3D Measurements with Camera (scanner)
cabdriver
Hello to everyone,
I’m new here and I hope that I found right discussion.
Company where I work (we have TS16949) had bought company with similar product-stamping parts (without TS).
As they don't use checking device for process approval (around 400 different parts) they use 3D measuring machine.
I wonder if there is some device such as 3d camera or scanner which is enough fast that can measure 5 parts let say 10 min.
I want to post part picture, but It looks that I’m not very active on forum.
Matt Swartwood
I don't know the complexity of the product you are talking about or how much your company is willing to invest... But have you looked into camera operated vision systems such as cognex or portable CMM's like Faro technologies, who offers a laser scanner?
The technology and integration companies are readily available if you know what you want and how much you are willing to spend.
Dr. Kerstens
If you already have one or more CMM's, you could investigate the use of a 3D CMM scanner, like the ones offered by Metris. Of course, all depends on the application.
Dr. Kerstens
Yes, I do, but mentioning it was by meant by means of example as in Swartwood's reply.
trainerbob
There is plenty of technology to do the measuring, but if you have to do that much measurement, maybe you should be looking at the processes and see if they can be improved to reduce some of the measuring.
cabdriver
I also think on that, but after some calculations we got to a price tag above our range (over 1million € for all checking aids), especialy in this difficult time.
Problem is that this company has sell Checking devices to customer but they were never build (money has ben privateized by prevoius owner :mad:).
I will look for this metris company. Maybe they have some solutions fo us.
Thank you for your cooperation.
This is very helpfull forum.
mboucher
The answer to the original question is yes. There are Vision products that use both cameras and lasers. I have a Vision machine with both.
But you need to look at your part, 2d stamped parts do not require a Metris system to accurately measure them. Although the Metris system is great, I was the Mitutoyo applications engineer working directly with Metris and I have a lot of experience with their product, and would highly recommend them for the right parts. Werth, Mitutoyo, OGP, RAM, Starrett all make a fine vision product.
With a arm cmm I don't think you'll get the measuring time you are requiring "fast enough that can measure 5 parts let say 10 min". But this again depends on your parts. In a vision machine you can stage the parts in rows and columns and the vision machine can loop the program with an offset to repeat the program without you having to stage each part.
A standard vision system will do fine for simple 2d stamped parts.
Mark
bobdoering
Stop X-bar/R Madness!!
Lasers have been used for quite a while for 3D space, cameras are ok, but they typically use pixels for X and Y and focus for Z. Adjusting the focus for the Z location takes 'some' time (in relative terms). Understanding lighting is dead critical. Under higher magnification, they can get confused finding a radius (or similar feature) among tool marks. Also, they are also typically looking at projection, in that any hidden dimensions (undercuts) can be a problem unless you have a very sophisticated system. That is why the handiest systems have multiple sensors - camera, touch probe and laser. But, get out your checkbook... Personally, I just love the OGP programming - which is unique to their system (not PCDMIS), but that is my personal preference. Very easy to train others, especially if they have any CAD experience.
N R&R for Differences between 2 measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M What is the proper way to document measurements Measurement Uncertainty (MU) 1
N New (Upgraded Technology) vs Existing Equipment - Measurements Shift Design and Development of Products and Processes 4
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Q Measurements after Calibration Expiry General Measurement Device and Calibration Topics 13
chris1price Error in data recording - Recording measurements in SAP Capability, Accuracy and Stability - Processes, Machines, etc. 2
G How many Uncertainty Measurements for Micrometers and Calipers? Measurement Uncertainty (MU) 3
BHobbs_Busche All Measurements taken with a Variable Gage have to be Recorded 100% IATF 16949 - Automotive Quality Systems Standard 14
T GR&R Data from Caliper Measurements APQP and PPAP 3
L Color measurements R&R: what's wrong with white? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Standard for Rounding Measurements for Labels Other Medical Device Related Standards 9
M 10 parts, 3 operators, 3 measurements GR&R study tolerance question Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Uncertainty measurements for a 6 inch caliper Measurement Uncertainty (MU) 11
C MU (Uncertaincy of Measurements) definition and MU Factors Measurement Uncertainty (MU) 4
C Measurements of Major Diameters of plug thread gages General Measurement Device and Calibration Topics 12
J Can some measurements be considered information only and not need calibration? General Measurement Device and Calibration Topics 7
C Chamfer Measurements - Do you measure the height and width or the hypotenuse? Manufacturing and Related Processes 15
5 Number of 'significant digits' in measurements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 31
S TL 9000 Certified Companies - REMINDER - TL 5.0 Measurements Effectivity - July 2013 TL 9000 Telecommunications Standard and QuEST 1
S US and Metric Measurements in same Document Other ISO and International Standards and European Regulations 4
P Uncertainty of Measurements for Adhesive Weights for Peel Testing Capability, Accuracy and Stability - Processes, Machines, etc. 2
G Improve final GR&R value by taking average of more measurements? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
R Using Curve Fits and Predictions in place of good old Measurements General Measurement Device and Calibration Topics 3
CycleMike 7.6.1 - ".....type of measurements system" and Plug Go/NoGo gages IATF 16949 - Automotive Quality Systems Standard 4
R Procedure for Measurement Uncertainty Estimation for Electrical Measurements Measurement Uncertainty (MU) 2
C The Dreaded Uncertainty Measurements - Confidence in your results Measurement Uncertainty (MU) 1
T Implementing SPC - Control Chart for Individual Measurements Statistical Analysis Tools, Techniques and SPC 9
C Building a Dimensional Metrology Laboratory to Inspect various Physical Measurements General Measurement Device and Calibration Topics 2
S Is it alright to let the supplier do all measurements and inspection? Quality Manager and Management Related Issues 10
J TL9000 Common Measurements - Design and Development for Telecommunication Products TL 9000 Telecommunications Standard and QuEST 5
C Referencing or Using a Master Part to take Measurements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K Measurements - Sphere in contact with a plane General Measurement Device and Calibration Topics 3
V Importance of Replicate Trials/Measurements in DOE Trials Statistical Analysis Tools, Techniques and SPC 2
A Burrs affecting measurements and Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 7
F Supplier Measurements vs. Incoming (Receiving) Measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
D Gauge Analysis with 2 Complimentary Measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Q Shipping Measurements (Measurables) other than On-Time Delivery ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P Not Enough Resolution for Gage R&R - 79" Panel Length Measurements Help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
M PPAP including FAI Parts - Customer is requiring 5000 measurements APQP and PPAP 15
K Are Surveys and Interviews considered Objective Measurements? Internal Auditing 25
T Vernier Caliper Accuracy Issue - Inside measurements were slightly off General Measurement Device and Calibration Topics 7
R Problems Making Measurements - Agilent 8902A Measuring Receiver Calibration and Metrology Software and Hardware 4
S A2LA requirements for Electrical Uncertainty Budgets - Measurements with a slope Measurement Uncertainty (MU) 3
B MS Access to document metrics and performance measurements? Preventive Action and Continuous Improvement 1
C Measurements (Dimension) Data Anaylsis - Methods to determine trends Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Small Variation in Thickness Measurements in Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 23
M DIN6930 What table to use - Tolerances of straight line and radii measurements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J What is ratio or reciprocity-type measurements in ISO15189 General Measurement Device and Calibration Topics 2
