3 Major Changes between AS9100B and AS9100C
Cainamogel82
Our company is AS9100B certified and with the roll-out of revision C, I want to make sure that we can meet the requirements on our own terms, not what a consultant comes and tells us we need to do. That said, there are 3 areas that need serious improvement:
1) Customer Service - Looks like the simple survey is not enough anymore, looks like we are going to have to start tracking our customer service up and down the chain. This means getting responsive customer feedback as well as suppliers.
2) Project Management - We do not do design, how effective is this revision statement going to be to us? Our project management consists of getting an order and making sure we can fill everything on that order. Am I wrong by saying that the project management scope of this revision change is not going to effect sub-contractors much?
3) Risk Management - The only thing that I can think of to manage this is pFMEA diagrams and those suck. Does anyone else have any advise on what their company is doing to make this a reality, as simple as possible? I understand the basics of risk management, am I going to have to suck it up and create pFMEA's for our facility?
Any response is appreciated. I would especially like to know what other companies are going to do to meet this standard and I will, in turn, bounce back my personal ideas for how we can meet this requirement.
Eric
Jeff Frost
Re: 3 Major Changes for AS9100C
Sidney has given you links to the IAQG information associated with AS9100C. I have been helping my current employer through the same issue and we on the verge of being recommended to registration so this information may be of some help.
1. Project Management
7.1.1 requires you to mitigate risks and to control the realization process within your companies resources and schedule constraints to insure that product quality and schedule are not compromised. This Project Management must occur prior to start of production.
2. Risk Management
Because you are building to the customer's design requirements and as such the customer would define special requirements, critical items and key characteristics of the product. Your process for risk management, under 7.1.2, would be those risks you identify during contract review, known within your processes such as new technology, short delivery time frame,etc. You need to mitigate product realization risk's when they exceed the customer defined risk acceptance criteria.
3. Customer Service
You need to identify what customer service is within your industry. Look as the 2nd note under 7.2.1 and all of 7.5.1.4. If you believe that it is only customer focus and satisfaction then you could apply both Clause 5.2 and 8.2.1 in combination to address this definition of customer service.
Good luck,
Jeff
Cainamogel82
I guess that my major question is: What software (if any) is designed to help with these three areas? I am looking into using MS Project for my Project Management, while our customer service application has to be under pretenses that we define internally (probably some sort of excel workbook or something).
I am kind of stuck then on the Risk Management. Is the best way of dealing with this going to be the application of pFMEA's or is there a pre-designed software out there somewhere that can help to monitor this? I have designed a pFMEA previously and I do not want to think about having to do that for every product we make, that is a job in and of itself. I guess that I am looking for what suggestions other companies might be looking at employing.
:thanx:
K
KwalityWonk
Man... I spent a whole lot of time on this, and this is what I came up with. Still don't have a simple way to document it yet, but at least you can get an idea. Not sure how far they are going to expect each company to delve into this, but ours is an Aerospace Manufacturer making some pretty complex assemblies, and our systems are fairly complex also. May be way too much for a smaller shop, where a FMEA might work, be sure to tie in with ConTract review. Hope this helps.
Cainamogel82
TO: KwalityWonk
That document sure does clear some things up and I would like to use it as a reference guide more than anything. I am not sure what type of spreadsheet to make to define all of these parameters and that is basically where I am at presently. As I stated, I do not want to go so far as to make FMEA's for all of our processes/products, I believe that will be overkill. Thanks.
Cainamogel82
Thanks, I have definitely been taking a look at any (and all) information that anyone can provide.
jpsencik
OK. I'm at the beginning stages of this endeavor, but my companyis currently registered to AS9100B and will be upgrading over the next few months. I am familiar with ISO, but not so much with AS9100 other than the basics. My question is would it be feasable to learn enought and complete an upgrade in a limited amount of time (3 months but 50% of time) or should I be contacting a consultant and get the process going.
Jeff Frost
If you are starting this late in the game on you upgrade to AS9100C you will need to look at when your next audit with your CRB is scheduled. They (the CRB) are required to use AS9100C and associated audit Standard AS9101 and your current certificate will expire July 1, 2011. You should also review AS9101 as there are mandatory requirements such review of 12 months of process effectiveness data, mandatory on-time-delivery review etc. that your organization will need to address that are not part of AS9100. Add to this the requirement that you must, at some point, have completed an audit of your QMS to AS9100C requirements and formally declare to your CRB that you are ready for their audit may be key factors for using a consultant or not.
