510(K) submission - Is it necessary if we changed from nylon to polyester suture?
Cinti
We are one of the leading manufacturers of ophthalmic eye care products. We are manufacturing surgical suture needles in four types of suture materials like Nylon, Silk, Polyester and Polypropylene. We have 510(K) approval for our Nylon and Silk sutures.
Recently we have gone through the guidelines “Deciding when to submit a 510(K) for a change to an existing device”, published on January 10, 1997. From material change and labeling change flow chart (Flow chart A and Flow chart B), we understood that we can submit documentation for the material change in an existing 510(K).
Is it possible to submit documents for getting 510(K) approval for Polyester suture other than filing new 510(K)? There is no change in our manufacturing and QA processes except material of suture (ie) instead of Nylon suture, we are attaching polyester suture in the needle. The only change in the labeling is the model number. Instructions like adverse reactions, warnings, precautions etc., in IFU are remain same. We are still manufacturing Nylon suture. This is for your kind information.
I will be very grateful if any one can advice me for submitting documents.
sreenu927
Re: 510(K) submission
Hi Cinti:
I don't think that you can submit for a supplementary 510(k) submission, although the intended use is the same for a material changed device/product, for ur case here.
From my view, as the material changing, which is a biomaterial, involves biocompatibility studies(toxicology studies for the material), which requires submission of new 510(k).
Regards
Sreenu
Michael Malis
Hi Cinti:
Regards
Sreenu
:agree:Absolutly - you need a new 510(k)
Material changed and Enginnering testing with ISO 10993 must prove that it new product is working the same way. Also you need to do Risk Analysis per ISI 14971...
MIREGMGR
If you make the suture material itself, and if the polyester suture material is not already qualified as a freestanding device or is not made from an already qualified biomaterial formulation and grade, then yes, a new 510(k).
If on the other hand the substitution is one already-freestanding-qualified material for another similarly qualified material, or a material siilarly manufactured from an already qualified biomaterial formulation and grade for another similarly qualified formulation and grade, then a Special should be possible.
Michael Malis
:yes: Agree with part 1.
:nope: Not part 2 - Both Materials can be qualified, however these 2 materials in question from mechanical properties* and processing stand point are not the same and therefore, will require Traditional 510(k)...
*Nylon to polyester have different mechanical properties and shrink factor and can't be 1 for 1 substitute for the same intended use.
L How to find a good 510(k) submission training? Other US Medical Device Regulations 2
S FDA 510(K) submission question US Food and Drug Administration (FDA) 4
V 510 k submission RTA (Acceptance Checklist ) Other US Medical Device Regulations 8
A Which guidance do you use for guiding the requirements of IFU for 510(k) submission? Medical Device and FDA Regulations and Standards News 5
T 510(k) submission - Which name should I use in the submission? Other US Medical Device Regulations 3
A Some questions about voluntary consensus standards in traditional 510(k) submission US Food and Drug Administration (FDA) 6
A Some doubts about traditional 510(k) submission US Food and Drug Administration (FDA) 5
A Bench test report translation to English for 510(k) submission Other US Medical Device Regulations 2
T First 510(k) submission - Class II software as medical device US Food and Drug Administration (FDA) 3
K 510(K) File eCopy Submission 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 16
P Predicate Device Information for 510(k) Submission Medical Device and FDA Regulations and Standards News 4
D First 510(k) Submission - Don't Forget Tips US Food and Drug Administration (FDA) 5
D Is Human Factors testing mandatory for a 510(k) submission? Human Factors and Ergonomics in Engineering 16
D Pre-Submission after 510(K) Submission? Other US Medical Device Regulations 4
M CBE (Change Being Effected) 510(k) Submission Other US Medical Device Regulations 2
K 510(K) Submission (Traditional) for Medical Device US Food and Drug Administration (FDA) 17
shimonv Referring to previously submitted biocompatibility results in a new 510(k) submission Other US Medical Device Regulations 1
S 510(k) Submission - Orthodontist that wants to distribute aligners in the US ISO 13485:2016 - Medical Device Quality Management Systems 2
shimonv Does 510(k) submission need to include UDI Data Other US Medical Device Regulations 6
D Documentation Requirements for Firmware in a 510(k) Submission Other US Medical Device Regulations 1
D Use of clinical data in a 510(k) submission Other US Medical Device Regulations 6
M 510(K) submission for clinical study devices US Food and Drug Administration (FDA) 2
V 510(K) Cyber Security Documentation for Pre-market Submission (Templates) Other US Medical Device Regulations 6
A FDA 510(k) Submission Timelines US Food and Drug Administration (FDA) 1
M Demonstrating battery safety in 510(K) submission for the FDA Other US Medical Device Regulations 9
S FDA Draft Guidance on HLA Kits 510(k) Submission 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
D FDA 510(k) Submission Tests - Posterior Cervical Spinestem 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Z Agile Software Development and 510(k) Submission 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
T 510(k) Revision Level History and Submission Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
W 510(k) Submission for a huge, changing complex Medical Device System Other US Medical Device Regulations 6
T Level of Concern for Class II Medical Device Software 510(k) Submission 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S Revision of 510(k) Submission Documents - Risk Management Report? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R Who must sign 510(k) Submission? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A Should I submit the entire copy of my software in a 510(k) submission?? US Food and Drug Administration (FDA) 7
I About the 510(k) Submission US Company but Products are made in China US Food and Drug Administration (FDA) 6
S Clinical or Non-Clinical Data in 510(k) Submission for a type II Medical Device US Food and Drug Administration (FDA) 1
shimonv Bench Testing as part of 510(k) Submission US Food and Drug Administration (FDA) 1
C Locating Approved Special 510(k) Submission Data from 1997 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
I Cost to prepare 510(k) submission (resources, time, dollars) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
T IEC 62304:2006: Medical device software SDLC- CE Vs. Fda 510(k) submission IEC 62304 - Medical Device Software Life Cycle Processes 16
W Applying for 510(k) Submission for Blood Glucose Monitor System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P Blood Glucose Monitor - Sample 510(k) submission application 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Does Windows Service Pack (SP-3) upgrade need supplementary 510(k) submission?? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
L Software Documents in 510(k) submission (Moderate Level Concern) Other US Medical Device Regulations 1
W 510(k) submission - Questions about page 2 of form 3654 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
T 510(k) Submission for Outsourced Automated Instrumentation System Components 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
T Submission of 510(k) - Does the FDA require a predefined structure of the content? ISO 13485:2016 - Medical Device Quality Management Systems 2
R EC11 - Guidance Document - FDA 510 (k) Submission - ECG Monitors 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
D FDA Question: Contents of an FDA 510(k) Submission ISO 13485:2016 - Medical Device Quality Management Systems 1
K 510(k) Manufacturer question (private label and manufacture under another persons 510(k)) US Food and Drug Administration (FDA) 1
