4.2.4 Control of Records - Registered to ISO9001:2000, ISO 13485 and AS9100
silly girl
Hi all-
I am in the middle of an internal audit, and I am having some trouble deciding what to do with a particular finding. Any thoughts would be appreciated.
First, some background. We are registered to ISO9001:2000, ISO 13485 and AS9100. During the last internal audit there was a finding written against 4.2.4, specifically concerned with protection and retrieval. This involves supplier records (C of C and Test data) that are used in an aerospace product. The method of filing makes retrieval difficult (though not impossible), and older records are being stored in a semi trailer (unheated, damp, insect ridden :mg: environment). In the response to the CAR, the responsible person basically said 'This is too expensive to fix, so we won't.' This response was accepted and the CAR closed.
I am auditing our corrective action system, and this CAR closure made my ears perk up. I can accept not changing the filing system, since I do believe that we can find any record we need to, but the 'protection' piece really bothers me. During the last audit there were no records found that were illegible or ruined by moisture, however I am not sure how long records can really stay out there safely. Since our customer has stringent requirements on record retention, we expect those records to stay around for many years...
Opinions wanted - am I overly concerned about this, or is my concern reasonable? Any thoughts on how I should write up findings, or what else I should go look at?
Thanks for input,
SG
BadgerMan
The AS9100 standard requires that records be retrievable.......not easily retrievable. It is also pretty vague regarding "protection" of records.
However, you should also be concerned about any customer or regulatory impositions concerning the control of records. Maybe the company can justify the risk from an ISO/AS perspective but that is only one piece of the puzzle.
Historically, I have found our corporate record control requirements to be the most stringent of all with regard to protection from loss or damage and retention times.
Randy
Have whoever answer this....
Which is more expensive?
A) Properly maintain records so they can be protected and retrieved, or
B) Possibly pay out million$ from litigation if we can't prove our bona fides.
All records have the potential to have litigation tied to them, either good or bad. Records provide "proof" and without them you just have hot air to verify the past.
silly girl
Yes, that is exactly my take on the situation. Thanks for the feedback.
SG
silly girl
An update
Just an update for those interested.
Today I spoke with the management rep. and he has agreed that the CAR was closed inappropriately. As a result, two new CARs are being issued, one for the original issue and one for the corrective action system itself.
SG
shirly
Control Of Records
Dear silly Girl,
I don't know the volume of your records, but have you considered scanning your records and storing it electronically?
shirly
silly girl
Scannning records
Yes, that is under consideration. There is a project in place addressing this, but shaking money loose is always a problem so I am a bit sceptical about how long it will be before we have such a system in place. I think it would be wise to manage the risk to the existing records in the interim.
Regards,
SG
gard2372
Regards,
SG
A simple cost effective way to store your records electronically is to scan them with a modern printer/copier machine. We do this everyday as certain segments of the projects are completed we gather the paperwork and scan them using our shop floor copy machine and scan them as a pdf file into a predetermined folder ie;
Q:\Engineering\Repair jobs supporting docs\2005\Customer\Component\Frequency testing
It is very easy to maintain and retrieve once the directory is mapped and the folders are maintained. Check with your IT department as it would be very simple for them to implement this and keep daily backups of data for you. As far as the hard copy paperwork goes, our travelers and repair documents are scanned and stored in file cabinets after shipping and receiving processes them.
This is a simple solution, and you've probably already mentioned it to your colleagues, but this is how we maintain our 4.2.4.
Rob
Caster
An Early Cover
A benchmark for you
silly girl said:
silly girl said:
We are registered to ISO9001:2000, ISO 13485 and AS9100. During the last internal audit there was a finding written against 4.2.4, specifically concerned with protection and retrieval. This involves supplier records (C of C and Test data) that are used in an aerospace product. The method of filing makes retrieval difficult (though not impossible), and older records are being stored in a semi trailer (unheated, damp, insect ridden environment). In the response to the CAR, the responsible person basically said 'This is too expensive to fix, so we won't.' This response was accepted and the CAR closed.... but the 'protection' piece really bothers me. During the last audit there were no records found that were illegible or ruined by moisture, however I am not sure how long records can really stay out there safely. Since our customer has stringent requirements on record retention, we expect those records to stay around for many years...Opinions wanted - am I overly concerned about this, or is my concern reasonable? Any thoughts on how I should write up findings, or what else I should go look at?Thanks for input,
SG
SG
Many years ago I did a courtesy audit of a sister plant which was an aerospace foundry. We were Automotive.
When it came time to look at record retention, I was lead to a locked area directly above the main offices.
All records were in heavy duty bankers boxes arranged on shelving. A laser beam passed along the ends of the boxes would just touch them all. They were exactly 2 inches back from the edge of the shelf, exactly 2 inches apart.
All the covers were on and secure. The labels were all exactly 1 inch from the left top and side.
Within each box each individual file folder was snugged up to the left of the box. Within each file folder the records were neatly stacked and they were snugged up to the left within the file folder.
This was starting to creep me out. Every file folder was clearly labelled. All records were in date order within the file.
After I was done pawing through things the doc clerk almost had a heart attack putting thing back to rights.
