8.2.2.5 Internal Auditor Qualification - Competent Auditor or Qualified Auditor?
jasonb067
#11
Re: 8.2.2.5 internal auditor qualification- Competent auditor or qualified auditor?
English can be fuzzy at times and there can be enough synonymous overlap between two words that context becomes necessary to decipher what's being said.
In the context of the standard, I tend to agree with Stijloor. If the standard says an auditor must be qualified, I think we should be able to assume from the context that competence is part of being qualified. It would make no sense otherwise.
On the other hand, if a person were (for example) applying for a job, the hiring company would want to know about the candidate's qualifications (training, experience, etc.) while recognizing that competence can't be demonstrated until the person is on the job.
But in the context of the standard there are customer specific requirements for Auditor Qualification. For one company those include that one must be trained in core tools, CSR, automotive process approach, or have conducted x number of internal audits.
There is also a requirement from another company for the auditor to be competent in understanding and application of process approach to auditing, core tools, and CSR.
If one portion of the standard CSR or not requires competence and remainder of the standard is silent on competence I can not infer that it is a requirement where it is not stated.
insect warfare
QA=Question Authority
#12
Hi warfare
Thanks for your reply.
I became confused, because your answer is completely against Stijloor answer. You believe that for competence you must be qualified, but Stijloor believes that for qualification you must be competent.:confused:
Wow, a lot of truth being spoken in this thread...
From what I've read so far, it almost sounds like a paradox: Which came first, the chicken or the egg? Qualification or competence? :confused:
My thought process was that qualification is something that was done and it can be proven that it was done, just like evaluation of competence.
Competence itself is that non-tangible thing which can come and go for many, many reasons. My pool league buddies always keep telling me, "You're only as good as you play today". So true...
Has this been discussed before in the Cove? I would like to see what others have had to say about it...
Brian
#13
The authors of the standard have no influence over, or any way to predict, what any individual customer might require, or what descriptive terms might be used in CSRs. It would be a wonderful thing if there were universally understood definitions, but there ain't.
ssz102
#14
the responds from Treesei is perfectly and correctly
red66climb
#15
There are some conflicting statements here that need some moderation!!!
:caution:
The two concepts are similar but not identical. Language certainly gets in the way.
Qualifications are things we place on our resume...such as certifications and degrees.
However, to be deemed "competent" you don't have to have formal qualifications. You can learn "on-the-job" too. To be competent, we need objective evidence of competency. Observing someone and providing documented feedback is one form. Exams and quizzes are another way to demonstrate competency.
I like to think of qualifications as something I use to screen applicants with in a hiring process. Competency is something that takes me 90 days to properly evaluate and document. Both are needed in a training record. A resume may be in a personnel folder, while competency evaluations might be in a training folder. The two items together make a complete training record.
#16
There are conflicting statements due to ambiguities in the language, and not necessarily because someone is right and someone else is wrong.
When in doubt, look it up:
qual·i·fied(kw
l
-f
d
) adj.
1. Having the appropriate qualifications for an office, position, or task.
2. Limited, restricted, or modified: a qualified plan for expansion.
qual
i·fied
ly
(-f
d
l
, -f
d-l
) adv.
The American Heritage® Dictionary of the English Language, Fourth Edition copyright ©2000 by Houghton Mifflin Company. Updated in 2009. Published by Houghton Mifflin Company. All rights reserved.
com·pe·tent(k
m
p
-t
nt) adj.
1. Properly or sufficiently qualified; capable: a competent typist.
2. Adequate for the purpose: a competent performance.
3. Law Legally qualified or fit to perform an act.
[Middle English, adequate, from Old French, from Latin compet
ns, competent-, present participle of competere, to be suitable; see compete.]
com
pe·tent·ly
adv.
deepak69748
#17
Qualification : Certification Course of IQA
Competent : mere doing certification course is not enough , you should start doing Internal Quality Audits independently.
