7.5.2 Validation of Processes for Production and Service Provision
Shredder
I have smoke coming out of my ears trying to understand the "special processes" portion of this 7.5.2.
For the past three years, we have passed AS9100 audits with an exclusion to 7.5.2., since this states: "the organization shall validate any processes for production and service provision where the resulting output cannot be verified by subsequent monitoring or measurement, and as a consequence, deficiencies become apparent only after the product is in use or the service has been delivered"... "often referred to as special processes". Ok, check, got that part... Any work that we do with an outside service supplier comes back to our shop, goes through a thorough QA review prior to being sent to the customer. We make PWB's, no assembly, that's it, copper, laminate, holes and traces. So for us, we do not do any special processes that cannot be validated in house... any OSS processes take place PRIOR to final QA testing procedures, therefore the process IS validated in house, before delivery, our failures don't make it out the door. Any failure that takes place outside of our company after delivery would realistically be due to components and/or assembly, which we do not have any control over or responsibiltiy to. Anyway...
I have had an auditor recently tell me regarding our exclusion and I quote "Bull---t! If your telling me you don't have special processes you're lying", my explainations falling on deaf ears :argue:. I don't feel like changing my entire quailty system for a client auditor, but at the same time I'm not sure how to address the validity of this claim, successfully. Any feedback from anyone out there?
A sincere advance thank you to anyone who can help me wrap my brain around this finding.
Jason PCSwitches
You state "around this finding", so that tells me you got an NC on this correct?
What was cited as the evidence on noncompliance??
Shredder
My apologies, I should have clarified. Yes, I have a "nice" audit finding over this issue and a request for corrective/preventative action that I have to complete.
Jason PCSwitches
How does the NC read - verbatim??
silentrunning
My thinking is that until he finds the special process that you're not validating, he has no basis for an NC.
How can I put this to you? Pretty much your whole process of making a circuit board (well, the important bits, the trackwork, plating etc) is a "special" process!
The process of plating has always been considered a special process! The process parameters and controls are what define the quality of the plated pcb - how much plating is deposited, the shaped etc. I can tell you from some hard won experiences, that the quality of adhesion/plating etc cannot be inspected.
I probably wouldn't have phrased it in that manner, but maybe it's because your system doesn't call it a 'special' process, because it's not special. You do, however, have to meet those requirements, since you are plating.
BTW - I was responsible for pcb quality for a number of interesting and informative years!
Shredder
Basically: "within the aerospace industry, fabrication of PWB is considered a special process; however Company X has taken an exclusion to this requirement".
My response is I can understand how big aerospace company considers my product a special service they outsource [to my company], but since it's my product, my processes and validations, why does my system automatically have requirements for becoming a mirror of theirs? It's confounding!
Sidney Vianna
Post Responsibly
So for us, we do not do any special processes that cannot be validated in house... .
So, do you validate the process or not? You are claiming an exclusion to 7.5.2, but you just wrote that you "validate the process" in house. There is a difference between inspection and validation. Many people mistakenly believe that a thorough visual inspection negates the need for process validation.
In principle, the manufacturing of printed wire boards contain several processes that could be deemed special, such as: Chemical etching, lamination, exposed conductor plating and coating, solder resist, electrochemical migration, etc.
Chances are, you do have sub processes that should be validated. But to know for sure, a thorough review of your customer requirements and the specifications associated with your outsourced processes would have to be done. I don't think your auditor did a good job of articulating his statement of nonconformity, but I don't think he is totally off the mark here.
You simply have to be able to answer the question 'Can you check the quality of the track work, plating, adhesion of plating, plating thickness, track undercut, etc by inspecting the product, and assure the quality (at a reasonable cost, too) to the customer?
The answer is NO! It isn't possible. (at least not in the more advanced markets)
I suspect that you do not have a clear understanding as to what a special process is.
In the simplest of terms, it is a process that you cannot tell the outcome of from normal inspection. Some processes that nearly always fit into that category are welding, brazing, soldering, and plating. Since plating is part of what you need to do to make your product, it fits into that category.
Lets take a closer look at the processes mentioned. Although you can tell a lot about a weld from inspection, you really can't tell if there was sufficient penetration to properly bond two pieces of metal together. The only absolute way to know for certain is to pull it apart, destroying the piece, to confirm that it did not come apart at the seam, but that it pulled parent metal with the weld. If you need to destroy the part to confirm a proper weld, how can you sell it?
Brazing and soldering are similar to each other. It is not welding, since you do not mingle the metal pieces. It is necessary to get the molten solder or brazing material hot enough to flow over the entire mating surface as well as have the parts clean enough and the use of appropriate flux so that there is a good bond. Again, you can tell a lot about a solder joint from inspection, but it is possible to have a good looking joint that is unsatisfactory. Again, you need to destroy it to tell for sure and that makes it unsellable.
Plating quality cannot be told simply by inspection although you can tell a lot. You cannot tell if the plating will flake off when bent simply from inspection. You cannot tell that the surfaces were clean enough to ensure the proper bond of the plating material to the base material. Once again, you can tell more from a destructive test, but then you can't sell it.
So what do you do when you can't tell the quality from normal inspection (verification)? You validate it. How do you validate a special process? The answers are given in the letters of 7.5.2.
Again, in the simplest of terms. You can validate plating by following the plating specification (recipe) and part of the validation is keeping records of your process controls. Tank chemistry logs, recording the math used to calculate the tank times and the rectifier settings. Recording the actual tank times and rectifier settings.
You validate soldering by a combination of training and then visual inspection following a known set of standards. The J standard for training the operators comes to mind. The number of the related one does not come firmly to mind, but I think part of the number is 160. Both of these are revised every five years or so. The most current is 2010. Both of those standards are not fully useful without the training aspect.
