21 CFR part 11 compliant Electronic Document Management Systems
abchris
I work for a small biotech company (approx 40 employees) and we currently use an entirely paper based system for all of our documentation. We would like to migrate to an electronic document management system that is 21 CFR part 11 compliant AND not spend a fortune (target of less than 50k). This would ideally also include an easy way to link training records to SOPs too.
Does anyone have any first hand experience in assessing and implementing such a system? What are the important things to look for and questions to ask?
Q
QA_chick
Re: Electronic Document Management Systems
I am not familiar with the standard(s) you cited, but our company is certified to ISO 9001:2000 with HACCP based food safety management system.
We are using a web based version of CompliantPro (vendor: IBS-US) which is designed to manage a variety of documentation electronically (i.e. SOPs, CA/PA, internal assessments, calibration and maintenance, etc. etc.) including the training record linkage to SOPs that you specifically mentioned.
I was not involved in the product sourcing process, so I cannot comment on what other documentation management products are commercially available.
There is a significant learning curve in the configuration (front end work) but once configured, the program is very easy to use and effective. However, if implementing change at your company is already 'challenging' (as it is here), a business tool such as CompliantPro won't help with that...:nope:
tsmith7858
Do a search of the cove (or google) for document software or QMS Software and you will find a lot of threads on the topic.
I searched last year for a company I was working for and found that most packages run 10K to 30K depending on licensing and how many seats you need. (There are also annual service fees for most)
A few that I look at included Q-Pulse, MetricStream, Harrington, Interax, CEBOS, Qudos and ISO SytemPlus.
I was not looking for 21 CFR part 11 but I know many had it.
timference
There is a company called desert sky software. Look them up. They have a very good doument system that is web based. you can host or they will for you. If you have a goood network and a reliable back up system, hosting yourself is a lot cheaper
Out of the box is pretty good. We had to have some customization added but still spent less the 20K for 10 concurrent users. It also has a workflow for document changes, routing, approvals, distribution, etc. it even has a way to send via email and send to parties without giving them acces to the web system. It is a very good system and is compliant with any standards you need to address
Helmut Jilling
Auditor / Consultant
I would recommend an inexpensive step first. Put all your controlled documents in a folder and write protect the folder, so it is read-only for all the users except your document manager. Or, scan them into PDF files. Try this before you invest $$$ in a rigid database.many companies find this is sufficient.
somerqc
The only thing I would add to Helmut's comments is that it may be worth the investment of software if there is a high need of approvals required and there are large geographic regions separating the various approval authorities.
Otherwise, like Helmut, I KISS when it comes to document control. Oh ya, one other tip - make sure everyone knows to 'click' the read-only button :frust:
RickRay
We use Agile in our facility, it works fine as a PLM. It could easily be used for what you are looking for. :2cents:
BradM
I have seen GMPharma used. It's not my favorite, and I am unsure of the cost. But I do know it is ER/E-sig compliant.
Now... that we've covered that I have used all the fancy, expensive programs, allow me to make a suggestion: Heavily consider Helmut's advice.
Being in calibration, we had about 50 technical procedures. We intentionally left it out of the "document management system" for several reasons. Primarily, you really, really get locked down in them.
Here's what we did. We had a system coordinator, and all the procedures were in Word. She would put them on the network drive, but they were read only. So, I need to make a revision. She would send a draft. If we really needed to (and there were a few times), we could implement a new revision in 20 minutes or less.
I would do a change form, have two people sign it. She would sign it once it was updated, and we're done. You could make it more simple, by having a logbook for signatures, and archiving that once a year. You would not even need change forms.
I guess I am trying to persuade you to stay simple. When you get one of those systems, you have to validate it, set up control levels and systems, be subject to obsolete versions, need for backup, archiving, etc. etc. For your size organization, it could weigh it down quite heavily.
:tg:Take that money and invest in a good calibration program!! Ha! That's my pet project, if you did not know!!:lol:
Q
quality.shesha
In our company we are paper based for all documentation purpose. Apart from this EDMS (Electronic Document Management System) is there a way out?
In our org many of them hate using papers, which is for good, and they want to have these approvals thru emails.
So, does ISO, AS & CMMi allows us to do so (Approval thru emails)?
Our's is a Engineering Services company.
