5S Red Tag and ISO Procedure Red Tag - Tag Color Conflict
Rochy
My ISO procedure stated that the red tags is for Customer Returns, however, our 5S program stated that the red Tag is for product that we are not goin to use. Is not this a conflict in color code? Please advise
Re: 5S Red Tag and ISO Red Tag
My ISO procedure stated that the red tags is for Customer Returns, however, our 5S program stated that the red Tag is for product that we are not going to use. Is not this a conflict in color code? Please advise
Would there be a confusion with the people using the tags? Do the people who use them who handle product, ever get to handle customer returns? The color isn't exactly the issue, more the reason for the reject and how you process it.
Your procedure can explain both - as long as the people are clear in what's going on. It doesn't HAVE to be an "either, or" situation...
Golfman25
Why would there be any confusion? A red tag on a box of produced product means a customer return. A red tag on something typically used for production means we are going to eliminate the item.
what about the color blind folks?
seriously, symbols and text can be used to denote what the tag is for. don't get all wrapped around the axle on this.
Most 5S red tags I have seen are not blank red tags. The same hold true for quality red tags. Normally, they have some data fields on them. So, the identification to tell them apart would be the data fields. If they are both blank tags, you could use the same tag for both. But once again, in both instances, you want to record on the tag why the tag was there, so there still should be no problem figuring out which is which.
You would probably need some form of guidance on how to tell the difference, but that, too should be no biggie.
U Form and Procedure for Red Tag in 5S Lean in Manufacturing and Service Industries 3
B Should there be a Red Tag Time Limit, in regards to 5S Lean in Manufacturing and Service Industries 13
W Nonconformance ID tags - Seeking universal non-conforming Red Tag - Approx. 4" x 6" Document Control Systems, Procedures, Forms and Templates 3
M Reject Tags - red tag is a form and needs to have a part number and revision? Document Control Systems, Procedures, Forms and Templates 14
S Red tag or not to Red tag... ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B Where to acquire EN 868-5 required dye (Amaranth red)? Other Medical Device Related Standards 2
M MDR, RED and LVD - Should our device comply with them? EU Medical Device Regulations 3
R IATF/IAOB Red Supplier Pilot Program IATF 16949 - Automotive Quality Systems Standard 1
M Harmonised RED Standard ETSI EN 440 - Which Version? Other ISO and International Standards and European Regulations 0
P Are red non-conformance bins required anywhere in the ISO or IATF standards? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
O EMC testing under RED and IEC 60601-1-2 CE Marking (Conformité Européene) / CB Scheme 1
C Looking for RED ESD Bags that preferably say NON-CONFORMING Manufacturing and Related Processes 5
R AS9102 - Are FAIs against a Customer Red-Lined Drawings Allowed? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R IEC 60601-1 4th Edition - Is a "Red-line" version available? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Marc Definition RED = Radio Equipment Directive Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
Y Can manufacturer select AR for MDD different from AR for RED? EU Medical Device Regulations 5
S ISO 9001 Audit Checklist - Red, Yellow and Green status Quality Manager and Management Related Issues 10
W Red Ballooning Stamp for Adobe Acrobat Files Quality Manager and Management Related Issues 1
M Shewhart Control Chart for SPC In Excel - Explain the yellow and red marked column Statistical Analysis Tools, Techniques and SPC 2
C Red Plague Control Plan (RPCP) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Douglas E. Purdy Where to buy Little Red Arrow Stickers Coffee Break and Water Cooler Discussions 11
V Where to find Red/White Rust Rating Requirements? APQP and PPAP 4
T Red Rabbits with Multiple Failure Modes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T End of Line Testers - When to use Red Rabbits? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T Red Metric on a Customer Scorecard is a Major Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
Randy Getting Red X 's in a box instead of pictures - I need some information.... After Work and Weekend Discussion Topics 10
Q Red Stamped Printed Paper vs. Electronic Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
RoxaneB Interviews and Slaloming through the Red Flags Career and Occupation Discussions 3
B Problem Solving Methodology Help - Shainin/Red X Problem Solving, Root Cause Fault and Failure Analysis 19
T Stamping Original Paper Document 'Record Copy' in Red Ink - Document Control Document Control Systems, Procedures, Forms and Templates 4
R Red LED vs. White Light Inspection Lamp Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Steve Prevette Red Bead Video on YouTube Philosophy, Gurus, Innovation and Evolution 6
Ajit Basrur FDA Warns Consumers Nationwide Not to Eat Certain Types of Raw Red Tomatoes US Food and Drug Administration (FDA) 5
Steve Prevette Red Beads in Ohio on May 21 - Kitty Hawk Chapter of the ASSE in Kettering Ohio ASQ - American Society for Quality 3
J Where to draw the line with Red Lining? US Food and Drug Administration (FDA) 7
J The Red Plague - Improper copper wire coating process causes oxidation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E GM's RED X - Supposed to be a simple tool to find Root Cause Problem Solving, Root Cause Fault and Failure Analysis 25
S Products affected with Sudan I ( Sudan Red ) World News 0
S Standardization of Problem Solving - 6 Sigma, Red-X, 8D, VA/VE, PDCA, RCA, C&E Quality Tools, Improvement and Analysis 15
apestate Writing on Customer Engineering Drawings - Red Lining? Document Control Systems, Procedures, Forms and Templates 14
N How can I do the Red Bead Experiment? Hotel Industry Statistical Analysis Tools, Techniques and SPC 3
D Red, Yellow, and Green and QS9000 Suppliers - Visual evaluation of the status QS-9000 - American Automotive Manufacturers Standard 2
P Quality Games and Deming's Red Bead Experiment Training - Internal, External, Online and Distance Learning 18
R Specific ISO requirement to fill in all spaces on a move tag? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
S Conformity vs. 8130-3 tag creation date Federal Aviation Administration (FAA) Standards and Requirements 1
L Valid reasons to omit an "ear-tag" type label on a cable? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
T EFA or F/C on the TAG EASA and JAA Aviation Standards and Requirements 1
T EASA TAG Block 11 Status/Work issue Quality Manager and Management Related Issues 1
I Faster way to Tag Parts for Painting Manufacturing and Related Processes 8
V Ford Dimensional Tag Characteristics requirements APQP and PPAP 2
