21CRF820.70(g)(2) Maintenance Inspection Interval
21CRF820.70(g)(2) states “Inspection. Each manufacturer shall conduct periodic inspections in accordance with established procedures to ensure adherence to applicable equipment maintenance schedules. The inspections, including the date and individual(s) conducting the inspections, shall be documented.”
The majority of our equipment is maintained on yearly intervals however there are a few which require weekly tasks to be completed.
I was unsure if this inspection can lump multiple equipment together or if an inspections needs to be completed for individual equipment?
Is there any guidance on the frequency of the inspections based on the maintenance schedule?
ScottK
Not out of the crisis
Hi Logan, welcome
There is really a great deal of flexibility in this. FDA doesn't mandate frequency and will usually be happy with the equipment manufacturer's recommended schedule. Individual inspectors will have opinions but the standard is pretty open.
How you document it is up to you - just be consistent and document how you will do it and make sure the documented checks are kept in accordance with record retention procedures
If you have, say, a weekly checklist that has all machines on it where you walk the lines and check coolant levels of each machine that's fine. It's also fine if you have a weekly check list for each machine.
From a practical perspective I've always had everything separated by machine so I can easily pull all the records for a given machine and not have to sort through group records. So I might have a binder for each CNC machine in my shop where all the completed inspection forms are stored. (I've also worked with CMMS systems, which are nice)
As far as frequency this would be a combination of manufacture's recommended intervals and past experience... bring risk into the equation here and think "What's the risk to the product if I check the oil level monthly rather than weekly? What can happen if the oil goes too low? What's the likelihood that it will, base on history?"
In my experience most equipment has short term and long term things to monitor. And some equipment now has alarms that will notify you that maintenance is required - that can be factored in to eliminate periodic checks.
The most important things are: be consistent and have rationale based on risk to the product documented if schedules deviate from a manufacturer recommendation.
Thanks for your response Scott. Am i right in assuming that the Maintenance Schedule and the Inspection are two separate records?
For example if i have a Lathe with a folder containing the Maintenance Schedule and Record which I keep with the instrument. When the daily/weekly/monthly maintenance is required it is completed and signed off.
This seems to cover 21CFR820.70(g)(1):
"Maintenance schedule. Each manufacturer shall establish and maintain schedules for the adjustment, cleaning, and other maintenance of equipment to ensure that manufacturing specifications are met. Maintenance activities, including the date and individual(s) performing the maintenance activities,
shall be documented. "
Do I then also need a separate document where an inspection of this folder is completed to ensure the maintenance is being done? Is this what 21CFR820.70(g)(2) is referring to?
Or does the inspection form part of the maintenance record. Using my example of the Lathe. One item may be a weekly task "Inspect that lead screw is oiled" i inspect it and find it sufficient so i note this and sign off on it. This is my documented inspection. Next week i inspect it and find it insufficient and so i note it and oil the lead screw. This would be my documented inspection and maintenance.
I hope you can understand where my confusion is.
ScottK
They can be the same document or different documents.
Whatever works best for your company.
You can make the schedule a form that is filled out as 2018 progresses and at the end of the cycle you save the record and print a new one for 2019.
Or you can have a documented annual schedule, and then write the results in a log book, which becomes your record.
If you have a maintenance work order system you'd probably go with something similar to the latter of these. Example: A procedure that outlines maintenance steps and intervals for each piece of equipment, documenting the actual work on the work order and keeping that as the record.
So as to your example... Yes. you must document the requirement and frequency somewhere. Then you must document that you did it as required. How you do that it up to your business.
