5 Why's Help Needed
TacitBlue
Need to help with my 5 why's. Does this look okay? Any help is appreciated.
Problem: The ENG0002 Form, Rev. D does not include a *BPR review number and is designated as N/A; additional investigation revealed that no proof of a BPR review was conducted is on file.
WHY1: Without completing the BPR review process, the document was released to All Business Processes (our main procedure library).
WHY2: There was no peer review to ensure that the document had completed the BPR process.
WHY3: The staff (responsible doc control staff) was not notified that the document had been uploaded to All Business Processes.
WHY4: Staff are not required to complete document peer reviews prior to posting to the library, nor are they set up to receive notifications within SharePoint when a document is posted to the library.
WHY5: DOC0013 (our doc control procedure) does not require that notifications be sent to staff or that a peer review be carried out prior to posting documents to the All Business Processes library.
*BPR is our document control review process. A number is always assigned when a document is submitted for review and approval.
Big Jim
Something important is that 5 is not a magic number for determining a root cause.
The concept is based on some ancient oriental philosopher whose name I have long since forgotten, that stated something like "if you ask why enough times you can get to the bottom of the problem".
The number 5 seems to be the most common number, but it may take more or less.
Something to think about is if you can still reasonably ask why you aren't there yet.
Your final why may be sufficient. The real test is can you answer it with a corrective action. How will you address that final why? I suspect you may revise that procedure.
With all that said, you might be making things more complicated for yourself, which is a frequent issue when you make a more complex procedure. Is there an easier way to address the problem that doesn't add complexity to your system. For example the revision might stress keeping it clear while being terse (not using more words than needed).
Anyway, overall you are on the right track but I would still stress the KIS method (Keep It Simple).
Some ancient oriental philosopher? Are you thinking about Ohno? Toyoda? Or perhaps Shingo?
anyhoo. For the OP: Your ‘5-why’ seems like you are just filling out a form, by yourself. The answers to each ‘why’ are not intended to be the lack of a solution, but a real reason (with objective evidence) for the action taken. Quite simply the 5-why reads like a justification for the solution you want to put in place.
Johnnymo62
Haste Makes Waste
Try starting each why with the word because, at least mentally. It helps make sure you are answering the why question.
Why 1: Because the document was released to All Business Processes (our main procedure library) Without completing the BPR review process.
Tidge
Everyone always forgets the quality stylings of Omar Khayyam, by way of Fitzgerald:
Why, be this Juice the growth of God, who dare
Blaspheme the twisted tendril as a Snare?
A Blessing, we should use it, should we not?
And if a Curse--why, then, Who set it there?
as well as
For "IS" and "IS-NOT" though with Rule and Line,
And, "UP-AND-DOWN" without, I could define,
I yet in all I only cared to know,
Was never deep in anything but--Wine.
I prefer other questions than why. It is a fairly weak question. Ask things like “what prompted you to take that action”. Of course that can’t be honestly answered by someone sitting at their desk filling out a form to support their agenda.
TacitBlue
5 Why's has always somewhat confused me. I am always unclear at which point of the failure that I start my first "why"?
Start with your problem description (not the symptom) and ask the first why. The problem description should contain a specific Object with a specific Defect.
