G
Please share your thoughts and insight concerning the following ISO/TS 16949:2009 situation.
Our TS Registration auditor says that ALL measuring and test equipment systems listed in a Process Control Plan must be calibrated and have Statistical studies conducted to analyze the variation present in the results because of what is said in 7.6.1.
7.6.1 Measurement systems analysis
Statistical studies shall be conducted to analyze the variation present in the results of each type of measuring and test equipment system. This requirement shall apply to measurement systems referenced in the control plan. The analytical methods and acceptance criteria used shall conform to those in customer reference manuals on measurement systems analysis. Other analytical methods and acceptance criteria may be used if approved by the customer.
Example: Pyrometer used to measure temperature, which is an internal Process requirement that could potentially affect a product requirement (Mechanical Properties) that is checked prior to shipment to the customer.
I believe that this only applies to measurement devices that are used to provide evidence of conformity of product to determined requirements because of what is said in 7.6.
7.6 Control of monitoring and measuring equipment
The organization shall determine the monitoring and measurement to be undertaken and the monitoring and measuring equipment needed to provide evidence of conformity of product to determined requirements.
Example: Instron Robotic Mechanical Testing Machine used to measure Mechanical Properties (yield, tensile strength, etc.), which is a Product requirement of our customers.
Situations like this will only make people take things out of their Process Control Plans that should be in there for all the right reasons.
Please advise. Thank You.
