4.2.3 Document Control using Microsoft Sharepoint - Visibility of Draft Documents
H
hoef17
In my organization we use Microsoft Sharepoint to control of documents. Some associates can see draft version of documents and others can only access published versions (non-draft). For those who can see draft versions there is a particular way to navigate back to the version that has been published for all users to see.... during our internal audits we have found that some people who can see draft versions are unable to navigate thru version history to see published version. What would you typically write this up against? My opinion is 4.2.3 d to ensure the relevant version of applicable document are available at points of use.
Your thoughts?
Re: 4.2.3 Document Control
It's not clear whether the people can't access the published version at all, or just can't do it via a certain path. Nonetheless, do you have your own documented procedure for how the thing is supposed to work? If so, and the way that it works doesn't conform to the documented requirements, you have a nonconformity against your own requirements.
On the other hand, if you don't have a documented procedure for how the thing is supposed to work but you've discovered that it doesn't work as expected, you should fix that, perhaps documenting it as an opportunity or whatever it is your company calls that sort of thing when discovered in an internal audit. It's generally not a good idea to do internal audits against the standard. Design your processes to meet the requirements of the standard, and audit against your own process designs.
Chance
As Jim said, it is not clear what people do and don't have access.
IMHO, why would you let your audience see the previous version history? Those becomes obsolete anyway from the moment a new version is published. Pardon me if I misunderstood your post.
selena15
Hi all
well
i would saw it as the following:
IMHO, it is just it issue, since just some have this problem, it may be a right access cause or other missing cookies or related
but as others said, the obsolete version need to be kept separatly as archive. and the draft version is in my understanding available to people who writte it and approve it when a company use electronic way to update or writte procedure.
i would consider it as nc against item 4.3.2 d if i consider that you make available to people the draft version while the approved copy is released
hope i contribute
sel
C Document Control using Wiki - Cannot Create all Documents as Wiki Pages Document Control Systems, Procedures, Forms and Templates 10
P SharePoint for Document Control - 'Workflows' using SharePoint 2010 Enterprise Document Control Systems, Procedures, Forms and Templates 3
S Using Lotus Notes/Domino for Document Control Document Control Systems, Procedures, Forms and Templates 4
Pancho Using a wiki for Document Control The Reading Room 10
Q Document Control Software Suggestions - Anyone using MIPSIS? Document Control Systems, Procedures, Forms and Templates 7
A What Electronic Document Control Software are you using? 'Canned' or In-House? Document Control Systems, Procedures, Forms and Templates 10
M Document Control - Applying Suitable Identification to Obsolete Documents ISO 13485:2016 - Medical Device Quality Management Systems 5
D Document Control Question involving DocuSign US Food and Drug Administration (FDA) 6
M Document Control ISO and FDA ISO 13485:2016 - Medical Device Quality Management Systems 7
R Does anyone use iQMS for their ISO based document control? Manufacturing and Related Processes 1
dpenbert AS9100 7.5.3 - Manual Document Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Help in document control procedure Document Control Systems, Procedures, Forms and Templates 8
J Training on the importance of Document Control Document Control Systems, Procedures, Forms and Templates 3
M ISO 13485 and document control for programs ISO 13485:2016 - Medical Device Quality Management Systems 6
K ASME, ANSI, ASTM and similar specifications and their requirements for document control. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 4
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Document Control Software Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
I Document Control Workflow Document Control Systems, Procedures, Forms and Templates 2
D ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions Document Control Systems, Procedures, Forms and Templates 51
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
B Referencing to Supplier Outputs within our Document Control System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Sidney Vianna IAF Mandatory Document #23 - Control of CB Franchisees and Agents Registrars and Notified Bodies 3
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
D Software for advancing with Document Control Quality Assurance and Compliance Software Tools and Solutions 4
L IATF 16949 Cl. 7.1 - Lotus Notes for Document Control IATF 16949 - Automotive Quality Systems Standard 0
A Removing purchase order form from document control - should it be done? Document Control Systems, Procedures, Forms and Templates 9
I Video under Document Control SOP ISO 13485:2016 - Medical Device Quality Management Systems 2
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Document control for tooling drawings (Document control clause 7.5.3) IATF 16949 - Automotive Quality Systems Standard 5
J Document Control Newbie - Control of Nonconforming / Returns Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
R External Standards List (Document Control) Document Control Systems, Procedures, Forms and Templates 3
M Retiring documents in Document Control Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Managing Level 3 Production Documents - Document Control System Help Document Control Systems, Procedures, Forms and Templates 6
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