S Internal Auditing for API Spec Q1 - auditor qualification requirements Oil and Gas Industry Standards and Regulations 6
M TS16949 8.2.2.5 Internal Auditor Qualification IATF 16949 - Automotive Quality Systems Standard 4
9 AS9110 Rev A Internal Auditor Training and Qualification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
K Internal Auditor Qualification for ISO 9001:2008 Internal Auditing 14
R ISO/TS 16949 Internal auditor qualification Internal Auditing 14
R Internal Auditor Qualification Requirements Internal Auditing 7
M NCR (minor) - Internal auditor qualification not prescribed Internal Auditing 7
V Internal Auditor Competency KPI IATF 16949 - Automotive Quality Systems Standard 14
B Internal Auditor Competency - Product Auditors Internal Auditing 9
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
S ISO 13485 Lead Auditor - Debate between our Quality Team and Regulatory Auditor - Internal Auditor Training ISO 13485:2016 - Medical Device Quality Management Systems 23
B Internal and external auditor competency to CSR's IATF 16949 - Automotive Quality Systems Standard 20
D Impartiality of Internal Auditor ISO 9001/13485 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
M IATF 16949 7.2.3 Internal Auditor Competency - Trainer's competency Internal Auditing 7
C Recommendations for UK-based ISO 13485 internal auditor training ISO 13485:2016 - Medical Device Quality Management Systems 1
A External Auditor issue with Internal Audits Internal Auditing 7
Q Internal Auditor competence for ISO 14001 ISO 14001:2015 Specific Discussions 11
S IATF 16949: Is "Certified" Internal Auditor mandatory? IATF 16949 - Automotive Quality Systems Standard 9
J Your opinion on the better training org for IATF16949 Internal auditor and Lead Auditor IATF 16949 - Automotive Quality Systems Standard 3
Q Internal Auditor Training requirements for ISO 14001:2015 ISO 14001:2015 Specific Discussions 5
E Informational I would like to get some Internal Auditor Training Internal Auditing 31
J IATF 16949 CAR - Internal Auditor Requirements IATF 16949 - Automotive Quality Systems Standard 15
A ISO 13485 - Internal Auditor Independence and Process Owners ISO 13485:2016 - Medical Device Quality Management Systems 3
Q AS 9100D internal auditor training requirements Internal Auditing 16
A Other Discussion Boards - Internal Auditor Coffee Break and Water Cooler Discussions 5
E Online training for an internal auditor to AS9120B AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q Internal Auditor Trainer's Requirement Internal Auditing 4
D IATF 16949 - Internal Auditor Training/Certification Requirements Training - Internal, External, Online and Distance Learning 2
R Internal Auditor vs. Public Accountant - Accounting Student Needing Help Career and Occupation Discussions 4
C IATF 16949 Cl. - 7.2.3 Internal Auditor Competency IATF 16949 - Automotive Quality Systems Standard 1
C IATF 16949:2016 Cl. 7.2.3 Internal Auditor Competency Requirements IATF 16949 - Automotive Quality Systems Standard 39
Q IATF 16949 Cl. 7.2.3 - Internal Auditor Competency and Records IATF 16949 - Automotive Quality Systems Standard 5
R Internal Auditor auditing Internal Audit Procedure (AS9100) Internal Auditing 18
Q How can an Internal Auditor Trainer's Competency be Evaluated - IATF 16949 Cl. 7.2.3 IATF 16949 - Automotive Quality Systems Standard 10
H ISO/IATF Internal Auditor Recommendations For Manufacturer In California, USA Internal Auditing 3
Casana 2nd Party and Internal Auditor Qualifications & Training IATF 16949 - Automotive Quality Systems Standard 13
P Problem with IATF 16949 Clause 7.2.3 Requirements (Internal Auditor Competency) IATF 16949 - Automotive Quality Systems Standard 3
B Competency of Trainer for Internal Auditor Training (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 11
C ISO 13485:2016 - Internal Auditor Training vs. Lead Auditor Training Training - Internal, External, Online and Distance Learning 4
J Dinged on Internal Audits for supervising an auditor I was training Internal Auditing 10
M Internal Auditor --> Licence needed? Internal Auditing 6
V Internal Auditor Training Documents and PPT Document Control Systems, Procedures, Forms and Templates 5
V Internal Auditor Training Documents and PPT Internal Auditing 3
V Certified Internal auditor is necessary? ISO 9001 requirement? Quality Management System (QMS) Manuals 4
D Can the Plant Manager be our ISO Representative and an Internal Auditor? Internal Auditing 26
M ISO 13485 Audit Questions - Internal Auditor Training and other Requirements ISO 13485:2016 - Medical Device Quality Management Systems 10
M Questions about AS9100 Internal Auditor Training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
