61010-1 Accessible Parts - Limit Values and Crepage and Air Clearance Distances
antonoia
HI All, I have a terrible doubt on some 61010-1:2010 clauses, I hope you can help me.
Clause 6.3.1 gives limit value for accessible parts in normal condition, 33Vrms ,46.7Vp and 70Vdc. And for equipment intended in wet location 16V rms , 22.6Vp and 35Vdc. That means if have a internal circuits (properly separated from mains) with voltages below these values separation toward accessible parts would not be required?
Table 6 (clearances and test voltages for secondary circuits derived from mains circuits..)., starts with a value of 16Vac and 22.6Vp or dc. Oddly enough they are same limit values for accessible parts for equipment in wet locations of caluse 6.3.1. Is this further confirm that circuits with value below clause 6.3.1 do not need separation or do I still need to apply linear interpolation? But I did not find confirm of my bellief since the next table for crepage requirements , table 7, starts with a working voltage of 10 V rms or dc. According table 7 separation will be required , it is the linear interpolation applicable also to voltage less than 10V? So, if I have 5 Vdc what clearance and creepage should I have to the accessible parts? Hope you can help me to undertsand the relation of caluse 6.3.1 and table 6, 7. Many thanks!
Stijloor
Re: 61010-1 Accessible parts, Limit values and crepage and air clearance distances
A Quick Bump!
Can someone help?
Thank you very much!!
H IEC 61010-1 Clause No. 10.5 Resistance to Heat - Sub Clause 10.5.3 Insulating Material CE Marking (Conformité Européene) / CB Scheme 6
H Required explanation of sub clause 7.2.101.2 (Exception) of IEC 61010-2-020:2006 CE Marking (Conformité Européene) / CB Scheme 5
B 3-phase supply, overvoltage catogory, line-to-neutral and working voltage (IEC 61010-1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
M IEC 61010-1 requirements for motors Other Medical Device Related Standards 0
B IEC 61010, Touch currents related to burns at higher frequencies (cl. 6.3, A.3) Other Medical Device Related Standards 0
B IEC 61010-1 - Voltage / Dielectric strength tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
J Universal Power Cord with Adapters - IVD IEC 61010-2-101 CE Marking (Conformité Européene) / CB Scheme 6
M Define voltage and frequency to perform tests 61010-1 and 61326-1 for CE certification CE Marking (Conformité Européene) / CB Scheme 4
E IEC 61010-1 Dielectric strength test of inner power supply Other ISO and International Standards and European Regulations 0
T List of Tests - IEC 61010-1, 3rd edition and IEC 60601-1, 3.1 edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
G IEC 61010 - Single Fault Condition - Protective Impedance Implementation IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
I IEC 61010-1 and Flammable Liquids Other ISO and International Standards and European Regulations 1
O Flammability Requirement for Gaskets and Seals - UL 61010-1 CE Marking (Conformité Européene) / CB Scheme 4
K IEC 61010-2-100 Labeling question - IVD equipment Other ISO and International Standards and European Regulations 1
C IEC EN 61010 3rd Edition Safety Design Checklist Other ISO and International Standards and European Regulations 3
F IEC 61010 Creepage and Clearence Requirements Other ISO and International Standards and European Regulations 2
G IEC 61010 Humidity Preconditioning and Condensation CE Marking (Conformité Européene) / CB Scheme 4
E EN/UL/CSA 61010 -1 (ed3) Safety and use of Software to Prevent Electrical Hazard CE Marking (Conformité Européene) / CB Scheme 3
O IEC 61010-1 Ed 2: "Automatic Disconnection of the supply" CE Marking (Conformité Européene) / CB Scheme 3
T Is IEC 61010 needed for a populated PCB within a unit? CE Marking (Conformité Européene) / CB Scheme 2
L Does IEC 61010-1 apply for Surgical Microscopes? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E EN 61010-1:2010 Requirements Interperation for a Product CE Marking (Conformité Européene) / CB Scheme 1
L Temperature - IEC 61010-1 ed2 & ed3 at chapter 10 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
P IEC 61010 3rd Edition - When devices are listed to the 2nd edition CE Marking (Conformité Européene) / CB Scheme 5
S IEC 61010-1 and IEC 60601 - Borderline Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
B IEC 61010-1 Certification Requirements, and External Supply/ELV questions CE Marking (Conformité Européene) / CB Scheme 4
S Advantages of IEC 60601-1 over IEC 61010 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R Is IEC 61010-1 required for my silly little device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M IEC 60601 vs. IEC 61010 - CE Mark for our IVD medical device IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
R IEC 61010 vs IEC 60601-1 to ISO 15197 - Blood glucose monitoring device IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
T CB Scheme IEC 61010 / IEC 60601...+ NRTL mark IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
A APPLIED vs ACCESSIBLE PART IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
T Accessible metal parts connected to secondary ground IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E How to test 8.7.4.7 d) ? What "not protectively earthed accessible part" means? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
aleexander Grounding of metallic accessible parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B Accessible parts per 8.4.2 b) - Touch currents in combination with MOOP or MOPP? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
C IATF 16949:2016 Section 8.5.1.2 item d) accessible for use at the designated work area(s) IATF 16949 - Automotive Quality Systems Standard 5
Ahang Separation between secondary circuit and accessible parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
V 2MOP of mains voltage is required between 2nd Circuity and Accessible parts? IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
M Barrier Free vs. Wheelchair Accessible - Differences Occupational Health & Safety Management Standards 1
A Insulation between Secondary Accessible Parts and Earth IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
A Ground bond test when no ground is accessible IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B Should Documented Procedures be accessible to all people/employee? Document Control Systems, Procedures, Forms and Templates 20
T Section 7.5.1.2 - Instructions SHALL be accessible for use at the workstation IATF 16949 - Automotive Quality Systems Standard 18
Q Work Instructions 4.9.1 - Work instructions must be readily accessible QS-9000 - American Automotive Manufacturers Standard 8
T Counterfeit parts training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K Process FMEA responsible For "Make to Design Parts" (Inhouse or Suppliers ?) FMEA and Control Plans 3
Q AS9100 Counterfeit Parts Prevention/Mitigation Work Instruction? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
H Does ISO state in anyway that we MUST keep physical first piece parts? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B Spare parts of medical device need CE mark? EU Medical Device Regulations 0