D Preventive Maintenance vs. General Cleaning ISO 13485:2016 - Medical Device Quality Management Systems 2
F Component maintenance qualification - Regulation (EU) No 1321/2014 Article 5 EASA and JAA Aviation Standards and Requirements 6
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
S Quality management system (Well head installation & maintenance) Quality Management System (QMS) Manuals 5
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
A Feedback of typical maintenance problems with LMI digital probes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Are there ISO9001:2015 Requirements for Preventive Maintenance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
Q Software SOP - Use and maintenance of an ERP system Software Quality Assurance 6
R Robotic weld cell - maintenance issues - expertise needed Manufacturing and Related Processes 0
J Requirements for Layered Process Audits including Maintenance, Shipping, Receiving IATF 16949 - Automotive Quality Systems Standard 4
D Preventive Maintenance Implementation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
D Preventative Maintenance for Gages, handtools etc Other Medical Device Regulations World-Wide 1
C Maintenance of Product Technical Documentation EU Medical Device Regulations 3
R IATF 16949 Clause 8.5.1.6 a) maintenance and repair facilities - Production tooling management and personnel IATF 16949 - Automotive Quality Systems Standard 4
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
B Total Productive Maintenance - Company Transport IATF 16949 - Automotive Quality Systems Standard 2
P Minor Non-Conformance - Maintenance Records Not Fully Completed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
I Tool maintenance and calibration procedure - Calibrating tools/equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K IATF16949 8.5.1.5 Total Productive Maintenance IATF 16949 - Automotive Quality Systems Standard 9
J FAA Maintenance Requirements - DER Repair to a PMA Part Federal Aviation Administration (FAA) Standards and Requirements 1
K Maintenance requirements for Production Equipment in AS9100D General Auditing Discussions 8
T Part 145 Maintenance Station S/N ESN Character Requirements EASA and JAA Aviation Standards and Requirements 3
M Preventive Maintenance Spreadsheet in Excel Quality Assurance and Compliance Software Tools and Solutions 2
B IATF 16949 Section 8.5.1.5 (Total Productive Maintenance) IATF 16949 - Automotive Quality Systems Standard 19
D Does AS9100 certified OEM need AS9110 if no maintenance is provided? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
N Laboratory Audit Nonconformance - Maintenance of Standards ISO 17025 related Discussions 10
A Technical File Maintenance - Old generation product EU Medical Device Regulations 4
L Seeking help in Basic Maintenance Knowledge Manufacturing and Related Processes 4
M CAPA due to Consumer not following Maintenance Instructions... Nonconformance and Corrective Action 9
S Preparing a Turtle Diagram for Maintenance Department Misc. Quality Assurance and Business Systems Related Topics 2
U Relating maintenance to product quality Manufacturing and Related Processes 5
S ISO 9001 Audit requirement for maintenance department ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
C Service and maintenance in an initial importer facility USA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M Total Productive Maintenance vs. Lean, Six sigma, Business Process Reengineering, etc Quality Tools, Improvement and Analysis 9
A Electronic Maintenance Records stored in a machine ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A How to create a Maintenance procedure based on TS 16949 Requirements IATF 16949 - Automotive Quality Systems Standard 5
N ISO 9001 Quality Manual for an O&M (Operations and Maintenance) Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
S Predictive Maintenance Format / Example Misc. Quality Assurance and Business Systems Related Topics 4
T Are Customers required to follow a Manufacturers Maintenance Schedule? ISO 13485:2016 - Medical Device Quality Management Systems 3
E Manufacturer Responsibility (vs. User/Customer) for Preventive Maintenance/Repair 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A Technical Files/Dossier/STED File Maintenance for Notified Body Audiits Other Medical Device Regulations World-Wide 2
C Document Revision for each new Preventative Maintenance Checklist? Document Control Systems, Procedures, Forms and Templates 5
M Where to start Maintenance Function Kaizen Lean in Manufacturing and Service Industries 4
A Assessing a Preventive Maintenance Strategy - Reliability or Maintenance Statistics Reliability Analysis - Predictions, Testing and Standards 2
J Maintenance Man Hour Plan which satisfies EASA Part 145.A.30 (example needed) EASA and JAA Aviation Standards and Requirements 4
S How to determine Preventive Maintenance and Calibration Grace Periods General Measurement Device and Calibration Topics 4
