8.2.2 Internal Audit - Determination of Effective Implementation
morteza
Hi all
In clause 8.2.2 ISO/TS states:
The organization shall conduct internal audits at planned intervals to determine whether the quality management system:
b) is effectively implemented and maintained
May someone describe me the meaning of effectively implemented? How can I satisfy this requirement during internal audit?
Overview:
I think this requirement asks the organization to evaluate the effectiveness of its QMS during internal audit. If the intent of the above requirement is this, it would be logical and better that the standard would write the requirement in this way:
b) is effective and maintain effectively
So, I think effectively implementation and effectiveness of QMS should be 2 different things.
Is it right?:confused:
Thanks all
amit_rd
Re: 8.2.2 internal audit- determination of effectively implementatin-what is the inte
Congratulations for bringing such interesting topic:
To understand 8.2.2 completely, I suggest that you study 7.1 (ISO/TS16949:2009), Clause 8.3.3 from ISO 9004:2009 and also refer to ISO 19011 for further insights on auditing.
I am sure that you will be clear on the fact the effectively implementing the QMS is the key to QMS effectiveness :)
Hence what clause specifies is correct!
Note: We must remember that ISO 9001 and ISO/TS16949 are not designed in isolation, and all references to them are to be carefully studied for better interpretations.
K
kgott
Hi all
May someone describe me the meaning of effectively implemented? How can I satisfy this requirement during internal audit??:confused:
Thanks all
Perhaps if you looked at 5.1 e- objectives and 5.4.1 - Objectives. While I can't find it, (I'm a bit short on time) I know there is a phrase ' in accordance with planned arrangements."
I think you will find insight in these areas to the question you have, which by the way is a good question.
To some extent "effectively implemented' may also mean whatever management is happy with.
hope this helps.
Colin
A couple of things to to my mind regarding this aspect of the internal auditing clause.
In terms of the implementation aspect of this clause, I have known many situations where a procedure defines a process very well but it is simply not being followed, It is often the case that people find new, easier ways of doing the job but the procedure gets 'left behind' - so it lacks maintenance.
Or:
You could be conducting an audit where a procedure defines that the sequence of activities is A, B then C. When you check this you find that they are following this sequence but the output from the process is not what the organisation wants it to be. As kgott rightly states, we should be checking that the output satisfies the quality objectives. In this situation you could not raise an NC for not complying with the procedure, but you should raise it because it is not effective in meeting the organisation's needs.
mortby
To me, effectiveness is simply - does it work?
I use a 3 level model to help prioritise improvement activities:
Compliance - does it meet the basic requirements of the standard(s) or procedure(s)?
Effectiveness - does it work? does it do the job intended? does it achieve the goal?
Efficiency - does it work well? is it quick and easy to use? does it minimise the time and resource required to achieve the goal?
We must maintain compliance, effectiveness is important (but survivable short term) and efficiency is nice to have (but wins you lots of credit with people in your business)
C ISO 14001 Internal Audit - Opportunity for Improvement ISO 14001:2015 Specific Discussions 2
P Does FDA require certification for quality system internal audit for auditor? Qualification and Validation (including 21 CFR Part 11) 1
P Looking to outsource Internal Audit - MDSAP competent auditor needed Other Medical Device Regulations World-Wide 9
J Outsourced Internal Audit requirements for Aerospace Suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 21
D Number of people to be interviewed during an internal audit? Internal Auditing 6
Q Easy CARs for Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
A Internal audit plan and processes for ISO 14001:2015 ISO 14001:2015 Specific Discussions 3
C API Q1 internal audit report Internal Auditing 3
P Filled in F48/F49 for internal audit ISO 17025:2017 Internal Auditing 2
J Internal audit random sampling methodology Internal Auditing 2
G Organizing internal audit program for an Integrated QHSE Management System Internal Auditing 13
W How do you phrase your internal audit questions? Internal Auditing 3
M IATF - Internal Audit 3 year span Internal Auditing 4
Q ISO 9001-2015 Internal audit finding Internal Auditing 14
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
A Add MDSAP to Internal Audit Schedule Medical Device Related Regulations 0
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 18
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 8
A Internal Audit Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
salaheddine96 Internal audit planning Internal Auditing 2
E MDR internal audit Internal Auditing 1
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
B Looking for 10 Internal Audit Online Training Participants ISO 17025 related Discussions 2
H AS9100 Checklist for Internal Audit needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F Internal Audit before Pre-Assessment ISO 17025 related Discussions 2
Q Internal audit plan template Internal Auditing 12
L Internal audit during COVID-19 restrictions ISO 13485:2016 - Medical Device Quality Management Systems 5
O ISO13485 implementation - Are internal audits expected before stage 1 audit? Design and Development of Products and Processes 3
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
S Internal audit discrepancy - We missed a few audits that were scheduled Internal Auditing 12
Raffy ISO 14001 9.2.2 Internal Audit Programme Content Internal Auditing 10
N Internal Audit Schedule – Who gets to set the schedule? Internal Auditing 16
V IATF 16949 9.2.2.1 Internal Audit Program - "Process Changes" IATF 16949 - Automotive Quality Systems Standard 11
G Non Conformance During ISO 9001 Audit - Not All Internal Audits Completed General Auditing Discussions 19
B Using external FDA and ISO 13485 audit as internal audit Internal Auditing 6
T Internal Audit Schedule when Hiring Out Internal Auditing 7
D ISO 9001:2015 Internal Audit Training Advice Internal Auditing 10
M Internal audit consultant ISO 13485 (English speaker) Consultants and Consulting 3
S Implementing a 45001 Health & Safety standard - Internal audit plan wanted Internal Auditing 1
F Internal Audit - Procedure example Internal Auditing 5
C Internal Audit - Process Clause Matrix / Audit Checklist ISO 13485:2016 - Medical Device Quality Management Systems 7
CPhelan Internal audit - Combine similar nonconformities in one or keep separate? Internal Auditing 6
M Internal Audit Plan in Retail Internal Auditing 10