There is more than one way to validate welding, depending on the application, but the premier method is by certifying the welder. The welder is trained, then samples of his welding are provided to a welding certification lab where it undergoes a battery of NDT followed by pulling the samples apart. The certifications are specific to the metal involved, the type of equipment used, the thickness of the metal, the type of joint, and even the position of the weld (gravity's effect on the molten puddle plays a big factor). To be a broadly certified welder, it takes a lot of samples so it can be a very expensive undertaking. Once the welder is certified it is presumed that the welds are good, although in some schemes the testing has to be repeated from time to time.
It is very likely that you actually are validating your special processes and don't realize it.
A really big thing to point out is that just because earlier auditors didn't catch it before doesn't mean it is right.
D 7.5.2 Validation of Processes for Production and Service Provision AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Validation Processes of Production & Servicing - API Q1 clause 5.7.1.5 Oil and Gas Industry Standards and Regulations 2
A 7.5.2.1 Validation of Processes for Production and Service Provision IATF 16949 - Automotive Quality Systems Standard 7
D 7.5.2 Validation of Processes for Production and Service Provision - Distributor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Y 7.5.2 Validation of Processes for Production and Service Provision Discussions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
H Excluding 7.5.2 - Validation of Processes for Production and Service Provision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
B Validation of Processes for Production and Service Provision - 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Understanding AS9100 Clause 7.5.2 Validation of Processes for Production and Service AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A Validation of processes for production for Test Equipment ISO 13485:2016 - Medical Device Quality Management Systems 9
B Validation of processes for production & service provision - Service industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
V Validation of Processes for Production and Service Provision Procedure Document Control Systems, Procedures, Forms and Templates 8
R Validation of Processes for Production and Service Provision - Clause 7.5.2 IATF 16949 - Automotive Quality Systems Standard 4
R Validation of Processes for Production - How are doing it? Clause 7.5.2 Reliability Analysis - Predictions, Testing and Standards 25
M Examples for Clause 7.5.2 - Validation of processes for production and service ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Exclusion from Validation of Processes for Production and Service Provision? Service Industry Specific Topics 17
D 8.5.1.2 Validation and control of special processes requirements for Heat Treat External Processor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R Validation of processes Oil and Gas Industry Standards and Regulations 2
N Validation of special processes - thread closed Oil and Gas Industry Standards and Regulations 3
M Is Validation of Plating Processes required and who is responsible? Qualification and Validation (including 21 CFR Part 11) 11
Stoic Manual soldering processes - 100% verifiable, or always requiring validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
T ISO 13485:2016 - Processes exempt from process validation ISO 13485:2016 - Medical Device Quality Management Systems 12
J ISO 13485 - 7.5.2 cleanliness , 6.4.2 validation of special processes, and 6.4.2 contamination ability to be exempt? ISO 13485:2016 - Medical Device Quality Management Systems 5
GoSpeedRacer Validation of Processes 7.5.6 - Do cosmetic welds need process validation? ISO 13485:2016 - Medical Device Quality Management Systems 3
P Validation of Processes - What is meant by 7.5.6 (a) - Defined Criteria for Review ISO 13485:2016 - Medical Device Quality Management Systems 7
S Re-validation NCR - In which cases re-validation of processes is required Oil and Gas Industry Standards and Regulations 6
M AS9110C Clause 8.5.1.2 Validation and Control of Special Processes for Repair Station AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
W AS9100D Clause 8.5.1.2 Validation and Control of Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 37
I Bracketing for Validation - Processes that share some unitary operations Qualification and Validation (including 21 CFR Part 11) 4
J ISO 9001 Clause 7.5.2 Validation of Processes - How to comply? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
M Looking for a simple procedure on section 7.5.2 for Validation of Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO/TS 16949 - 7.5.2 - Validation of Processes And 7.5.2.1 All Processes IATF 16949 - Automotive Quality Systems Standard 1
E What are Validation Requirements for Vendor (Supplier) Processes Supplier Quality Assurance and other Supplier Issues 5
K Validation of Processes does not seem to apply - Scientific Research Company Design and Development of Products and Processes 1
F External Storage of Data - ISO 9001 Clause 7.5.2 Validation of Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Validation of Special Processes - Are Casting and Forging Special Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
N Validation of Special Processes - N/A of ISO 13485 Clause 7.5.2 ISO 13485:2016 - Medical Device Quality Management Systems 12
M Validation of Processes - Is Cl 7.5.2 applicable to bricktile firing in an oven? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
L Outsourcing "passivation" - Clause 7.5.2 Validation of Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
O Format for Clause 7.5.2 (Validation of Processes) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T Validation of processes 7.5.2 - We are a label printer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Validation Of Outsourced Special Processes under AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
V Validation & which processes are called special processes & why not all the processes Manufacturing and Related Processes 9
C Equipment, Software and Processes Validation for Medical Devices - 21CFR 820.75 (a) ISO 13485:2016 - Medical Device Quality Management Systems 35
L Validation of Processes - Plastic Injection Moulding - ISO 9001 Clause 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
K Validation of Processes - How do I address TS 16949 Sec. 7.5.2.1 IATF 16949 - Automotive Quality Systems Standard 30
L Validation of Processes - Resulting Output can not be Verified - Exclusion to 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
R Validation of outsourced processes - Calibration - How do we validate that? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Software Validation Processes - Telecommunications software Software Quality Assurance 10
A Validation of Processes - How to meet requirement of TS 16949 para. 7.5.2.1? IATF 16949 - Automotive Quality Systems Standard 12
F Process Validation of 'Special Processes' - How do I? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