S Is Adobe Sign - E-signature for QMS documents - 21 cfr part 11 compliant? ISO 13485:2016 - Medical Device Quality Management Systems 2
M Suggestions for Electronic Signature Software (FDA 21 CFR Part 11 Compliant) Qualification and Validation (including 21 CFR Part 11) 12
A Alternative to keeping hard copy records that is 21 CFR part 11 compliant Document Control Systems, Procedures, Forms and Templates 0
K 21 CFR Part 11 (and EU) compliant Digital Signatures on a Production Line Other US Medical Device Regulations 5
M How to validate a system to make it compliant with 21 CFR Part 11 Qualification and Validation (including 21 CFR Part 11) 2
D FDA 21 CFR Part 11 Compliant Digital (electronic) Signatures Document Control Systems, Procedures, Forms and Templates 7
D Affordable electronic CAPA system (compliant to FDA 21 CFR Part 11) ISO 13485:2016 - Medical Device Quality Management Systems 1
J Software Outsourcing - 21 CFR Part 11 and HIPAA Compliant Applications Career and Occupation Discussions 1
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
D CFR Title 14: Aeronautics and Space PART 120—DRUG AND ALCOHOL TESTING PROGRAM Federal Aviation Administration (FAA) Standards and Requirements 3
M 21 CFR 820 vs 21CFR820 vs 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
Anonymous16-2 21 CFR Part 11 - Steps to take if we want to validate an electronic system Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
A 21 CFR part 11 - section 11.100 - Electronic Signature Certification Other US Medical Device Regulations 6
L Wearables 21 CFR Part 11 compliance Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
Ed Panek 21 CFR Part 820 - FDA Label Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
F 21 CFR Part 11 - Implicit requirements - Validation plan for a Software as a Service Other US Medical Device Regulations 1
C 21 CFR Part 11- What about handwritten signatures? Other US Medical Device Regulations 1
Ed Panek Do Cloud services require 21 CFR Part 11 compliance? Qualification and Validation (including 21 CFR Part 11) 7
QIE FDA 21 CFR Part 11 "Meaning of Signature" Other US Medical Device Regulations 6
J Business Intelligence and 21 CFR Part 11 Compliance Qualification and Validation (including 21 CFR Part 11) 1
R Addressing training requirements - 21 CFR Part 820.25 (1) & (2) Other US Medical Device Regulations 4
R How to improve a Validation program and procedures to FDA (21 CFR part 820) & ISO13485 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Marc Problem with 21 CFR Part 820 - US FDA Quality System Regulations (QSR) sub-forum link - 2 May 2019 Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
R 21 CFR Part 820 Contract Manufacturer of Medical Device Component 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C Signature manifestations - 21 CFR Part 11 Qualification and Validation (including 21 CFR Part 11) 4
I GMP 21 CFR Part 11 Electronic Records Compliance Project Help Qualification and Validation (including 21 CFR Part 11) 9
D Use of password managers on validated computer systems (21 CFR Part 11) Medical Information Technology, Medical Software and Health Informatics 2
Q 21 CFR Part 111 - Requirements for Dietary Supplement Manufacturing Water Quality Document Control Systems, Procedures, Forms and Templates 1
N Change Control - Compliance with FDA 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
D 21 CFR Part 820 (Subpart A) - Question about "Authority" 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
D 21 CFR Part 11 - Electronic Signature Management SOP Other US Medical Device Regulations 0
I 510(k) Raw Data from Studies - 21 CFR Part 11 Compliance Qualification and Validation (including 21 CFR Part 11) 4
V Use of e-records and e-Signatures in Clinical Investigations Under 21 CFR part 11 Q&A Qualification and Validation (including 21 CFR Part 11) 1
R 21 CFR Part 820.186 - Types of Quality System Records Document Control Systems, Procedures, Forms and Templates 1
M Does the Scope of 21 CFR Part 820.72 (Equipment) apply to Design? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C Validation of Applications in a Cloud, CFR 21 part 11 (Environmental Monitoring) Other US Medical Device Regulations 3
C 21 CFR Part 820.184 - Label Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
L MDR (Medical Device Reporting) under 21 CFR Part 803 Other US Medical Device Regulations 5
Q How to apply 21 CFR Part 11 and/or cGMP in the Life Sciences industry Qualification and Validation (including 21 CFR Part 11) 3
L Design software for a spectrophotometer for 21 CFR Part 11 compliance Qualification and Validation (including 21 CFR Part 11) 1
Pmarszal Clarification for 21 CFR Part 11.100 - General Requirements Other US Medical Device Regulations 14
shimonv CFR Part 830.50 - Changes that require use of a new device identifier Other US Medical Device Regulations 2
S Looking for a checklist comparing ISO 13485:2016 and 21 CFR Part 820 ISO 13485:2016 - Medical Device Quality Management Systems 14
Q Internal Audit of Product Quality Complaint System (21 CFR Part 820) Customer Complaints 9
R Managing Employee Training Files - 21 CFR Part 820.25 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M Treatment system data analysis - Subject to CFR part 11? Entire system? Qualification and Validation (including 21 CFR Part 11) 7
J Minimum staff per 21 CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Interpreting Process Controls - 21 CFR Part 820.70(a) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M Help interpreting 21 CFR Part 806 (corrections and removals) Other US Medical Device Regulations 1
S How others have defined "reaudits"? 21 CFR Part 820.22 Internal Auditing 1
