5 Why help needed Please kindly review
Bradley C Smith
Ok I am trying to utilize the 5 why's down to a management issue does this appear ok?
Self Inspection NOK
Why? Visual inspection control method is not effective/robust for this type of failure mode.
Why? Based on Gage R&R, repeatability was less than 90% which shows that visual inspection is not adequate for this failure mode.
Why? No evidence that a Gage R&R was performed to validate the control method during the program phase.
Why? PFMEA RPN value is too low
Please critic if it can go farther or if this makes sense.
Jen Kirley
Quality and Auditing Expert
I think it is worthwhile to identify whether visual inspection is warranted in this step or not, and I am unclear as to the role Gage R&R plays with this decision. My understanding has been that the type of inspection is determined while defining the control plan, and that GR&R is a tool to quantify and verify an instrument's ability to perform a mechanical inspection. So the purpose of GR&R seems to be misapplied, while the various fallibilities of visual inspection do not so far appear to be addressed.
I welcome other Cover's input, out of concern I may not have identified this issue correctly.
G
George Weiss
Hello pretty-new cover,
The 5 WHYs’ evaluation is a look for a root cause. It is a basic tool/approach. An evaluation of your 5 WHYs would require knowing the problem better. Listing a problem, and requesting some offered suggested 5 WHYs would be one idea. Another would be allow forum brainstorming on your problem(s)
5 WHYs criticism:
  • Tendency for investigators to stop at symptoms rather than going on to lower level root causes.
  • Inability to go beyond the investigator's current knowledge - can't find causes that they don't already know Lack of support to help the investigator to ask the right "why" questions.
  • Results aren't repeatable - different people using 5 Whys come up with different causes for the same problem.
  • The tendency to isolate a single root cause, whereas each question could elicit many different root causes
Pulled from @
Wikipedia reference-link5_Whys
:bigwave:
Bradley C Smith
We had a situation where we were visually checking at the workstation to see if 4 screws were fully seated down to secure a speaker to a door panel. Operator did not detect presence so we conducted an attribute gage R&R to see if they could visually detect screws being fully seated down = 0 gap. A 30 piece attribute gage R&R was done with 4 inspectors at various screw gaps 1.50 mm, 1.25 mm, 1.00 mm, 0.75 mm 0.50 to see if they could detect consistently. What we found was at 1.50mm was detected 100%. 1.25 to 0.75 there were non-detections, 0.75 and lower was always non-detected. So we validated that the measurement method was not correct.
Jen Kirley
What was the operational control? How are the screws set in? Is there some specific torque set for the screws at this step?
Bradley C Smith
Torque tolerance is 0.90 to 1.10 Nm with atlas copco electric torque driver. Workstation operators are required to use electric torque driver and then visually check screws are seated. Driver is not poka-yoked to prevent part from going to next station that is why there is visual inspection.
Bradley C Smith
Operational control is torque driver that torques 4 speaker screws down at between 0.90-1.10 Nm to secure speaker to door panel. Since torque driver is not error-proofed at the station we were relying on visual inspection to check that screws were seated fully down. Torque driver was found to be repeatable and does torque to those values.
Jen Kirley
Gage R&R is normally done with gages. If inspectors are less reliable than the torque value of the driver, why not use the torque driver to ensure proper torque?
Bradley C Smith
What ensures that the torque seats all screws down in the event that there is an interference condition between the screw and the bottom of the screw boss which causes the screw not to sit flush? Torque is acheived however screw is not flush.
G
George Weiss
I hear the condition of variations in the pilot hole for the screw. I am guessing you are going through several soft materials, and securing to a sheet metal door panel. The variations in pilot hole are causing less than fully seated speakers. The speakers have a metal support frame also, it is expected. The sheet metal screws attaching metal to metal can handle quite a torque, unless the screws are of the cheapest brand. I am betting an evaluation of the screw shear/break torque will find you have ample room to increase torque to solve this problem. Max securing torque being 80% of shear/break, and allowing for 5-10% torque drive spec. The target is normally 60-70%. If I am totally off target, then of course disregard.
