6-32 UNC-2B Threads are Tight after Cleaning before Painting?
CarolX
#11
Do they form the thread or cut them ? I am going through a tight thread issue on some extruded parts since switching to a form tap. I have not figured it out yet but we are seeing .010 variation in minor diameter after threading even though we make a consistence drill hole. As you can see this is causing tight threads on some parts. Seems limited to blind tap holes for me.
Just off the top of my head - you may want to check with your tooling supplier - a form tap requires a larger drill hole to allow for material flow.
#12
I've seen a lot of instances where it was possible to check a threaded hole with the fastener it was designed to mate with, thus bypassing all of the trouble with exact fit to thread gages. Sometimes a screw will fit just fine, and function perfectly, when a thread gage won't go or is excessively tight. Of course, care must be taken to insure that the method is valid, but oftentimes it is. If you can't make a reasonable performance prediction though, all bets are off and you're stuck with the gage.
qcman
Registered Visitor
#13
Yes we drill a larger hole than you would when cutting threads. We actually found it necessary to go .002 under recommended size to prevent going oversize on minor diameter. We do not see the variation when cutting that we do forming however tap breakage is now small and no chips to deal with. I agree with Jim about the fastener working fine even when the gage is tight or even fails.
Q
QCAce
#14
Re: Threads are tight after cleaning?
My guess is that some debris is disturbed or otherwise mixes into the threads themselves during the wash process.
The other thing to consider is galling with the clean aluminum. Google the term
"thread galling" or "cold welding" to get some insight.
Update.....
I did some research and found this about thread galling:
http://www.accuratescrew.com/TechTips/?TipNO=4
After reading this, I tried a test where we put a little lube on our thread gage and sure enough, it slipped in and out of the threads just fine. The No/Go side of the thread gage did not go, so I would guess if the threads were not correct, the Go side would not have fit either.
It makes a little more sense to me. The supplier is checking their parts with their thread gage at the machining station, where of course there would still be some nice, lubricating cutting fluid already in the hole.
Short-term I'm having a small bottle of lube available at Assembly.
Wes -- were you a mfg engineer for a screw manufacturer in a former life? Not sure how you know about all the different things you do. :thanks:
Wes Bucey
Prophet of Profit
#15
Update.....
"Not sure how you know about all the different things you do."
It's MAGIC!:magic::lmao::lmao::lmao:
andygr
#16
Do not overlook the propert of AL to form a oxide on the surface soon after exposure. When welding accetone is a recomendation to remove the oxide.This oxidization process would be accelerated if exposed to temperature and moisture ( plus possably the additives in cleaning stations). Some form of protection based on the alloy to the threads soon after tapping plus some extra care in masking can help to minimze this condition.
:2cents:
#17
Jim Wynne! How could you stand there, riding that bicycle and say such a thing! :D I'm amazed that one so learned would propose such heresy!;)
Which mating fastener are you going to use to 'accept' the threads?
Depending on the thread fit and the variation of the fasteners would have some influence on whether all the parts were good at assembly. I've personally had painful experience where someone proposed such acceptance of threads.
I'd only suggest qualified gauging be used..............
Wes Bucey
Prophet of Profit
#18
Should this be placed in the Coffee Break Forum? This statement by Mr. Wynne is a statement which probably needs some smileys to indicate it is not to be taken seriously by a Quality professional, but is merely a weak attempt at injecting some humor into the thread.
Stijloor
#19
:topic: :topic:
Stijloor.
5
56flh
#20
I have some 6-32 UNC-2B threads machined into an aluminum die cast part that are failing (too tight) from our supplier. The supplier is claiming that this is because of the wash cycle prior to paint. Has anyone heard of this condition? Any way to fix the problem other than re-tapping the holes after paint?
Haven't heard of wash cycle disrupting thread form unless its possible that corrosion may be taking place.
The part could possibly be run with a different pitch diameter tap.
