3 PQ lots mentioned as requirement in PPAP. Is this necessary?
In the medical device industry. PPAP to supplier for an injection molded part. Many on the team have been adamant about adding the requirement of a minimum of 3 PQ lots during run-at-rate consisting of 3, complete startup/shutdowns and 8 hr runs each day. My question is, since this is a PPAP shouldn't the supplier be providing the appropriate information regarding the validation? Is it really necessary we list things out?
My thoughts are as follows:
-Validation protocols will be reviewed and approved prior to the runs being executed. This will ensure minimum 3 lot PQs.
-What makes up a lot? I hear all the time that 3 lot PQs are required and I understand why but what decides when one lot starts and another stops?
-Doesn't it go without saying that a PQ should have 3 lots minimum?
-If a run at rate is supposed to demonstrate capability to produce part as well as capacity, shouldn't it be tailored to the parts need/ forecast? (As opposed to the blanket statement of 3 lots consisting of 8 hrs each)
Apologies if this is a ramble.
Jen Kirley
Quality and Auditing Expert
  • -Validation protocols will be reviewed and approved prior to the runs being executed. This will ensure minimum 3 lot PQs.
  • -What makes up a lot? I hear all the time that 3 lot PQs are required and I understand why but what decides when one lot starts and another stops?
  • -Doesn't it go without saying that a PQ should have 3 lots minimum?
  • -If a run at rate is supposed to demonstrate capability to produce part as well as capacity, shouldn't it be tailored to the parts need/ forecast? (As opposed to the blanket statement of 3 lots consisting of 8 hrs each)
Good day Vobro, I am sorry about the delay in this response.
For those of us in the medical device industry, it's all about risk. It is not at all unheard of to require three, four or even five PQs (or at least that many pieces for First Article Inspections). Injection molding gets such requirements in more places besides just you.
Additionally, manufacturers have a recent European Union requirement to ramp up these requirements; they naturally get passed on to you. Yes, run-at rates too. This is based on business risk of your ability to deliver good stuff on time. I think it makes sense from your view to establish blanket statements, but the manufacturer may be trying to normalize their statistics. That can be awkward for large parts. If that's the case for you, I would consult with your SQE.
I don't know how many is in a lot. I suppose it depends on size and material type. Starts and stops can involve new raw material introduction, tooling intervention and/or other factors. All could introduce risk to consistent good outputs.
I hope this helps!
kuyakut
We always follow the production shift pattern. If the production is running two 12 hours shift, the PQ run is 2 Lots. The idea of running multiple lots is to simulate normal production operations, unexpected interruptions and mold changeover.
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
A Gauge Study for Small Lots Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
N FDA Traceability Requirements - Component lots ISO 13485:2016 - Medical Device Quality Management Systems 2
lilybef Number of lots required for stability testing of a Class II device in the 510(k) Qualification and Validation (including 21 CFR Part 11) 3
L Why is initial production units, lots, or batches, or their equivalents required for Design Validation? US Food and Drug Administration (FDA) 3
Q Is it acceptable to mix components from two different lots into an assembly? ISO 13485:2016 - Medical Device Quality Management Systems 1
C Sampling plan for destructive tests on small lots ISO 13485:2016 - Medical Device Quality Management Systems 20
S Labeling for Validation Lots Products EU Medical Device Regulations 5
D Number of Manufacturing Lots for Process Validation Manufacturing and Related Processes 10
T Combining multiple lots of the same raw component for packaging or kitting 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
K Sampling Plan for Small Lots of Single Use Items Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
Ronen E Covidien recalls some Monoject Insulin Safety Syringe lots Other Medical Device and Orthopedic Related Topics 0
Ronen E Ethicon recalls some ECHELON 60 ENDOPATH? STAPLER Endoscopic Linear Cutter lots Other Medical Device and Orthopedic Related Topics 0
Ronen E Moog Medical Devices Group is Recalling certain Lots of IV Sets Other Medical Device and Orthopedic Related Topics 1
V Sample Size for Attribute Data - Large Production Lots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T How to calculate AQL on Small Lots AQL - Acceptable Quality Level 1
A Looking for a wordsmith - Little compensation - Lots of appreciation! General Auditing Discussions 8
T Sampling Plan for Small Lots between 20 and 100 or so units Statistical Analysis Tools, Techniques and SPC 1
A What is a good Sampling Plan for LARGE Lots of Supplier Components Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Zero Acceptance Number Sampling Plans for Isolated Lots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
B Addressing Lots that were measured with Out of Tolerance Gage Pins Nonconformance and Corrective Action 5
N Re-Packaging and Re-Labeling Bulk Lots of Class II Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
P Testing 3 Manufacturing Production Lots EU Medical Device Regulations 4
N AQL (Acceptable Quality Level) Sampling Plan for Small Lots AQL - Acceptable Quality Level 8
T Partial Shipping of Lots - Shipping of product prior to the lot being completed ISO 13485:2016 - Medical Device Quality Management Systems 4
F Determining the Number of Samples for receiving large lots of wire? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Silver Plating (Lots of questions) Manufacturing and Related Processes 8
A Traceability and Control of Manufacturing Lots IATF 16949 - Automotive Quality Systems Standard 7
Z Tracking Lots for Reduced and Tightened Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M FOC (3 lots) - First of Code - Are you still doing 3 lots for FOC? Other Medical Device and Orthopedic Related Topics 1
D Samples from Lots of Incoming Raw Materials - Sampling Protocol Help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
D Device History Record - Single file for each lot with all the lots history? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
K Reproducibility between different lots using minitab Using Minitab Software 1
A Combining Lots under ANSI/ASQC Z1.4 Inspection Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Marc Telcos: The Internet Will Collapse If The Gov't Doesn't Gives Us Lots Of Money After Work and Weekend Discussion Topics 0
I Traceablity of Small Part Lots Supplied to Production taken from Large Lots? Lean in Manufacturing and Service Industries 7
R Sample Size and Confidence question for Small Sample Size on Large Lots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
H Medical Devices and Mixed Lots Manufacturing and Related Processes 4
S Mixing lots at the platers - Electrical Contacts Manufacturing and Related Processes 11
Q AQL - Can progressive acceptance be used with longer/bigger lots? AQL - Acceptable Quality Level 5
R Sampling plan for lots smaller than 25 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D Confidence interval for % overuse in component lots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Qualification Lots and product transfer elements affected IATF 16949 - Automotive Quality Systems Standard 1
M Individual or Moving Range Chart? Parts run in lots of 7 with 4 key wall thicknesses Statistical Analysis Tools, Techniques and SPC 5
R Reject Rates - Lots and split lots Quality Tools, Improvement and Analysis 3
M Basics of a Quality System - Novice Book with lots of illustrations Book, Video, Blog and Web Site Reviews and Recommendations 5
S Lots of products - need CP's IATF 16949 - Automotive Quality Systems Standard 9
I TS 16949 Quality Manual Templates - Lots of free examples and great discussion! Quality Management System (QMS) Manuals 159