V Help needed with ISO 14001 Procedures please ISO 14001:2015 Specific Discussions 7
J Contract Review - Please help me define the requirement 7.2.2 Info needed Contract Review Process 9
A Help needed with locating conector Design and Development of Products and Processes 0
D Help needed for Compliance Road-Map - Startup making their first device (IVD) IEC 62304 - Medical Device Software Life Cycle Processes 1
V Root Cause help needed - Sheet metal breaking at press Problem Solving, Root Cause Fault and Failure Analysis 9
W TL9000 transition from 5.5 to 6.0 - help needed TL 9000 Telecommunications Standard and QuEST 1
K Processing Time Tracking Software Program Help Needed Lean in Manufacturing and Service Industries 3
N VDA 1 Critical Characteristics Requirements Help needed VDA Standards - Germany's Automotive Standards 6
G Help needed on 2 TS 16949 Elements - 7.5.5 & 7.5.3 IATF 16949 - Automotive Quality Systems Standard 2
R Excel 2003 and Capability Studies for Dummies - Help needed! Excel .xls Spreadsheet Templates and Tools 4
R ISO 13485 Software Validation Requirements - Help needed ISO 13485:2016 - Medical Device Quality Management Systems 4
D Generating a detailed Process Plan - Help needed Process Audits and Layered Process Audits 6
R ISO 9001 Implementation in the Bus/Coach Industry - Confused and Help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
O ISO 9000 section 7.2.1(c) Compliance help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
E Help needed on the TS 16949 External Auditor Exam IATF 16949 - Automotive Quality Systems Standard 8
Q Regression Analysis for the Attached Data - help needed - TIA Reliability Analysis - Predictions, Testing and Standards 13
S Interpreting Level of Confidence - Round Robin for Tensile Testing - Help needed Statistical Analysis Tools, Techniques and SPC 4
J ISO 9001 and Improvement of Business Performance - Research help Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Dew Point Meter: DPL4000 - help needed Manufacturing and Related Processes 1
W Australian Approval for Class I Medical Device - Help needed. Other Medical Device Regulations World-Wide 1
R Student Question - Help needed with statistics questions Statistical Analysis Tools, Techniques and SPC 6
L Definition Throughput Yield (TPY) or First Pass Yield Calculation - Help Needed Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
P Sample Size Calculation help needed Reliability Analysis - Predictions, Testing and Standards 4
6 Preventive Action - Help Needed. Input for Training and Sustenance Preventive Action and Continuous Improvement 3
R ISO 13485 Surveillance Audit Nonconformances and Report Help Needed ISO 13485:2016 - Medical Device Quality Management Systems 9
A Help needed for Fighting a specifically identified Organism found during Dose Audit Miscellaneous Environmental Standards and EMS Related Discussions 2
D AASHTO R18 Accreditation (quite similar to ISO 17025) QMS - Help needed ISO 17025 related Discussions 4
L Gage Linearity and Bias Study Analysis - Minitab help needed Using Minitab Software 4
H Husky 1750PSI Pressure Washer - Help needed! Manufacturing and Related Processes 3
L Medical Device FDA Product Classification help needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Cross Tabulation in Attribute MSA - Help Needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Trend Review and Process Improvement help needed Capability, Accuracy and Stability - Processes, Machines, etc. 6
L Easy Access of Obsolete Documents - Corrective Action help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T FDA Single Use Instruments - Classification Help Needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
T PFMEA of Die casting Process--Help needed? FMEA and Control Plans 5
P Design FMEA (DFMEA) Basics - Help needed IATF 16949 - Automotive Quality Systems Standard 3
K ISO 13485 Audit help needed General Auditing Discussions 20
U Issue with Labelling of Outer Container - help needed for clarification EU Medical Device Regulations 3
S Excel Spreadsheet Conditional Formatting help needed Excel .xls Spreadsheet Templates and Tools 12
G Help needed to complete a Financial Audit of a Nonprofit Organization Various Other Specifications, Standards, and related Requirements 7
K Low Volume Products Data Analysis help needed Statistical Analysis Tools, Techniques and SPC 6
somashekar Water and Air Pollution Load Calculations help needed Miscellaneous Environmental Standards and EMS Related Discussions 6
S Master Document Register Project Procedures help needed Document Control Systems, Procedures, Forms and Templates 2
Ajit Basrur Tabulating Improvement Plan Status - Help and suggestions needed Excel .xls Spreadsheet Templates and Tools 9
R Sample Audit Report of an Investment Company - Audit help needed Document Control Systems, Procedures, Forms and Templates 1
E FDA New Product Introduction Regulations help needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
R Process VSM (Value Stream Mapping) help needed Lean in Manufacturing and Service Industries 5
K Virtual DMIS vs. PC-DMIS - Help needed Calibration and Metrology Software and Hardware 3
T Excel Time Calculations and Formulas help needed Excel .xls Spreadsheet Templates and Tools 15
C TS 29001/API spec Q1- help needed Oil and Gas Industry Standards and Regulations 1