T Defining Major vs. Minor Changes to Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S What constitutes Major and Minor changes in Software Software Quality Assurance 7
somashekar 7 Major changes expected in ISO14001:2015 ISO 14001:2015 Specific Discussions 3
Marc Major Google Search Changes - January 2012 After Work and Weekend Discussion Topics 9
S Major Changes in Indian H&S Legislation - Info. for Indian Covers Occupational Health & Safety Management Standards 0
T ISO 10993-10: 2002 vs 2010 version - What are the Major Changes? ISO 13485:2016 - Medical Device Quality Management Systems 2
A Major Software System Changes - Implementing TS 16949 and ISO 14001 IATF 16949 - Automotive Quality Systems Standard 2
J AIAG PPAP Third edition changes to Fourth - Ten major changes? APQP and PPAP 10
M HACCP - What are the major changes DS 3027:2002 vs. DS 3027:1997 (Danish) Food Safety - ISO 22000, HACCP (21 CFR 120) 1
A Define timeline for Major and Miner Audit finding General Auditing Discussions 4
Scanton Double Major for the same infraction? IATF 16949 - Automotive Quality Systems Standard 11
M Major vs. Minor for Internal Audits? Internal Auditing 10
W Major NCRs within AS9100 - What is the most frequent reason for Major NCRs? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Stefan Mundt AS9100D Major nonconformity due to recurrence of a NC during a subsequent CB audit. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AIAG/VDA’s FMEA Manual Is a Major Advance (my take on this subject) FMEA and Control Plans 2
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
S Formula for Calculating NoGo Major Diameter for UN gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Fact or fiction - Repeat minor becomes a major IATF non-conformance IATF 16949 - Automotive Quality Systems Standard 7
N Validation procedure, Major NC CAP - Equipment Validation process is not effective ISO 13485:2016 - Medical Device Quality Management Systems 5
I Is this a Major AS9100 QMS change - Quality Concerns AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K FAA Audit - Major nonconformity for lack of timely calibration of two devices EASA and JAA Aviation Standards and Requirements 5
Sidney Vianna Interesting Discussion Legal compliance as part of ISO 45001 accredited certification. Major OSHA penalties in the USA. Occupational Health & Safety Management Standards 15
Sidney Vianna Interesting Discussion How major corporations in the West keep failing to uphold their pledges of abolishing child labor in their cocoa supply chains Sustainability, Green Initiatives and Ecology 3
R Major nonformance finding was given during a closing meeting of a ISO9001 certification audit General Auditing Discussions 76
Y Informational Change control process - Major vs Minor change - Active class III medical devices ISO 13485:2016 - Medical Device Quality Management Systems 12
A Where are the rules for when a repeat minor nonconformance becomes a major? IATF 16949 - Automotive Quality Systems Standard 36
P Major Finding Elevation - Do I elevate this minor finding to a major one? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
J IATF 16949 registration - Major Nonconformance Finding IATF 16949 - Automotive Quality Systems Standard 9
Sidney Vianna Top 10 Major and minor NC's during IATF 16949:2016 Audits IATF 16949 - Automotive Quality Systems Standard 8
G AIAG FMEA - Major customers of the FMEA process FMEA and Control Plans 3
M New Medical Device Accessory with New Function - Is this a major change? Other Medical Device Regulations World-Wide 3
C IATF 16949 : 2016 - How put in place a Containment for this kind of Major NC IATF 16949 - Automotive Quality Systems Standard 14
A ISO 14001:2015 transition audit - Major NC due to the procedure and audit plan ISO 14001:2015 Specific Discussions 10
C How does a major NC for a support site affect our certificate? IATF 16949 - Automotive Quality Systems Standard 2
AlienraverX How to appeal a major audit finding ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
W IATF 16949 Clause 6.1.1 - My first Major NCR (Management Review) IATF 16949 - Automotive Quality Systems Standard 57
K Outsourced Major Processes - Working for Two Sister Companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T Non-addressed Minor Finding elevated to Major Finding Internal Auditing 37
B IATF 16949: Definition Major/Minor Non-conformity IATF 16949 - Automotive Quality Systems Standard 6
M Increase in Major TS16949 Audit Findings IATF 16949 - Automotive Quality Systems Standard 14
S Could I issue major finding for Inadequate Procedures Supplier Quality Assurance and other Supplier Issues 17
D Is Failure to achieve a Goal a Major Non-Conformance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
C Notification to Customers regarding Major Audit Finding IATF 16949 - Automotive Quality Systems Standard 25
J Follow up on Major Audit Finding General Auditing Discussions 15
C ISO 9001:2008 Audit Major Finding - Dial Calipers not set to zero ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
N Formula that will calculate the NoGo Major Diameter of an M20 x 1.5 6H Thread gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
6 Print Callout for a Special Thread - 1.173-18 UNS-3A Major Dia. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
