21 CFR 820 Compliant way to use Kaizen to address Nonconformances
ValGal
Hey there!
Would you say that there is a 21 CFR 820 compliant way to use Kaizen to address NC in medical device manufacturing?
Any ideas or opinions?
This is in Japan, by the way. I am really uncomfortable with Kaizen so I would love to hear for others!
Thank you for your help!!!!!!!!!!!!!!
v9991
'Kaizen' could be certainly a tool
* integrated with 'preventive action' section
* this could also be extended to the correction action section; but with a specific time line and focus-area i.e.,root cause)
about the 'part 820 compliant way', need to focus on
* formalize/outline the kaizen steps in the SOP
* record various activities/steps of implementation (evidence!...records)
:2cents:
ValGal
Thank you!
I wanted to make sure that others have "heard" or actually made a Kaizen SOP. The people I am working with seem quite put off on the idea.
v9991
Thank you!
IF the question was towards, 'intent'of making the 'kaizen' as a tool for implementation of NC-CAPA ==> would obviously lead to 'integrating same into SOP' an obvious step and appreciable.
this is to enable
* a harmonized and sustainable practice
* retaining the spirit of "doing as it is written and writing as you do it" ; and the level of details could be differed to an annexure which broadly entails the framework, to a 'format' which enables you to evolve a template for implementation steps.
* traceable - audit-able - compliant practice.
IF you meant otherwise, 'feasibility of adopting kaizen as a tool for CAPA system implementation ' without affecting the 'compliance; aspect to regulations/auditability ....==> it can very well be done,
viz., SOP deals with the auditable-minimum-criteria (viz., follow up for completion-timelines, trending of NC, CAPA etc)
and process of kaizen-implementation would be driven outside SOP, with "minimum or even no-reference" to it.
however, personally, the SOP has to have representation to the implementation process/steps. (viz., if the tracking is through SAP or any other software tool, it is required to add an reference in SOP!)
in this case, if we use kaizen! as an improvement tool, it ought to have minimal reference.
:2cents:
supplement response.,
true, SOP for kaizen, or integrating kaizen into QMS would not only raise eye brows, but when implemented in a 'compliant' manner, it would also turn heads;
integration of QMS tool into QMS-systems&processes would really shift the definition from 'compliance to standards' to 'quality_improvement'.
kaizen integration would boost the "continuous improvement" (read preventive actions" process; today this is more or less tightly coupled with the QMS-CAPA, however there is a opportunity ( not long before it becomes a regulatory requirement wrt expectation of Continuous improvement.)
Ronen E
Problem Solver
Moderator
Hey there!
Why should the "part 820 way" of addressing NC be conflicting with Kaizen in the first place?
If you search Elsmar for "Kaizen" you'll find a lot of interesting (and possibly useful) reading. You'll also find conflicting opinions about Kaizen.
v9991
I guess the question is about including 'kaizen' process as part of SOP.
reluctance could be that, it is not required as per 'requirements' ( traditionally/typically the procedures emphasize more on procedure not on tools , )
Further, integrating tool could place further expand the exposure and scope of compliance.!!!
Ronen E
Problem Solver
Moderator
Kaizen is an approach / state of mind, and also a technique (or set of techniques). Why should there be a problem with the organization adopting it in a formal way, ie capturing it in an SOP? Would doing it without an SOP make it better? I think the opposite, it would only make it less consistent, more prone to arguments and less committed to.
Now, in general there is no conflict between "the part 820 way" and making something that isn't spelled out in part 820 an SOP. A problem may occur only if that SOP requires something that is against an explicit part 820 requirement. The title "Kaizen" is too general to comment on whether or not "making it an SOP" will result in a clash with a part 820 requirement. Make sure that it won't, and it won't... As a general statement, I don't see why a Kaizen implementation should contain such a conflicting requirement.
Yes, that can be an issue - management might question the necessity of a perceived "extra" beyond the regulatory minimum (though in my opinion it's not really an extra). But that's not unique to Kaizen.
Not sure what you mean. A procedure is just a way of providing instructions/guidance, typically for something sequential. Most methodical tools can be covered by procedures.
v9991
:agree:
I take same line here (ref. initial responses); and, in earlier-post I was just reflecting on the counter points from 'practice or trend' of handling SOPs.
Ajit Basrur
Hey there!
Hello ValGal,
First of all, there is no "21 CFR 820 compliant way". The 21 CFR Part 820 is a regulation and tells us what to do and does not tell "how" to do. The "how" is up to the manufacturer to contain the nonconformities to meet the 21 CFR Part 820.90 requirements.