J Help Needed Customer and Company Specific Requirements 1
G Help Needed: Quality Control / Assurance process Quality Manager and Management Related Issues 3
Kevin Walters IAQG Required Audit Days Needed (Please help) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J Help needed on clauses identification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S Help needed in choosing the method of calculating the minimum sample size Internal Auditing 12
J HELP NEEDED ! Risk Management Exercise ISO 14971 - Medical Device Risk Management 12
A Help needed with locating conector Design and Development of Products and Processes 0
D Help needed for Compliance Road-Map - Startup making their first device (IVD) IEC 62304 - Medical Device Software Life Cycle Processes 1
V Root Cause help needed - Sheet metal breaking at press Problem Solving, Root Cause Fault and Failure Analysis 9
W TL9000 transition from 5.5 to 6.0 - help needed TL 9000 Telecommunications Standard and QuEST 1
K Processing Time Tracking Software Program Help Needed Lean in Manufacturing and Service Industries 3
N VDA 1 Critical Characteristics Requirements Help needed VDA Standards - Germany's Automotive Standards 6
G Help needed on 2 TS 16949 Elements - 7.5.5 & 7.5.3 IATF 16949 - Automotive Quality Systems Standard 2
R Excel 2003 and Capability Studies for Dummies - Help needed! Excel .xls Spreadsheet Templates and Tools 4
R ISO 13485 Software Validation Requirements - Help needed ISO 13485:2016 - Medical Device Quality Management Systems 4
D Generating a detailed Process Plan - Help needed Process Audits and Layered Process Audits 6
R ISO 9001 Implementation in the Bus/Coach Industry - Confused and Help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
O ISO 9000 section 7.2.1(c) Compliance help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
E Help needed on the TS 16949 External Auditor Exam IATF 16949 - Automotive Quality Systems Standard 8
Q Regression Analysis for the Attached Data - help needed - TIA Reliability Analysis - Predictions, Testing and Standards 13
S Interpreting Level of Confidence - Round Robin for Tensile Testing - Help needed Statistical Analysis Tools, Techniques and SPC 4
J ISO 9001 and Improvement of Business Performance - Research help Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Dew Point Meter: DPL4000 - help needed Manufacturing and Related Processes 1
W Australian Approval for Class I Medical Device - Help needed. Other Medical Device Regulations World-Wide 1
R Student Question - Help needed with statistics questions Statistical Analysis Tools, Techniques and SPC 6
L Definition Throughput Yield (TPY) or First Pass Yield Calculation - Help Needed Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
P Sample Size Calculation help needed Reliability Analysis - Predictions, Testing and Standards 4
6 Preventive Action - Help Needed. Input for Training and Sustenance Preventive Action and Continuous Improvement 3
R ISO 13485 Surveillance Audit Nonconformances and Report Help Needed ISO 13485:2016 - Medical Device Quality Management Systems 9
V Help needed with ISO 14001 Procedures please ISO 14001:2015 Specific Discussions 7
A Help needed for Fighting a specifically identified Organism found during Dose Audit Miscellaneous Environmental Standards and EMS Related Discussions 2
D AASHTO R18 Accreditation (quite similar to ISO 17025) QMS - Help needed ISO 17025 related Discussions 4
L Gage Linearity and Bias Study Analysis - Minitab help needed Using Minitab Software 4
H Husky 1750PSI Pressure Washer - Help needed! Manufacturing and Related Processes 3
L Medical Device FDA Product Classification help needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Cross Tabulation in Attribute MSA - Help Needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Trend Review and Process Improvement help needed Capability, Accuracy and Stability - Processes, Machines, etc. 6
L Easy Access of Obsolete Documents - Corrective Action help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T FDA Single Use Instruments - Classification Help Needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
T PFMEA of Die casting Process--Help needed? FMEA and Control Plans 5
P Design FMEA (DFMEA) Basics - Help needed IATF 16949 - Automotive Quality Systems Standard 3
K ISO 13485 Audit help needed General Auditing Discussions 20
U Issue with Labelling of Outer Container - help needed for clarification EU Medical Device Regulations 3
B 5 Why help needed Please kindly review Problem Solving, Root Cause Fault and Failure Analysis 15
S Excel Spreadsheet Conditional Formatting help needed Excel .xls Spreadsheet Templates and Tools 12
G Help needed to complete a Financial Audit of a Nonprofit Organization Various Other Specifications, Standards, and related Requirements 7
K Low Volume Products Data Analysis help needed Statistical Analysis Tools, Techniques and SPC 6
somashekar Water and Air Pollution Load Calculations help needed Miscellaneous Environmental Standards and EMS Related Discussions 6
S Master Document Register Project Procedures help needed Document Control Systems, Procedures, Forms and Templates 2
Ajit Basrur Tabulating Improvement Plan Status - Help and suggestions needed Excel .xls Spreadsheet Templates and Tools 9
