21 CFR 820 Record Control Requirements
MIREGMGR
#11
Note however that there's a valid question, not substantively answered yet by the FDA as far as I know (and I've asked them directly), as to whether some form of electronic capture or recording of a signed document in a 21CFR Part 11 context may become a valid record in and of itself, including a record of the signature, sufficient to replace the original document for regulatory purposes so that it would be permissible to destroy the original document.
That for instance might consist of a record-batch scanning or photographing procedure, with a signature per batch by the scanning individual indicating that they had performed the scanning and that the records they had scanned were original, apparently unmodified and were physically signed and dated.
We've been told that such a process isn't acceptable at this time, but that it's being considered.
Such a process of course would be substantially different from transcription of data into a spreadsheet, which inherently does not capture the signature involved or allow any inspection of the nature of the data record.
Mark75
#12
Thanks for all the input pertaining to this topic. Sometimes the regs are not very specific, and I think they were probably written this way so that each company can has some flexibility to define for themselves the best way to go about meeting the basic requirements. However, this can lead to many different interpretations and this is why I also try to refer to guideance documents as well as 483s and warning letters by the FDA to help understand the interpretation from the FDA's point of view.
My point of view has been that data related to the process that has been determined to be a required part of the DHR must be defined (established) and maintained to demonstrate that the device is mfg'rd in accordance w/ the DMR and the req's of section 820.184. In order to define and maintain the data that must be captured you have to control the records (forms, notebooks, etc) via a change control process (820.40), or other controls when notebooks are concerned. 820.184(d) also makes reference to established acceptance records as part of the DHR. According to 820.80 (Acceptance Activities), section 820.80(e) specifically states that acceptance activities will be documented and the records will include information such as the signature and date of the individual(s) conducting the acceptance activities <820.80(e)(4)>, and also states these records will be part of the DHR <820.80(e)(5)>. Section 820.70(a) also states that each manufacturer shall develop, conduct, "control", and monitor production processes, which includes monitoring and control of process parameters. To "control" the methods for monitoring, this brings me back to 820.40.
I could maybe buy-off on justification that a controlled procedure defines what type of information must be collected when non-controlled methods for collecting data are used (w/ the exception of using sticky notes). However, I would still recommend establishing controlled records as attachments to this procedure as an opportunity for improvement. I don't see any way around not maintaining the original, signed and dated records as part of the DHR.
jkuil
#13
Subpart M of 21 CFR part 820 deals with records
  • In 820.180 General requirements: "and shal be stored to minimize deterioration and to prevent loss" Is essence you have lost your source documents and can not provide full traceability of data
  • In 820.180b "All records required by this part shall be retained..."
  • Section 820.184 specifies the records you generate per batch, lot or unit of products. Your laboratory may fall under this category
  • If they are not product specific they are quality system records as specified under 820.186
maxenix
#14
IMO, these violations include, but are not limited to, the following:
1 Failure to establish and maintain adequate DMR (b) Production process specifications ncluding the appropriate equipment specifications, production methods, production procedures, and production environment specifications,as required by 21 CFR 820.100. For example:
a. The blank forms for recording the data are not a part of DMR since you do not have such controlled form.(SEE QS MUANL:12 PRODUCT EVALUATION)
2 Failure to ensure that the QSR is prepared and approved in accordance with § 820.40 required by 21 CFR 820.186. For example:
a. The blank forms for recording the Lab test results ( process parameter checks & Quantities of product produced & scrapped )are not prepared and approved in accordance with 21 CFR 820.40.
3 Failure to conduct, control, and monitor production processes to ensure that a device conforms to its specifications as required by 21CFR 820.70, For example:
a. You can't supply original records of Lab test results and so on since those records are thrown away. (FDA think:if it is not written down, it never happened, only a transfer done (from paper to electronics)).
4 Failure to ensure the authenticity, integrity of the electronic records requied by 21 CFR PRAT 11.30.For example:
a. Do not transfer records in a authenticity and integrity way as what you says.
Y
yeshpal
#15
Aren't they meeting that requirement by noting the data on a "scratch pad" and then entering it into excel?
Hi Al Rosen,
"Scratch Pad" (source document) should be maintained (retention-Archival) for compliance, Quality and Regulatory revival etc...; if it were to be under Regulatory compliance.
My Perception,:cool:
Thanks & Regards,
Yeshpal Mathangi
Al Rosen
#16
Hi Al Rosen,
Thanks & Regards,
Yeshpal Mathangi
Yes, that may be true. What if they didn't have a interim step and entered it directly to electronic format?
Y
yeshpal
#17
Hello Al Rosen,
Well in that case there should be Authorized written procedures to establish compliance (21 CFR 820.20(e)) and for electronic format as stated by you then there should be compliance with 21 CFR part 11 (electronic records and signatures) and Audit trail.
