7.5.3 prod id and traceability master list of records
juliov
I need your opinion about the following point:
I did search the cove threads about this topic but did not find the correct interpretation. Here it goes:
Clause 7.5.3 in the records required by ISO 9001 : 2000 is listed as required
I would welcome to read your interpretation of this clause as to how to show compliance, the issue I am having is what records are needed (one suggestion stated: "the unique identification of the product, where traceability is required") can you expand a bit further, any examples would help visualize the depth and breadth of this clause. I am trying to fill in the master list of records with location, filing, retention and disposition. Since there are many functions how do we address this correctly.
Thanks,
ralphsulser
Identifications we use are lot tickets placed in part containers from each process department. The lot tickets contain lot numbers, part numbers, process name, raw steel heat numbers, die numbers, barcode scan codes, etc. We can trace all parts from each process back to the steel chemical analysis report we receive with each lot of steel received. Each process also logs lot numbers coming in from the previous department, and lot numbers going out from their department, on their checksheets.
GStough
In addition to barcodes as Ralph mentioned, labels, ink stamps, sewn-in labels, etc. may also be used, depending on the product.
Our identifiers contain the product style number, production lot number and/or case ID number, which can be traced to the date, shift, and in some cases the inspector who packed the product, depending on the type of product. The application of these means of identification and traceability is documented in approved procedures.
Ted Schmitt
Thanks,
We have a single number for each product assembled. During final inspection, we register this unique number and along with all of the subcomponents traceability numbers.
Ex. :
Unique Part number HA 001
Body : 12306
Bonnet : 12407
Stem : HQ
Rings : AB
Wedge : 12407
Weld on wedge : BZ
etc...
Each quality certificate we receive for the above components is verified and if approved, we write down the individual traceability number on it.
Hope this helps...
juliov
Thanks for the info. How can the records in the master list of records be entered under the headings of Location, Filing, retention and disposition.
specifically who would be the records custodians? since prod id and traceability can be encountered everywhere in the plant,
thanks,
Ted Schmitt
thanks,
IMO, 4.2.4 only applies to the maintenance of the traceability records and not the identification of the products...
I maintain as a record my suppliers quality certs and my Master assembly list...
Filing : by supplier / by cert #
Retention : 20 years
Disposition : recycle
ralphsulser
thanks,
This is included in our procedure for "Control of Records". Quality Control is the custodian of all the records relating to quality documents, such as check sheets, X bar & R charts. Filed in QC and after 1 year put in storage boxes identified with all the pertinent info. Then the boxes are stretched wrapped to a skid and stored in a safe palce in the plant on racks. Our procedure specifies all records will be maintained for 7 years unless otherwise specified, before disposition.( this was an edict from corporate headquarters to satisfy their requirements)
Vicki Mayer GAGEpack and Subcontracted Calibrations Traceability Using GAGEpack Software 2
Y Software to Manage IEC 62304 Traceability Requirement IEC 62304 - Medical Device Software Life Cycle Processes 3
qualprod Traceability with no rules to control labels? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Stock Traceability Methods, where to start? Manufacturing and Related Processes 0
B ASTM, Steel HEat traceability and mixing at distributors/reprocessors Various Other Specifications, Standards, and related Requirements 0
C IVD Metrological traceability without a reference measurement procedure General Measurement Device and Calibration Topics 11
A Traceability unequal lots/batches delivery production IATF 16949 - Automotive Quality Systems Standard 8
H Traceability after changing the machine IATF 16949 - Automotive Quality Systems Standard 13
A Traceability label ISO 13485:2016 - Medical Device Quality Management Systems 7
T Design Traceability - Labelling / Instructions for Use ISO 13485:2016 - Medical Device Quality Management Systems 5
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
S Traceability of requirements to design and risk Design and Development of Products and Processes 3
T ISO 9001 8.5.2. - Identification and traceability to Identify Outputs - Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S IATF 16949 - Partial traceability of Aftermarket products IATF 16949 - Automotive Quality Systems Standard 5
R DHR question: Traceability of components ISO 13485:2016 - Medical Device Quality Management Systems 2
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Traceability of component parts - Bolts, screws and washers ISO 13485:2016 - Medical Device Quality Management Systems 3
R Traceability on Unmarked Parts - AS9100 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Non conformance product identification and traceability 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
B Traceability of Thermoelement Batches ISO 17025 related Discussions 7
G ISO 17025:2017 Uninterrupted chain of traceability for test laboratories ISO 17025 related Discussions 6
J What is the minimum standard for automotive component traceability? Manufacturing and Related Processes 2
A Validation of Calibration Methods and Traceability - ISO 17025 ISO 17025 related Discussions 3
shimonv Design input/output traceability for mechanical parts ISO 13485:2016 - Medical Device Quality Management Systems 31
K Identification and Traceability with an ERP system - Barcode Labels? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B PED 2014/68/EU - Is this Traceability audit finding correct? Other ISO and International Standards and European Regulations 4
N FDA Traceability Requirements - Component lots ISO 13485:2016 - Medical Device Quality Management Systems 2
Stefan Mundt ISO 9001:2015 - 8.5.2 Identification and Traceability Manufacturing and Related Processes 14
S How to maintain a design traceability matrix ISO 13485:2016 - Medical Device Quality Management Systems 2
N Requirements for the identification and traceability of demo product for sales force US Food and Drug Administration (FDA) 1
MrTetris Traceability in Medical Sofware Development Process IEC 62304 - Medical Device Software Life Cycle Processes 3
M Medical Device Traceability ISO 13485:2016 - Medical Device Quality Management Systems 9
G Where to list chain of traceability? ISO 17025 related Discussions 6
A AS5553B Counterfeit Prevention - Traceability requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T In house Calibration? Measurement equipment traceability requirements - ISO9001 General Measurement Device and Calibration Topics 12
R ISO 9001:2015 Clause 7.1.5.2 - Is Measurement traceability applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Medical Device Traceability Matrix - Examples EU Medical Device Regulations 8
DeeDeeM IATF16949, clause 8.5.2.1 Identification and traceability-supplemental IATF 16949 - Automotive Quality Systems Standard 1
DeeDeeM IATF 16949 - Clause 8.5.2 Identification and Traceability IATF 16949 - Automotive Quality Systems Standard 7
D IATF 16949 - 8.5.2.1 Traceability Plan - Does anyone have an example? IATF 16949 - Automotive Quality Systems Standard 4
A UDI - Traceability of Products Other US Medical Device Regulations 1
B AS9100 Rev D - Traceability of Consumables AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Customer Identification and Traceability in Manufacturing Plans Manufacturing and Related Processes 5
S Traceability and the initiation of GMP Activities 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
N Calibration Traceability - Fluke 753 dpc with thermocouple Calibrated by Fluke ISO 17025 related Discussions 4
T Policy or Good Guidance for a Traceability Decision Tree (Serial and Batch Numbers) Misc. Quality Assurance and Business Systems Related Topics 4
J How to understand IATF 16949 Clause 8.5.2.1 - Traceability IATF 16949 - Automotive Quality Systems Standard 5
A Aluminum Die Casting Product Traceability Manufacturing and Related Processes 10
G Traceability - Checklist from NIST General Measurement Device and Calibration Topics 4
Raffy ISO 13485 NIST Traceability requirements for calibration of test equipment ISO 13485:2016 - Medical Device Quality Management Systems 3
