510k file requirements for non-sterile medical device accessories
justjat
I have a device that is 510k cleared and we would like to market extra cartridges in a separate box of ten cartridges. These cartridges have no function other than collecting samples. They are non-sterile and do not require to be sterilized. Do we need to notify the FDA of this separate "product"? If so, under what pathway?
Thanks!
mihzago
Have the same or similar cartridges been cleared with the parent device? Can these cartridges be used only with the parent device or will this be marketed as a generic accessory?
If it was already cleared with the parent device then just repackaging it should not require additional submission. If this is a modification to the cleared cartridge then depending on the modification you may be able to just file as an LTF (letter to file) against the parent file, or a special 510(k) for significant changes.
MIREGMGR
I agree with Mihzago's analysis.
Of course, there are a few Product Codes for which dependent components and accessories have separate Product Codes. If that were the case for your parent and child products, you might need to consider whether separately marketed cartridges would need to have their own classification so as to be properly Listable.
Mark Meer
Question: is this applicable even if the accessories are exclusively intended to be used with the parent device? ...or is a separate classification only necessary in cases of "generic" accessories?
justjat
Thanks, all.
It is the same accessory that is previously cleared and can only be used with that device.
Regarding your Listable comment - if I want to list this as a separate SKU, I will need to do a separate file?
mogluk
I would not think that you need to file, as long as you document required activities in engineering release process you should be fine. most product do not need an additional listing for an addition sku that is quantity based.
MIREGMGR
There's no uniform answer to that question. FDA over the years unfortunately has not been at all consistent in regard to Product Codes, guidances and 510(k) approaches. Each product context needs to be reviewed by a person with comprehensive knowledge of the applicable regulatory situation.
P Letter to file or special 510k or traditional 510k 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N 510k without DHF (Design History File) that we bought a 3 years ago US Food and Drug Administration (FDA) 4
S Similar Medical Devices - 510k versus Letter to File 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
D File a new 510k for change or not? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
N Traditional 510K Submission-Financial Certification or Disclosure Statement 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
Y 510k requirement for bringing in gloves Medical Device and FDA Regulations and Standards News 0
G Special 510K possible? Only the packaging has changed Other US Medical Device Regulations 0
H 510k with Contract Manufacturer Other US Medical Device Regulations 2
K FDA 510k electrosurgery 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
J Leveraging FDA 510k Clearance for International Registrations Other Medical Device Regulations World-Wide 2
K 510K new manufacturer but same components Other US Medical Device Regulations 6
S Two or more predicates suitable? 510K submission US Food and Drug Administration (FDA) 5
S 510k: What to include if your own device is the predicate US Food and Drug Administration (FDA) 5
L 510K - Trade Name Change 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
Ed Panek Adverse Event Clinical Trial using a 510K approved Device Other US Medical Device Regulations 6
R Countries that accept 510k approvals - Class II nonsterile medical device Other Medical Device Regulations World-Wide 2
M Timing of 510k submission Other US Medical Device Regulations 9
S Examples of software changes that required a 510k US Food and Drug Administration (FDA) 2
D 510K and Changes to Verification and Validation US Food and Drug Administration (FDA) 2
Ronen E Can anyone please explain this? (510k submission requirement) Other US Medical Device Regulations 14
H New 510K VS Documents about design change. Other US Medical Device Regulations 1
P Medical Device not on commercial distribution but installed in the establishment. 510k? Other US Medical Device Regulations 10
V Presubmission FDA for 510k US Food and Drug Administration (FDA) 4
A How to deal with changed shared components in 510k 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N Can we take a part from 510k cleared medical device and use it in class I device? Other US Medical Device Regulations 3
D Contents of a 510k Q submission Other US Medical Device Regulations 1
L Class IIa Medical Device, CE Mark & 510k - Labeling Content CE Marking (Conformité Européene) / CB Scheme 4
Ed Panek Other company wants to use our FDA 510K bundled with their product 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
L 510k exemption process - Do you still need to submit technical dossier? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S IEC 62133 - CB Scheme Required by FDA 510k Other Medical Device Related Standards 3
S The key differences in 510k types - Traditional vs. Abbreviated vs. Special US Food and Drug Administration (FDA) 0
P V&V for Special 510k 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Clarity on requirements for a 510k exempt Class I device - Suture removal kit US Food and Drug Administration (FDA) 9
T Is 510k Anesthesia group particularly picky/difficult to work with during 510k? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
J 510k - Product shelf life validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K 510K statement Questions 21 CFR 807.93 - Discontinued or never released for sale US Food and Drug Administration (FDA) 0
J Applying for 510K - What is a significant process change and what is not US Food and Drug Administration (FDA) 5
K 510K Interactive Review 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
I Celsius and Fahrenheit in 510k US Food and Drug Administration (FDA) 4
R FDA 510K - Does the FDA accept the testing report from other countries? Other US Medical Device Regulations 1
I 510k Performance Testing Studies (Raw Data) - What does the FDA expect 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P Is a different 510k is required for each (stand alone) software configurations? Other US Medical Device Regulations 3
K ISO 10993 Requirements For 510k - Substantial Equivalence Other US Medical Device Regulations 11
P Two separate 510k submissions for one device from the same company Other US Medical Device Regulations 10
I Special 510k Imported Legacy Blogs 0
K 510k "Premarket" Submission for Existing Class II Software Medical Device US Food and Drug Administration (FDA) 3
N Is a new 510K required for change of manufacturing location for an existing device? US Food and Drug Administration (FDA) 1
Q 510k Submission for a New Medical Device Product Other US Medical Device Regulations 3
W New 510k required for a material change? Other US Medical Device Regulations 9