My perception only.:cool:
Thanks & Regards,
Yeshpal Mathangi
S Records - Do's and don't' of record entries (FDA - 21 CFR 820) Records and Data - Quality, Legal and Other Evidence 13
B 21 CFR 820.180 Quality Record Retention Requirements Document Control Systems, Procedures, Forms and Templates 1
W Quality System Record as required by CFR 21 Part 820.186. ISO 13485:2016 - Medical Device Quality Management Systems 13
M Quality Record Retention Time - ISO 9001 vs. CFR 820.180(b) Records and Data - Quality, Legal and Other Evidence 25
A TUV Audits - 21 CFR 820 General Auditing Discussions 6
T 21 CFR 820.20 - Quality Planning Requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M 21 CFR 820 vs 21CFR820 vs 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
A 21 CFR 820 - Risk Management - Looking for some guidance US Food and Drug Administration (FDA) 3
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
D ISO 13485, FDA 21 CFR 820 and Auditing the Accounting Department ISO 13485:2016 - Medical Device Quality Management Systems 5
Ed Panek 21 CFR Part 820 - FDA Label Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
R Addressing training requirements - 21 CFR Part 820.25 (1) & (2) Other US Medical Device Regulations 4
R How to improve a Validation program and procedures to FDA (21 CFR part 820) & ISO13485 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Marc Problem with 21 CFR Part 820 - US FDA Quality System Regulations (QSR) sub-forum link - 2 May 2019 Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
R 21 CFR Part 820 Contract Manufacturer of Medical Device Component 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
N Change Control - Compliance with FDA 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
D 21 CFR Part 820 (Subpart A) - Question about "Authority" 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R RUO audits - CFR 820.22 and ISO 13485 8.2.4 Internal Auditing 3
A Training as well as certifications for ISO 13485:2016, 21 CFR 820... Training - Internal, External, Online and Distance Learning 5
K Production Unit Labeling - 21 CFR 820.184.e 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
R 21 CFR Part 820.186 - Types of Quality System Records Document Control Systems, Procedures, Forms and Templates 1
M Does the Scope of 21 CFR Part 820.72 (Equipment) apply to Design? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
V 21 CFR 820 Compliant way to use Kaizen to address Nonconformances Nonconformance and Corrective Action 9
C 21 CFR Part 820.184 - Label Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
shimonv 21 CFR 820.20(d) says: Each manufacturer shall establish a Quality Plan 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
V Upgrading Systems from CFR 211 to CFR 820 (drug+device combination) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
S Looking for a checklist comparing ISO 13485:2016 and 21 CFR Part 820 ISO 13485:2016 - Medical Device Quality Management Systems 14
Q Internal Audit of Product Quality Complaint System (21 CFR Part 820) Customer Complaints 9
R Managing Employee Training Files - 21 CFR Part 820.25 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M Release authorization before or after packaging per 21 CFR 820.80(d)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D Need advice in streamlining antiquated 21 CFR 820 compliant QMS Quality Manager and Management Related Issues 2
J Minimum staff per 21 CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Does a process map satisfy 21 CFR 820.20(d) (Quality Plan)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R Calibration of processing equipment - 21 CFR 820.70 Production and process controls 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Issues with UDI additions to 21 CFR 820 requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Interpreting Process Controls - 21 CFR Part 820.70(a) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S How others have defined "reaudits"? 21 CFR Part 820.22 Internal Auditing 1
M FDA 21 CFR 820.250 - Does "valid statistical" always mean math? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
J Document Control Features (Document Content Requirements) and 21 CFR 820.40 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S 21 CFR Part 820.40(b) Clarification on Required Document Approvers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
R Where to find 21 CFR Part 820 Translated into Czech, Spanish, and German 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
N Certificate of Compliance from a Sister Company for FDA 21 CFR 820 Exemption 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Does FDA expect suppliers to be independently assessed to 21 CFR Part 820 ? US Food and Drug Administration (FDA) 4
A Effective Date (of Documents) issue outlined in 21 CFR Part 820.4 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
L Mobile Medical App - Understanding 21 CFR Part 820 Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
T "Special Process" Validation Requirements (21 CFR Part 820) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
Y ISO 13485:2003 &FDA QSR (21 CFR 820) Quality Manual,34 Procedures and Form Book, Video, Blog and Web Site Reviews and Recommendations 8
R Policy Statement for FDA CFR 820 Acceptance Activities of Incoming Products. Other US Medical Device Regulations 1
shimonv Storage of finished medical devices per 21 CFR Part 820.150 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
M Does 21 CFR 820.80 (b) require a Supplier to have Receiving Inspection? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