Kaizen is a Japanese word for "continuous improvement", and agree with Ronen that there is no harm in including the tools in the SOP.
Refer Wikipedia reference-linkKaizen
D Need advice in streamlining antiquated 21 CFR 820 compliant QMS Quality Manager and Management Related Issues 2
A TUV Audits - 21 CFR 820 General Auditing Discussions 6
S Records - Do's and don't' of record entries (FDA - 21 CFR 820) Records and Data - Quality, Legal and Other Evidence 13
T 21 CFR 820.20 - Quality Planning Requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M 21 CFR 820 vs 21CFR820 vs 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
A 21 CFR 820 - Risk Management - Looking for some guidance US Food and Drug Administration (FDA) 3
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
D ISO 13485, FDA 21 CFR 820 and Auditing the Accounting Department ISO 13485:2016 - Medical Device Quality Management Systems 5
Ed Panek 21 CFR Part 820 - FDA Label Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
R Addressing training requirements - 21 CFR Part 820.25 (1) & (2) Other US Medical Device Regulations 4
R How to improve a Validation program and procedures to FDA (21 CFR part 820) & ISO13485 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Marc Problem with 21 CFR Part 820 - US FDA Quality System Regulations (QSR) sub-forum link - 2 May 2019 Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
R 21 CFR Part 820 Contract Manufacturer of Medical Device Component 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
N Change Control - Compliance with FDA 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
D 21 CFR Part 820 (Subpart A) - Question about "Authority" 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R RUO audits - CFR 820.22 and ISO 13485 8.2.4 Internal Auditing 3
A Training as well as certifications for ISO 13485:2016, 21 CFR 820... Training - Internal, External, Online and Distance Learning 5
K Production Unit Labeling - 21 CFR 820.184.e 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
R 21 CFR Part 820.186 - Types of Quality System Records Document Control Systems, Procedures, Forms and Templates 1
M Does the Scope of 21 CFR Part 820.72 (Equipment) apply to Design? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C 21 CFR Part 820.184 - Label Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
shimonv 21 CFR 820.20(d) says: Each manufacturer shall establish a Quality Plan 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
V Upgrading Systems from CFR 211 to CFR 820 (drug+device combination) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
S Looking for a checklist comparing ISO 13485:2016 and 21 CFR Part 820 ISO 13485:2016 - Medical Device Quality Management Systems 14
Q Internal Audit of Product Quality Complaint System (21 CFR Part 820) Customer Complaints 9
R Managing Employee Training Files - 21 CFR Part 820.25 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M Release authorization before or after packaging per 21 CFR 820.80(d)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J Minimum staff per 21 CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Does a process map satisfy 21 CFR 820.20(d) (Quality Plan)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R Calibration of processing equipment - 21 CFR 820.70 Production and process controls 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Issues with UDI additions to 21 CFR 820 requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Interpreting Process Controls - 21 CFR Part 820.70(a) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S How others have defined "reaudits"? 21 CFR Part 820.22 Internal Auditing 1
M FDA 21 CFR 820.250 - Does "valid statistical" always mean math? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
J Document Control Features (Document Content Requirements) and 21 CFR 820.40 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S 21 CFR Part 820.40(b) Clarification on Required Document Approvers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
R Where to find 21 CFR Part 820 Translated into Czech, Spanish, and German 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
N Certificate of Compliance from a Sister Company for FDA 21 CFR 820 Exemption 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Does FDA expect suppliers to be independently assessed to 21 CFR Part 820 ? US Food and Drug Administration (FDA) 4
A Effective Date (of Documents) issue outlined in 21 CFR Part 820.4 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
L Mobile Medical App - Understanding 21 CFR Part 820 Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
T "Special Process" Validation Requirements (21 CFR Part 820) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
Y ISO 13485:2003 &FDA QSR (21 CFR 820) Quality Manual,34 Procedures and Form Book, Video, Blog and Web Site Reviews and Recommendations 8
R Policy Statement for FDA CFR 820 Acceptance Activities of Incoming Products. Other US Medical Device Regulations 1
shimonv Storage of finished medical devices per 21 CFR Part 820.150 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
M Does 21 CFR 820.80 (b) require a Supplier to have Receiving Inspection? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
I Does being a subsidiary fully absolve company B from complying with 21 CFR 820? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A Help me understand the applicability of 21 CFR Part 820.198 (Customer Complaints) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A Do controlled documents require a signature on every page as per 21 CFR 820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
P Internal Audit Reports reviewed by management? 21 CFR 820.22 Interpretation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
