5 Why RCA for failure to test Contingency Plan
Vader22
Seeking help concerning External Audit Finding Root Cause Analysis. Trying to come up with a 5 why and I am struggling because it is basically something that we just didn't do. W1: Didn't fully understand the requirement in the standard. W2: We are dumb????? I know this isn't acceptable, but an audit finding can just be something that you just didn't do for no apparent reason. Thoughts...............
Vader22
STANDARD CLAUSE
6.1.2.3 Contingency plans
REQUIREMENT
The organization shall:
a) identify and evaluate internal and external risks to all manufacturing processes and infrastructure equipment essential to maintain production output and to ensure that customer requirements are met;
b) define contingency plans according to risk and impact to the customer;
c) prepare contingency plans for continuity of supply in the event of any of the following: key equipment failures (also see Section 8.5.6.1.1); interruption from externally provided products, processes, and services; recurring natural disasters; fire; utility interruptions; labour shortages; or infrastructure disruptions;
d) include, as a supplement to the contingency plans, a notification process to the customer and other interested parties for the extent and duration of any situation impacting customer operations;
e) periodically test the contingency plans for effectiveness (e.g., simulations, as appropriate);
f) conduct contingency plan reviews (at a minimum annually) using a multidisciplinary team including top management, and update as required;
g) document the contingency plans and retain documented information describing any revision(s), including the person(s) who authorized the change(s).
The contingency plans shall include provisions to validate that the manufactured product continues to meet customer specifications after the re-start of production following an emergency in which production was stopped and if the regular shutdown processes were not followed.
STATEMENT OF NONCONFORMITY
The organization's process for conducting contingency plan reviews (at a minimum annually) using a multidisciplinary team including top management, and update as required, periodically test the contingency plans for effectiveness (e.g., simulations, as appropriate) was not effective.
OBJECTIVE EVIDENCE
Documented information for annual review of contingency plans and periodically testing of the plans was not available.
John C. Abnet
Teacher, sensei, kennari
Good day @Vader22 ;
Impossible for "us" to know all the details and develop the 5whys for your organization. However, I would offer...
W1- Documented information for annual review of contingency plans and periodically testing of the plans was not available.
W2- No evidence was collected
W3- No testing was performed
W4- Leadership failed to plan the required testing
W5- Responsible individual(s) were not aware of the testing requirement
W6- ?..process owner was not assigned ??
W6- ?..process owner did not communicate and roll requirements into annual planning activity??
W6- ?..process ownership had changed and change point control is missing the training aspect?
W6- ?....org chart is not linked to a list of curriculum for each position on the org chart, therefore, when process owner changed, new process owner was not made aware of work instructions/procedures specific to his/her responsibilities ???
Obviously, there are numerous guesses/assumptions being made in this example.
Hope this helps.
Be well.
AMIT BALLAL
Ask further whys such as why this particular requirement wasn't known?
Whether this clause/few clauses were missed to understand properly.
Whether the system was designed with the help of a consultant, hence you didn't go through the standard properly.
Whether this is the first audit to IATF16949. If yes, there can be certain gaps, since it takes time for the system to get mature.
If the system is old, you can check whether the internal audit program is effective to identify such gaps earlier.
These are some sample answers to your why. Please check if any of these is the answer in your case. If yes, you can consider that reason for the further why-why analysis.
If you are still stuck up, please post for further discussion.
You say "...it is basically something that we just didn't do" Does this mean that you were aware of the requirement, but for whatever reasons there might be, it didn't get done? Or do you mean that there was no awareness of the requirement?
Mike S.
Happy to be Alive
Consideration of, and answers to Amit's and Jim's questions will help us understand your situation better.
malasuerte
Specifically to your question: No. There is a reason it was not done. So your RCA should now help to figure out the best RC.
Johns 5W above is pretty solid. You could do multiple 5W: Technical, QMS, and Management - each one may provide some insight.
Disclaimer: Random thoughts in general only! Why would you not test your contingency plans, period? How would you know they work (or up to date, or people understand what to do, etc) without testing? I am jumping, but it sounds like the co. doesn't understand what it means to have a BC or contingency program. Then maybe you extend that to the organization didn't plan correctly for it or understand the requirements and ensure expertise to implement, etc.
