1st Gage R&R Results help
justncredible
#41
maybe try here.
http://www.betalasermike.com/component/option,com_docman/task,cat_view/gid,56
The place I was working at last we had z-mikes and we evaluated the keyence systems. There is a cost diffrence, and some major diffrences between the two. We also used air gages. ±.0002 was the normal tol we delt with, as it is a grind shop. Air and laser are the gages used in that industry. The indicator mics were for floor checks, as was snap gages. A keyence and air gaging you can use on the floor, it is not a good idea to use z-mikes on the floor. Z-mikes are alot cheaper, but are alot less robust.
Either way you are looking at $7,000 to $20,000 for a single unit. Even air will run you that when added up. You need to set up a stream of salesmen to come in and discuss options. As well as gage engineers from the bigger supply sales houses. I even belive Mitutoyo sales laser mikes, get them to send you a engineer for a few hours to sit down and discuss what your dealing with.
CMfgT
#42
Ok everyone,
I had a rep from keyence today and demo the optical mic. Did a gage RR and the results are attached with the data. What gives:frust:, the total rr was 52% AGAIN!! The rep kept saying fixturing is just as important, but I am kinda at a loss for words here. I thought the results would be better.
bobdoering
Stop X-bar/R Madness!!
#43
Might be worth getting Beta Lazermike and Mitutoyo laser micrometers in there. Your supplier should be able to give you the answer. First, they are right there. Second, the gage is their specialty.
The only other question might be was it done correctly - the exact same spot on the part each time? Pretty wild ranges for a laser mic. Part 6 and 7 were really kooky. Anything unusual about them?
Something has to give...:cool:
CMfgT
#44
I believe it was done correctly. I had the parts marked in the same exact spot and we had the spot facing the operator each time. The rep did mention fixturing was an issue, but this was an offline station, not in process. I can't imagine the results in process. I am going to have to check with another supplier.
#46
It looks like Kurt M. had some reproducibility problems on parts 6 & 7 as well as repeatability problems with parts 1, 2 & 6. Joe C. had Repeatability problems with part 8. I would investigate these issues first. Eliminating the out-of-control Ranges would reduce Rbar by approximately 40% reducing the Repeatability variation. Addressing Kurt's measures of parts 6 & 7 will also improve the Reproducibility.
The gage resolution looks fine. Start with the recommendations above and see what you get before ruling out the gage.
bobdoering
#47
I agree, the data does kind of lend itself to make one think that there is an operator variation problem. If it was a hand gage, I would look closely at the technique. What disturbs me is that this is a high resolution non-contact measurement system. Having that much operator influence on the measurement results for any reason does not impress me with that type of measurement system. I agree with CMfgT's reaction to the results. I would rather see some other systems before breaking my back to get one to work better by restricting operator process. :cool:
CMfgT
#48
That's the thing with my interpretation of the results. Yes there is operator variation, but that is the purpose of the optical mic (no contact gage) I wanted to take the human error out. I just didn’t expect that repeatability with a hand mic versus an optical mic to be the same. Especially because I am fighting employees (especially the ones who use a hand mic religiously) who do not think we need an upgrade. I kept saying, yes you can read a mic and might “have the touch” but John Doe from Mcdonald’s that we hired yesterday does not have the touch. And guess what, John Doe is the operator and inspecting the parts, your not. This is just frustrating because I want to make a non- contact system work here and prove to others the benefit.
Well I guess I need to decide if I even want to demo the optical mic for free. I am going to try and get a rep from Mitutoyo in here.
Thanks for all the help everyone.
justncredible
#49
Fixturing for the keyence is a issue, put two V-blocks on each side on a surface plate and just have the operators lay the parts on the v-blocks.
That was a concern about the keyence set up I had as well. They did leave the unit with us for a few weeks. So if you still have it try that. The beta laser mikes are way bigger units, they also are not made for the shop floor. There are still other options such as the marposs. Which goes in the machine and takes about 20 mins for the operator to set up.
