8.2.4.2 First Article Inspection - Does every new part that is run require a FAIR
Lorgeo
Hello All,
My interpretation of sec. 8.2.4.2, First Article Inspection of AS9100B is that any new part that is run requires a FAIR using SAE AS 9102 3 page form. Is this correct? Thanks!
Sidney Vianna
Post Responsibly
Re: 8.2.4.2 First Article Inspection
Hello All,
AS9102 is not mandatory per AS9100B. You could use self developed forms for the FAIR. Some OEM's, however, mandate the use of 9102 for FAI.
Sidney Vianna
Post Responsibly
Sidnet;
Make sure you are using rev. c. I have if you need.
I was answering the question where the poster specifically mentioned 9100B. Since nobody can attain ICOP approved certification to AS9100C yet (and for several months to come), folks still need to keep conformity to Rev. B.
Oh, and by the way, I do have a purchased copy of both editions of the standard. You should not offer to provide a copy of a document protected by copyright here at The Cove, because it is against the policy and it is illegal.
I'll see you in Charlotte, next week.
joanas bruning hicks
I apologise for the lack of taking into account legal issues; am new to the site; trying to help.
Do not need the sarcasm; its painfully obvious you are an auditor and I'm a sales person.
brandnew
Hi Sidney,
i have a question, as i'm relatively new to the AS9100. Regarding FAIR, as we aim to become certified, does this apply to all parts produced whether it is an "in-process" or "finished" part?
It’s not the final product that is of concern, it’s the part where we just do a few things and send it to the customer who will create the finished product of the 'in-process' part they received from us.
While i'm in this question: Section 7.5.1.3 talks about validation of equipment. Can an FAI be used to validate the equipment? Or is this more of an "and" and not an "or" type of situation to deal with validation?
Coury Ferguson
Moderator here to help
Sidney I agree with you.
By choice, we/I use the 9102 Form and it isn't flowed down by any of our customers as of yet. The reason we/I use the 9102 because I am familiar with the form and I have trained the Inspectors to use it to, using the FAQ on the OASIS database, besides my experience with them.
I have also had FAI's documented on the drawing itself which was accepted by P & W awhile back. But, it is really a choice by the Organization (as you said in-directly) unless it is part of the Purchasing Documents requirements.
V
ValleyGirl
This is definately a question, not a reply to this thread but it has to do with FAI so I thought I'd put it here.
We usually create one proto type part - that's it. It generally will be machined on various machines (operations)- sometimes the same "part" will be machined on two different types of machines at the same time.
The first article is done when the job is finished (with in-process inspections being performed when necessary). Should a first article be performed for each component or assembly when it's machining process has been completed and the part is going to the next machine (operation)? Or are we OK performing the first article at the completion of the part?
What if we make 4 of the same part. Are we supposed to complete (1) part and perform a FAI at that time and then produce the last three?? (This would not be practical):nope: Or do we machine all four and inspect the first one that is finished? or all four?
Oh, and I am speaking of the actual inspection...not just the report.
Hope someone can understand what I'm asking.:confused:
Lorgeo
You seem to be on the right track.:)
The FAI should be done when the lot or single prototype is complete... as you are doing. Once the run of parts is completely done, we take a representative sample (as each part was made using the same process{es}) and do the FAI.
Hope this helps!
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
M Does AS9120 (aerospace first article inspection) apply to all customers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
briteme4 AS9102 First Article Inspection - do I need a second reviewer and signer? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
K First Article Inspection (FAI) - Equipment used - Dimensions vs. Go/No-Go ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Is a First Article Inspection (FAI) Procedure required by ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
C AS9100, Clause 8.5.1.3 - First Article Inspection Costs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
U Whether First Article Inspection Report- FAI is mandatory for regular Human Factors and Ergonomics in Engineering 4
R AS9100 FAI - First Article Inspection to a prior Customers PO AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
G FAI (First Article Inspection) Responsibility - QC or Engineering? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Qualification Builds & Process Changes (AS9102 - First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R FAI (First Article Inspection) on source-controlled parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K FAI (First Article Inspection) vs PPAP (Production Part Approval Process) APQP and PPAP 15
P Question on First Article Inspection referencing ISO 2768 APQP and PPAP 1
T FAI (First Article Inspection) of Large Assemblies/Tooling after move to new building AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
Q FAI IAW AS9102 - First Article Inspection Documentation Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
D AS9102 B (FAI - First Article Inspection) is Released - October 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A AS9102 First Article Inspection and NC Parts - New FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
V KPI (Key Performance Indicators) in First Article Inspection Lean in Manufacturing and Service Industries 4
J Inspection Software to Balloon Drawings and Create First Article Reports Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Delta or Partial FAI (First Article Inspection) - What are the differences? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K FAI (First Article Inspection) using Digital Design Data AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
G First Article Inspection Evidence AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
G What is meant by FAI (First Article Inspection) and how do we comply? AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 26
R How to draft a good First Article Inspection Procedure (when AS9100 is overkill) APQP and PPAP 6
C Inexperienced Mechanical Inspectors and FAI's (First Article Inspection) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L FAI (First Article Inspection) of Prototype Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S FAI (First Article Inspection) during Assembly of Sub-Assemblies Only AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
F Can you reference original FAI (First Article Inspection) after Delta? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R FAI (First Article Inspection) Report Number Method AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
K First Article Inspection - What are the Documents that need to be submitted with it? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Z AS9102 FAI (First Article Inspection) - Is a Ballooned Drawing Required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
O AS9102 (rev.a) First Article Inspection Requirement Quality Manager and Management Related Issues 1
H FAI (First Article Inspection) Software Recommendations and Help Quality Tools, Improvement and Analysis 11
L First Article Inspection Criteria for Medical Device Manufacturers Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S First Article Inspection - General Practices for Medical Device Manufacturers Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
B AS9102 FAI (First Article Inspection) per standard or contract? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Q AS9100 and FAIR (First Article Inspection Report) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
L Selling Products Produced before First Article Inspection (FAI) Approval AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q How to move from Supplier First Article to Sampling Inspection Supplier Quality Assurance and other Supplier Issues 4
E Understanding terminology for FAI (First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
AnaMariaVR2 Rapid Deployment Tips to Prepare for an Inspection Quickly (Article) US Food and Drug Administration (FDA) 0
T FAI (First Article Inspection) - How many parts are measured AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S FAI (First Article Inspection) and Key Characteristics Requirements - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
J AS9102 FAI (First Article Inspection) Full or Partial - Changes to NC programming Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J FAI (First Article Inspection) Do as I say not as I do AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A When to do First Article Inspection - AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
P Design Characteristics of the FAI (First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P First Article Inspection - FAI for every new product launch AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K Incoming Materials First Article Inspection (FAI) Procedure needed Document Control Systems, Procedures, Forms and Templates 2