Pitch diameters limits for 6-32 taps:
H1 .1177/.1182
H2 .1182/.1187
H3 .1187/.1192
M .125-40 UNC-2B Thread requiring Inspection to Thread Gage "Method A" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
L UN Class 5 Tolerances - Thread Setting Plug Gage 7/8-9 UNC 5 General Measurement Device and Calibration Topics 23
G AN316-12 nut Hexagon threads looks weird Manufacturing and Related Processes 1
K Things to learn during lockdown.... Safety-related books/articles/threads Book, Video, Blog and Web Site Reviews and Recommendations 2
G Oversized Threads - What sized stab pin would be best to quickly check for oversized thread holes General Measurement Device and Calibration Topics 5
J Painted cut threads - ASME Pipe Suppliers Manufacturing and Related Processes 6
S Gauge R and R - Product - Conveyor belt with threads that goes on Sprocket Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
Marc Search - Search for Discussion Threads started by a specific User Elsmar Xenforo Forum Software Instructions and Help 0
Marc Forums - "Watching" One or More Forums for New Threads and New Posts Elsmar Xenforo Forum Software Instructions and Help 1
Marc New Posts and New Threads - Monitoring (aka "Watching") Elsmar Xenforo Forum Software Instructions and Help 1
Proud Liberal Collapsing Forum FAQ threads Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 4
KyloDen Checking Threads - Discrepancy in threads that are machined In-House vs. Outsourced General Measurement Device and Calibration Topics 11
Kronos147 ISO 9001:2015 threads in the standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
kedarg6500 What is the difference between NS & NF3 stand for threads Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
B Doing MSA Variables Data Study on Threads Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Measuring Multiple Start ID/OD Threads Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
T Thread Wire Measurement - 3 Wire Method for BSPP Threads General Measurement Device and Calibration Topics 1
B Computing Failure Torque for Helicoil Threads in 6061-T6 Aluminum Design and Development of Products and Processes 5
BradM Six Sigma Forum - Suggested reference threads Six Sigma 0
B Accepting/Rejecting Threads WITHIN Gage Tolerance General Measurement Device and Calibration Topics 2
P Trying to figure Minor ? on Female Rolled Threads Various Other Specifications, Standards, and related Requirements 1
Q Threads for Knurls referenced on drawing - German standard DIN 82 Other ISO and International Standards and European Regulations 3
Wes Bucey Wes Bucey Job Threads Career and Occupation Discussions 10
somashekar Information sharing: Week 22, 2010 (HARDNESS, THREADS, BEARINGS) The Reading Room 3
R Thread Inspection - Using go/no-go gaging to inspect threads Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
M "All threads Coated" - 8.2.4 Monitoring and Measurement of Product question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C ID (Inside Diameter) Threads Shrinking due to Heat Treatment and Weld Manufacturing and Related Processes 11
Q Are there any threads specifically concerned with designing with AutoCAD? Design and Development of Products and Processes 1
B Drunken Thread Inspection - Gauges for quick check for drunken threads General Measurement Device and Calibration Topics 3
Hershal Congrats! Let's talk about top posters in the threads General Measurement Device and Calibration Topics 17
S Plating Internal Threads in Tapped Holes - Go Gage no longer enters Manufacturing and Related Processes 23
J Gaging for Dryseal Pipe Threads (NPTF) and calibration of these gages General Measurement Device and Calibration Topics 11
D What does NS stand for in reference to threads? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
G How to properly check British Standard threads? 3-wire method and a supermic General Measurement Device and Calibration Topics 39
B Process Transfer - How to analyse all items and threads? Quality Tools, Improvement and Analysis 1
L Magnetic Particle Inspection - Where's the threads? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
Scott Catron PLEASE READ before posting or viewing threads Funny Stuff - Jokes and Humour 0
S A Better Way to Inspect Timed Threads Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
L Internal threads - Maximum / Minor accept/reject diameter inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Marc Cp vs. Cpk - A Visual Animation and Related Discussion Threads Capability, Accuracy and Stability - Processes, Machines, etc. 15
Q Maximum minor thread diameter of UNF internal threads Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
apestate Need supplier, error-proof inspection of ID threads present attribute Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
P Anodising - Effect on M6 x 1.0 internal threads Manufacturing and Related Processes 6
L How to Measure the Minor Diameter of Internal Threads General Measurement Device and Calibration Topics 41
C Training on calibration of threads - Unified, ACME, Butress, British, etc. Training - Internal, External, Online and Distance Learning 2
P Thread Quality in Aluminium - Problems with the threads stripping out Manufacturing and Related Processes 7
Govind Software quality related forum threads-stat Software Quality Assurance 10
RoxaneB Rules and Guidelines for Coffee Break Forum Threads and Posts Coffee Break and Water Cooler Discussions 86
B MJ vs. M Thread Designation - All About Fastener Threads General Measurement Device and Calibration Topics 6
C Thread Classifications - External or internal threads - Class 1 or Class 4 - Pitch? Misc. Quality Assurance and Business Systems Related Topics 4