C Training for RCA - Root Cause Failure Analysis Problem Solving, Root Cause Fault and Failure Analysis 9
normhowe Why is RCA essential? Problem Solving, Root Cause Fault and Failure Analysis 19
drgnrider Corrective Action for not meeting target-RCA obvious ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S RCA examples for Finance Problem Solving, Root Cause Fault and Failure Analysis 3
GStough Is "Did Not Follow Procedures" Sufficient for RCA? Problem Solving, Root Cause Fault and Failure Analysis 30
A Who should be the CAR owner & Who is involved with RCA, CAPA plan & CAPA evaluation? Nonconformance and Corrective Action 3
Q RCA (Request for Corrective Action) on an Information Transaction Process Problem Solving, Root Cause Fault and Failure Analysis 2
Ajit Basrur RCA Training by 8D approach - Ideas appreciated :) Problem Solving, Root Cause Fault and Failure Analysis 18
A Root Cause Analysis - Whether one can do RCA for Positive Findings Problem Solving, Root Cause Fault and Failure Analysis 19
V Integrating the FMEA process with problem investigation/RCA process and PFMEA FMEA and Control Plans 11
C RCA - Internal Audit Request for Corrective Action ambiguity Internal Auditing 4
Q Can any one help me on RCA (Root Cause Analysis) Problem Solving, Root Cause Fault and Failure Analysis 9
J How I Was Pushed Into RCA Coffee Break and Water Cooler Discussions 4
S Standardization of Problem Solving - 6 Sigma, Red-X, 8D, VA/VE, PDCA, RCA, C&E Quality Tools, Improvement and Analysis 15
J RCA (Request for Corrective Action) Instructions or Guidelines Nonconformance and Corrective Action 8
B Package integrity Testing failure ISO 13485:2016 - Medical Device Quality Management Systems 6
J 'Failure rate leading to false-negatives and repeat testing' - MDCG and Common Tech Specs Other Medical Device Regulations World-Wide 0
S Sterile Disposable Cardiac Guidewire 3yr Real Time Sterility Failure When Confirming Accelerated Aging / Labeling US Medical Device Regulations 3
M How to show the effect of the failure mode on the manufacturing process as a customer of product design process? FMEA and Control Plans 3
B EO Production Batch Failure ISO 13485:2016 - Medical Device Quality Management Systems 1
S Reliability issue - Frequent component failure of the product Reliability Analysis - Predictions, Testing and Standards 0
S Die casting failure Manufacturing and Related Processes 9
N Failure Analysis-Potting Gel and Sealants Manufacturing and Related Processes 1
J NCR- Failure of contract review process - NADCAP audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Test failure Root cause not found Customer Complaints 10
T Risks of failure to meet intended use ISO 14971 - Medical Device Risk Management 6
P Missing 1m visual alarm signal in case of software/display failure, mitigation? ISO 14971 - Medical Device Risk Management 3
D Failure rate vs hazard rate vs rate of failure Reliability Analysis - Predictions, Testing and Standards 2
silentmonkey How to measure severity if my product is designed for emergency use and failure would result in death? ISO 14971 - Medical Device Risk Management 9
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
JoCam Failure to test Class I medical device to IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C Kaizen Events - Factors Affecting Failure Lean in Manufacturing and Service Industries 13
C Failure nets - Same level effects FMEA and Control Plans 0
C Failure mode at 0h, vs. 1 year vs. 5 year... FMEA and Control Plans 8
R How to properly use Survival Analysis to predict time to machine failure Reliability Analysis - Predictions, Testing and Standards 0
D Testing to failure for design verification Reliability Analysis - Predictions, Testing and Standards 11
M Informational US FDA – Ethicon Recalls Circular Staplers for Insufficient Firing and Failure to Completely Form Staples Medical Device and FDA Regulations and Standards News 0
C Detection Action for Failure Effects - AIAG 4th Edition Layout FMEA and Control Plans 5
Marc NASA Says Oregon Company Metals Fraud Caused $700 Million Satellite Failure - 2019 World News 16
C PCBA Hardware Component different failure types - How to rate detection? FMEA and Control Plans 8
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
P Detection rating for a user (surgeon) related failure mode in DFMEA APQP and PPAP 3
J How to look up Failure Modes on FDA website FMEA and Control Plans 4
P Electronic component failure analysis turnaround time Reliability Analysis - Predictions, Testing and Standards 0
C Design for Assembly in DFMEA - Failure Effect of Sub-System(s) FMEA and Control Plans 5
Marc Server RAM Failure - 7 Dec 2018 Forum News and General Information 3
