 3rd Edition 1st Amendment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Q Using Traceable Standards - AIAG MSA Manual Chapter II, Section B, 1st bullet Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Class I Medical Device - 1st notification and change notification EU Medical Device Regulations 4
K Raw Materials from 3rd World Countries vs. Finished Products from 1st World Countries Philosophy, Gurus, Innovation and Evolution 23
somashekar Medical Device Regulation - Singapore - 1st May 2010 Other Medical Device Regulations World-Wide 4
N What is a ?Reasonable? failure rate for an electronic device in the 1st year? Quality Tools, Improvement and Analysis 7
J FAA Training suggestions wanted for Sept 1st week Federal Aviation Administration (FAA) Standards and Requirements 5
N Nonconforming Product - 1st Piece Rejection Nonconformance and Corrective Action 3
G APQP 1st edition VS APQP 2nd edition - what are the main changes APQP and PPAP 2
CarolX Blueprint numbering for 1st Article submission Misc. Quality Assurance and Business Systems Related Topics 13
C Passed the CQE (Certified Quality Engineer) exam 1st time Professional Certifications and Degrees 23
J Final Inspection - 1st Article Dimensions before Anodize and Passivation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Digital Camera 1st DSLR Coffee Break and Water Cooler Discussions 10
ScottK ISO9001 - 1st Surveillance less than 6 months after registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R AIAG's FMEA Manual 4th Edition pushed back to 1st quarter 2008 FMEA and Control Plans 16
CarolX Definition 1st, 2nd and 3rd Party Audits - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 29
M Our 1st surveillance audit is coming soon - Any new input..or requirment..? IATF 16949 - Automotive Quality Systems Standard 6
SteelMaiden FDA approves 1st drug for obese dogs World News 6
P 1st Article Part - Recording All Dimensions vs. Critical Dimensions - AS9100B AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
B Should 1st Piece Process be a Control or a Line Item in the Control Plan FMEA and Control Plans 10
Marc Ford Has $1.19 Bln 1st-Qtr Loss on Job-Cutting Costs World News 15
J The AIAG's SPC manual 1st Edition and 2nd Edition - Differences? Statistical Analysis Tools, Techniques and SPC 2
Jeff Putman Meeting the 3rd Party Lead Auditor Prior to the 1st Audit IATF 16949 - Automotive Quality Systems Standard 4
Howard Atkins Errata for the AIAG's MSA Third Edition; 1st and 2nd printings Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
D What does 1st piece (1st Article) mean to a lay person like myself? IATF 16949 - Automotive Quality Systems Standard 12
A AIAG's SPC manual 2nd edition vs. 1st edition - Has it changed? Statistical Analysis Tools, Techniques and SPC 6
S Gmail invite - 1st asked - 1st served... After Work and Weekend Discussion Topics 5
C Consequences of Missing the Chrysler July 1st TS 16949 Deadline IATF 16949 - Automotive Quality Systems Standard 31
M 1st day success! QS-9000 - American Automotive Manufacturers Standard 5
G 1st Articles / Initial Sample Submissions - Requirements for submitting PPAPs Other ISO and International Standards and European Regulations 5
D 1st Internal Audit & Training Internal Auditing 8
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