S Successful 1st Gage R&R Study...but Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
K China UDI Implementation for October 1st 2019 China Medical Device Regulations 4
J AS9100D Sections related to 1st Piece and In-Process Inspection Manufacturing and Related Processes 15
V Handling decomissioned line/equipment during 1st time product-based inspection US Food and Drug Administration (FDA) 1
A 1st Time Purchase of Aluminum Extrusion - First Article? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Effective 1st Piece Inspection Sign Off Procedure Quality Manager and Management Related Issues 8
S 1st AHWP-RAPS Joint Conference @ KL, Malaysia 2-3 Dec 2013 Other Medical Device Regulations World-Wide 2
A Publication Dates of MSA Manuals (1st & 2nd Ed.) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D QMS 1st Cycle - Indicators and Data ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
N 1st Shift vs. 2nd Shift Production Crews - How to end this war? Career and Occupation Discussions 15
W Is there an IEC 60601 3rd Edition 1st Amendment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Q Using Traceable Standards - AIAG MSA Manual Chapter II, Section B, 1st bullet Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Class I Medical Device - 1st notification and change notification EU Medical Device Regulations 4
K Raw Materials from 3rd World Countries vs. Finished Products from 1st World Countries Philosophy, Gurus, Innovation and Evolution 23
somashekar Medical Device Regulation - Singapore - 1st May 2010 Other Medical Device Regulations World-Wide 4
N What is a ?Reasonable? failure rate for an electronic device in the 1st year? Quality Tools, Improvement and Analysis 7
J FAA Training suggestions wanted for Sept 1st week Federal Aviation Administration (FAA) Standards and Requirements 5
N Nonconforming Product - 1st Piece Rejection Nonconformance and Corrective Action 3
G APQP 1st edition VS APQP 2nd edition - what are the main changes APQP and PPAP 2
CarolX Blueprint numbering for 1st Article submission Misc. Quality Assurance and Business Systems Related Topics 13
C Passed the CQE (Certified Quality Engineer) exam 1st time Professional Certifications and Degrees 23
J Final Inspection - 1st Article Dimensions before Anodize and Passivation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Digital Camera 1st DSLR Coffee Break and Water Cooler Discussions 10
ScottK ISO9001 - 1st Surveillance less than 6 months after registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R AIAG's FMEA Manual 4th Edition pushed back to 1st quarter 2008 FMEA and Control Plans 16
CarolX Definition 1st, 2nd and 3rd Party Audits - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 29
M Our 1st surveillance audit is coming soon - Any new input..or requirment..? IATF 16949 - Automotive Quality Systems Standard 6
SteelMaiden FDA approves 1st drug for obese dogs World News 6
P 1st Article Part - Recording All Dimensions vs. Critical Dimensions - AS9100B AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
B Should 1st Piece Process be a Control or a Line Item in the Control Plan FMEA and Control Plans 10
Marc Ford Has $1.19 Bln 1st-Qtr Loss on Job-Cutting Costs World News 15
J The AIAG's SPC manual 1st Edition and 2nd Edition - Differences? Statistical Analysis Tools, Techniques and SPC 2
Jeff Putman Meeting the 3rd Party Lead Auditor Prior to the 1st Audit IATF 16949 - Automotive Quality Systems Standard 4
Howard Atkins Errata for the AIAG's MSA Third Edition; 1st and 2nd printings Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
D What does 1st piece (1st Article) mean to a lay person like myself? IATF 16949 - Automotive Quality Systems Standard 12
A AIAG's SPC manual 2nd edition vs. 1st edition - Has it changed? Statistical Analysis Tools, Techniques and SPC 6
S Gmail invite - 1st asked - 1st served... After Work and Weekend Discussion Topics 5
C Consequences of Missing the Chrysler July 1st TS 16949 Deadline IATF 16949 - Automotive Quality Systems Standard 31
M 1st day success! QS-9000 - American Automotive Manufacturers Standard 5
G 1st Articles / Initial Sample Submissions - Requirements for submitting PPAPs Other ISO and International Standards and European Regulations 5
D 1st Internal Audit & Training Internal Auditing 8
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
