7.5.4 Customer Property in a Repair Station
Uriel Alejandro
Hi everybody
I?m dealing with a situation related to customer property.
This is the situation:
One of our customers sent us a harness for reparation, it wasn't manufactured by us. We are just in charge of reparation.
According to 7.5.4 (Customer Property) "The organization shall exercise care with customer property while it is under the organization?s control or being used by the organization"
For us exercising care begins from product delivery to us. So, when a product it's manufactured by us we treat it under a scheme of RMA, we do the reparation and send it back to customer.
Now the question is: is it correct to give the same treatment to this harness? I mean, make it go though RMA scheme?
Big Jim
Re: 7.5.4 Customer Property
There is no reason that you must do it that way, but why not. That system is already in place. Why invent another method to track and handle it for this somewhat uncommon situation?
Marc
Fully vaccinated are you?
Re: 7.5.4 Customer Property in a Repair Shop
Sounds to me like you're operating as a "Part 145 repair shop" at times: "One of our customers sent us a harness for reparation, it wasn't manufactured by us."
The only down side I can think of is how your MRP system will handle an RMA for a part number you didn't make. Since this is posted in the AS9100 forum, I assume your business focus is as an aerospace supplier. Traceability issue(s) may come into play.
Darrell B
In my opinion, you would treat it like a new PO. The RMA process is for Returns, which this clearly is not.
G
gbcqc
Our repair station receives the part with a RFQ and then after the quote, we get the PO or instructions of what to do with the part. We do not bring any repairs in under a RMA into the repair station. Our production side uses a RMA system but the repair station does not.
Traceability should be the paperwork we receive from the customer. That same information (SN or other ID) is put on the 8130 form when shipped back to the customer. We keep a copy for our records.
But this is just the way we do it.
W
WKHANNA
At our facility, we would treat this as a new order. The order would specify 'Customer Supplied Material'. This would trigger the process of documenting, inspecting & handling of the material as soon at it arrived at our dock.
somashekar
Hi everybody
Its customer property that is with you for reparation, be it your manufactured or not. So if the RMA scheme works for you, why not use it. Make sure you communicate any loss or damage of parts to the customer while in your custody. This communication is your record which comes under your records control.
Uriel Alejandro
Thank you all for your answers!
Yes, we act like a "repair shop" sometimes, but most of repair activities are under warranty or maintenance.
So, agreeing with all of you, now we have a confirmed idea of how to proceed. We are going to extend the scope of our returns process in order to properly cover all cases, and not only the returns for discrepant product (RMA) but all cases when a product is sent to us for any purpose (repair, maintenance, raw material/tooling for manufacture, etc.). The 'Customer Supplied Material' idea sounds great :agree1:.
Any customer supplied material even if it will be treated as warranty repair, as a new quote/PO, etc., should be identified, verified, protected and safeguarded (7.5.4).
Again thank you all of for your help
P 7.5.10 Customer property - applies to leased/rented equipment? ISO 13485:2016 - Medical Device Quality Management Systems 10
M Customer Property - ISO 13485:2016 Clause 7.5.10 ISO 13485:2016 - Medical Device Quality Management Systems 9
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
C What falls under the 'Customer Property' according to ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 29
S Customer Property - If at all the customer return the product ISO 13485:2016 - Medical Device Quality Management Systems 2
M Damaged Customer Property - ISO 13485:2016 Clause 7.5.10 ISO 13485:2016 - Medical Device Quality Management Systems 7
A Identification of Customer Property: Customer-Supplied Thumb Drives & Ext Hard Drives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Receiving Inspection of Customer Owner Property IATF 16949 - Automotive Quality Systems Standard 5
E Owns Customer Property but No Product Integration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9001 Clause 7.5.4 - Damaged or Lost Customer Property Record ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
E ISO 9001 - 7.5.4 Customer Property - Services (e.g.: Training) on Rental Property ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Does anyone have an example Customer Property Procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
G Customer Property Cl. 7.5.4 - Where does ISO 9001 stop and ISO 27001 start? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
B Customer Property Exclusion as it applies to Personal Data ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C Identification of Customer Property - Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P Is a Drawing (Print) Customer Intellectual Property? ISO 13485:2016 - Medical Device Quality Management Systems 16
L Customer Property Checklist example wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
somashekar FDA cGMP on Feedback, Advisory Notice and Customer Property 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C Customer Property Log example wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
E How Do You VERIFY Customer Property? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Customer Property Identification Requirement - ISO 9001 Clause 7.5.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 77
Q Customer Property Tools - par. 7.5.4.1 - Electronic identification of a certain tool IATF 16949 - Automotive Quality Systems Standard 6
J Customer Property ISO 9001:2008 Clause 7.5.4 - Does this include E-mails? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Supplier's Property - Does 7.5.4 Customer property apply to supplier's property ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
N Customer Property Logs - Tracking customer property, specifically production tooling IATF 16949 - Automotive Quality Systems Standard 5
B What is Customer Owned Property for moulds and spare parts factory ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T Notification of lost/damaged Customer Property - Customer Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Customer Property - The best way to inspect MLO and what acceptance criteria AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D TS 16949 Clause 7.5.4 Customer Property, Intellectual Property requirements IATF 16949 - Automotive Quality Systems Standard 5
M 7.5.4 Customer Property - ISO 9001:2008 Intellectual Property ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Can I exclude Customer Property? ISO 9001 Clause 7.5.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
D Clarification on "Customer Property" - TS 16949 Clause 7.5.4 IATF 16949 - Automotive Quality Systems Standard 4
6 Customer Property documentation (Audit Finding) - Clause 7.5.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
H Can the documents supplied by the client categorised as customer property?? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
H What can be customer supplied properties (property) for the software industry? Software Quality Assurance 18
K Customer Property - Notifying Customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Purchase Order and its relationship with customer property ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D Absence Of Any Form Of Customer Property ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
K Identifying production dies to satisfy the 7.5.4 Customer Property clause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
H Not having a form for Customer Property Damage - ISO 9001 Clause 7.5 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
P Customer Supplied Property - System breakdowns at every level including sales ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A How is Customer Property defined by TS 16949? IATF 16949 - Automotive Quality Systems Standard 6
G 7.5.4 Customer Property (Shipping Containers) IATF 16949 - Automotive Quality Systems Standard 2
K Defining Customer Property - Specifications, templates, patterns from customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
T Customer Property ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Claes Gefvenberg Customer Property - 7.5.4 (intellectual property) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P Customer Property - 7.5.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Crimpshrine13 Customer Scorecards - Missing Scorecard from one Customer IATF 16949 - Automotive Quality Systems Standard 27
B Customer Preference Testing Customer and Company Specific Requirements 2
T No Customer Response to an SCR Manufacturing and Related Processes 2
