7.6 Calibration (referencing outsourcing) in the Quality Manual
Crusader
I'm venturing into new territory. Current employer does not have a lab or controlled area for calibrating in-house. Everything will be sent out.
I guess I'd like to see some examples of how this was documented in a quality manual for ISO 9001.
Anyone?
Michael_M
Anyone?
this is what we have for external calibration:
3.5 External Calibration and/or Measurements
3.5.1 Qualification
No contracted metrology laboratory is used until it has been qualified, verifying compliance with ANSI/NCSL Z540-1 or ISO 10012-1. ISO certification will qualify any potential laboratory.
3.5.2 Calibration Certificate
A calibration certificate is required in all cases where calibration is performed by an outside source. This certificate will include the following minimum information:
?Date of Calibration,
?Identification of the equipment to which the certificate pertains,
?Before and after measurement values of the equipment, and
?Proof of traceability to NIST (or other natural constant) for the accuracy of equipment used in the calibration.
All outside calibration certificates will be maintained in the Q.A. department.
3.5.3 Calibration Seals
Calibration adjustments, accessible from the outside of the equipment (other than zero/standardize) and access to internal adjustments are made tamper proof. This is accomplished using glyptol or frangible labels. Breaking of these seals voids the calibration.
Crusader
3.5.1 Qualification
And this is all you need in the QA Manual? No other docs to support?
insect warfare
QA=Question Authority
This is what we state in our manual:
"Calibration of test equipment (new and otherwise) is quoted and outsourced to an ISO 17025 accredited laboratory that specializes in calibration or metrology. The unique identification of items requiring calibration and/or verification, and their calibration frequency, is defined in separate documentation.
Test equipment is protected and safeguarded during handling, maintenance and storage through authorization of duties and/or the use of specified instructions. Employees are prohibited from performing maintenance on test equipment (such as removing components or breaking seals) that would potentially invalidate its measurement result or calibration status.
Golden samples are used (where applicable) to ensure that consistent results are obtained from test equipment, and are promptly replaced when they cannot provide those results.
Where test equipment does not perform to expectations, it will be removed from the area and, depending on its condition, may need calibration. Known good calibrated test equipment will be substituted in its place. Repaired test equipment is re-calibrated and verified before it is re-used.
Qualified calibration technicians will perform calibration activities either on-site or at a laboratory. Calibration certificates are issued, and stickers are placed on the corresponding equipment showing the calibration status, in accordance with their procedures.
The following types of equipment are tagged out to prevent inadvertent use, regardless of its working condition: Past due Calibration, and Defective (or suspect). Defective equipment may be routed to vendors who specialize in equipment repair, unless it is not economically viable to do so, in which case the equipment may be scrapped or its parts re-sold."
We also maintain the necessary records to provide evidence that we are ensuring this amount of control over this particular outsourced process. In short, there's not much to it. Define your required controls, implement them as you would and maintain a history of what's happened.​
Brian :rolleyes:
Michael_M
I keep a copy (scanned) of the calibration record. For outside processing, that is all I have.
Note, what I have listed is part of our calibration procedure, the quality manual does not state anything specific about outside calibration services.
Crusader
okay. understood. :thanks:
E Calibration-Conditional Pass Measurement Uncertainty (MU) 2
S Calibration Interval calculation for ECG Machine Calibration Frequency (Interval) 4
Mikey324 External calibration - Finding in our 3rd party audit General Measurement Device and Calibration Topics 58
L A certificate of conformance used to support a calibration General Measurement Device and Calibration Topics 6
A AS9100 - 7.1.5.2 In-House Calibration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
B UV-A and Illuminance meter Calibration Setup General Measurement Device and Calibration Topics 0
S Calibration Related Posters General Measurement Device and Calibration Topics 2
F Quality Control in Electrical Calibration ISO 17025 related Discussions 0
C Narrow definition of IMTE or calibration possible? ISO 13485:2016 - Medical Device Quality Management Systems 8
dhuot1990 In-House Calibration Program - Biotech Industry General Measurement Device and Calibration Topics 3
M Reference part calibration or verification General Measurement Device and Calibration Topics 12
M Calibration of equipment IATF 16949 - Automotive Quality Systems Standard 4
Q Gage calibration / tracking software General Measurement Device and Calibration Topics 5
C Should resolution be included in uncertainty budget for digital caliper or micrometer calibration? Measurement Uncertainty (MU) 5
S Calibration Due date-Critical Connie General Measurement Device and Calibration Topics 16
Q Request Calibration Info Calibration and Metrology Software and Hardware 16
R Calibration Log - Archive Manufacturing and Related Processes 2
U Calculate acceptance of equipment reading after calibration General Measurement Device and Calibration Topics 2
D Question on Documented Calibration versus ISO 17025 Accredited Calibration ISO 13485:2016 - Medical Device Quality Management Systems 2
U Calculate acceptance of calibration reading Measurement Uncertainty (MU) 1
D Air hood calibration ISO 13485:2016 - Medical Device Quality Management Systems 1
K Ground Bond Test for Class I Medical Electrical Equipment - calibration problems IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Calibration/Verification Report Durometer ISO 17025 related Discussions 2
S Medical device equipment calibration Qualification and Validation (including 21 CFR Part 11) 1
J Scrap Material Scale Calibration Required? IATF 16949 - Automotive Quality Systems Standard 21
S 7.1.5.2.1 Calibration/Verification Records IATF 16949 - Automotive Quality Systems Standard 6
K Is Calibration Required for Non-Adjustable Commercial Inspection Devices? General Measurement Device and Calibration Topics 11
F Calibration in GPC/SEC General Measurement Device and Calibration Topics 1
Q Changing calibration frequency Calibration and Metrology Software and Hardware 18
M IATF 16949 SI # 10: Integrated self-calibration of measurement equipment- Needs for explanation IATF 16949 - Automotive Quality Systems Standard 2
M Storing Calibration Certificate Document Control Systems, Procedures, Forms and Templates 7
B Risk analysis for defective measuring or measuring equipment out of calibration General Measurement Device and Calibration Topics 2
S Placing a calibration sticker with someone other than your initials Records and Data - Quality, Legal and Other Evidence 8
J IATF 16949 Calibration/Verification records question ISO 26262 - Road vehicles – Functional safety 6
M Approval of Calibration Certificates General Measurement Device and Calibration Topics 1
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 3
N IATF Calibration Lean in Manufacturing and Service Industries 5
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 32
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