Overkill? Of course, but this level of detail carried throughout every aspect of the business.
When I commented on the level of detail compared to our records system (biffed into a broken photocopy paper box), I was told, "my family and I fly in airplanes with our parts on them, what would you expect to see here?".
It made me feel better about the flight back home.
I thought automotive was bad for requirements until I saw Aerospace.
BTW, congrats on throwing down on this problem and getting a good result!
B Record Management - Does the QMS need to control templates of records? Records and Data - Quality, Legal and Other Evidence 17
S ISO 13485 Cl. 4.2.5 - Requirements for Control of Records ISO 13485:2016 - Medical Device Quality Management Systems 3
E Definition Integrity - The meaning of the word INTEGRITY in ISO 13485 Control of Records Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
GoSpeedRacer ISO 13485:2016 Clause 4.2.5 - Control of Records - HIPAA Requirements ISO 13485:2016 - Medical Device Quality Management Systems 11
T Control numbers for records Document Control Systems, Procedures, Forms and Templates 10
x-files Control of Records - Retention Time vs. Retention Period Document Control Systems, Procedures, Forms and Templates 5
M Control of email (and other electronic media) as Records - 4.2.4 Records and Data - Quality, Legal and Other Evidence 10
Gman2 Control of Records - Lets talk about modern methods Records and Data - Quality, Legal and Other Evidence 5
T Customer Specific Documents and Records - ISO 9001 Control Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Control of Records - Differences between Controlled Documents and Controlled Records Records and Data - Quality, Legal and Other Evidence 18
M AS9100 - 4.2.4 Control of Records and 6.3 Infrastructure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T Document Control - Disposing of Outdated Records Document Control Systems, Procedures, Forms and Templates 15
drgnrider Records control on a shared, open, network Records and Data - Quality, Legal and Other Evidence 15
D 21 CFR 11 Tools Validation - Electronic Document and Records Control Qualification and Validation (including 21 CFR Part 11) 5
K Records Control - How do you Manage tons of Paper Records? Records and Data - Quality, Legal and Other Evidence 10
K Control of Documents or Control of Records? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
K Records Control - Auditor Objection to Data being Recorded and Stored in PC Records and Data - Quality, Legal and Other Evidence 21
K Guidance on AS 9100 4.2.3 Control of External Records AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
L How to control some Documents and Records (ECN's and ECR's) Document Control Systems, Procedures, Forms and Templates 1
P Electronic Record Control (Specifically editable records not fixed documents!) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Supplier Retained Records Requirements - AS9100 4.2.4 Control of Records AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M When do you need to control records of Purchase Orders? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K Quality Records (QR) Control Codes Records and Data - Quality, Legal and Other Evidence 13
R Control of Records - Clarify which records are to be maintained ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W Design History Verification Records Control and Approvals US Food and Drug Administration (FDA) 3
P Control of Records - Is a List of Records Required by ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
J MS Office 2010 - Control of Records - ISO 9001 Clause 4.2.3 c Requirements Document Control Systems, Procedures, Forms and Templates 2
K ISO 9001 Clause 4.2.4 Control of Records - Documented Procedure help ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T Control of Records - API Q1 8th Edition Record Retention Requirements Oil and Gas Industry Standards and Regulations 7
K 5S on Control of Records (e.g. Check Records, Cluttered Files, etc.) in a 5S Audit Records and Data - Quality, Legal and Other Evidence 1
J How to Control Production Batch Records Document Control Systems, Procedures, Forms and Templates 4
J Control of Records - Complying with ISO 9001 Clause 4.2.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Procedure for Control and Maintain of Records in each Design Stage 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
A Control of Records Procedure (ISO 9001 Clause 4.2.4) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Control of records - what's simple and works! Document Control Systems, Procedures, Forms and Templates 6
J Control of Records - ISO 9001 Clause 4.2.4 Records and Data - Quality, Legal and Other Evidence 5
S Control of Records: "Retention" Records and Data - Quality, Legal and Other Evidence 18
M 21 CFR Part 11 & Control of Raw Data Records used as input into Validated Spreadsheet Qualification and Validation (including 21 CFR Part 11) 2
G Creating a "Records Policy" - Control of Quality Records Records and Data - Quality, Legal and Other Evidence 13
B Examples of Material Certificate (CofC or CofA) Document (Records) Control Systems Supplier Quality Assurance and other Supplier Issues 6
S What Documents and Records to Control and what not to control? Document Control Systems, Procedures, Forms and Templates 4
B Control of Records - Process Flow, ideas and examples wanted Process Maps, Process Mapping and Turtle Diagrams 4
J Why control of records in checking section? Miscellaneous Environmental Standards and EMS Related Discussions 3
N Master List of Records Required? ISO9001:2008 Clause 4.2.4 Control of Records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Record Control - Why must I control these records? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
A Procedure for control of Records - Needed Document Control Systems, Procedures, Forms and Templates 1
T Departmental Control of Records and Documents Document Control Systems, Procedures, Forms and Templates 9
L When do you need to control records? Purchase Orders ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Control of Vital Documents and Records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
